HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
I didn't realize but saw I have had a "duh" moment. This as the instructions clearly stated, use a plank to clamp to the bulkhead for installation of the stanchions.
Well, obviously they knew from the start that was the way to go.
There are a lot of cutting to get them done.20171024_205044.thumb.jpg.b9e0465e137aedf05e16ba0f765a53e5.jpg
I am considering cutting the heads from the bulkhead and replace them with stanchions. This to make them look uniformed.
Respectfully
Looking good!
I agree that the stanchions from the bulkheads leave a bit to be desired.  I ran into the same thing.  They do stand out once you get the others in there.
If I remember correctly from my build, I left the stanchions from the bulkheads in place and added the bulwark planking.  Once that was secure, I added the 'false' stanchions.  Once those were all in place, I went back and cut the bulkhead's stanchions out and replaced them with 'fake' ones.  This way I was able to get the planking nice and straight thanks to the bulkhead's stanchions, but ended up with a uniform look since I cut them out later.  If you cut the bulkhead ones off first, I think it might take some work to keep everything aligned for the bulwark planking.
Dave
Thank you for confirming my idea and approach with the bulkhead, and yes, I am to plank before removing them.
Have to remember not to glue the planks to the bulkhead tops.
Glad I have the razor blade saw.
Respectfully
My "baby" now has teeth (the stanchions) and are in place.
Now I am working on the stern part.
It's a delicate area and it's giving me a challenge.
However, I do  like it....... thus giving me a time to experience carving.
59f955574d998_sternparts.JPG.fefbfbd7e34ea447b80ee3248cd118b2.JPG59f95577b7309_sternpiece2.JPG.cbe518089371b015c978795717948265.JPG59f955788fde1_sternpiece3.JPG.a5d1351070c2a549fa0b7b1fee3808ee.JPG59f955795f501_sternpiece4.JPG.31d2bd5f5449548f9e1d4a517b05533c.JPG
Respectfully
look'in good......I'm going to need to follow the same procedure.    the model I got was damaged and I had to cut all the bulkhead post off  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Looking nice Per! Your deck looks very good! The stanchions as well!:)
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
The boat has beautiful lines Per.
Thanks Mike,
However, the stern part is certainly testing my patience.
Pictures will follow.
Respectfully
Did you have to carve that stern piece? Can't imagine a part like that coming from the kit.  Looks like it came out well.
Mike,
That was a piece I created myself.
One of many, the final is now glued into place.
The final was number six.
Funny though,  I think Bluenose has been given me more challenges than the longboat. But someone has once said - be persistent.
Respectfully
A pictorial update.
This block is just balsa to show how I started out.
The final part was made out of boxwood.
After I had somewhat the right size of the boxwood block the Dremel came into use.
There are a lot of angles to consider.
I made one block and then made a mirrored part.
Then dry placing the part at the end of the quarter deck, to figure out how much to cut off.
This part in the middle is the right one to install.
Here are the port and starboard part testing the area.
Some more trimming and then it will be time to add the waist parts.
Below is all my trial parts.
Respectfully
So are you making these pieces because the kit calls for you to? Broken in the box? Just got the urge? If it's the kit then did the plans provide you with dimensions?
The pieces are there on the plans, no dimensions provided. No parts either.
Instruction and plans says, use a block to shape.
A caliper was all I used to lift the dimensions, from there pure determination 😀
Edited by Nirvana
Respectfully
Waist planking has been done on the starboard side.
Extra stanchions will be added for the ones I cut out.
59ffabb2ed2a8_Waistplanking1.JPG.d4cfc71635c9a3e0b8ffda6a71f72bff.JPG59ffabb3c8ae2_waistplanking.JPG.e427b38f29904b9843bd7f0f87fb938f.JPG
Respectfully
I'm not looking forward to those stantions.
Norwegian Sailing Pram 1:12 Scale. 2nd boat in the learning series.
In Dry Dock:
Muscongus Bay Lobster Smack. 1:24 scale. Model Shipways, 3rd in the learning series.
Not sure what'll be next, probably the Santa Maria by Artesania Latina 1:65 scale. Unless someone has a better suggestion for a beginner.
Pride of Baltimore. Model Shipways. Clipper used in the war of 1812.
Black Falcon. Mantua Model. 18 century corsair brig.
CSS. Alabama. E. Manolie? Can't read the font. Build in Liverpool in 1862 for use in the American Civil War by the Confederates. Steam and sail, sloop of war.
Of all the things I've lost, I miss my mind the most.
A baseball cap my Dad wore.
Catching up on your build. Okay, started looking closer after having perused it. Page 1, post of June 7. You mention not to forget to bevel the waterway. I've no idea what you're talking about.
In Dry Dock:
Brian,
The waterway plank needed to be beveled is the third  plank in on the fore-deck.
Look at sheet 2.
Respectfully
Ok, thanks.
In Dry Dock:
On 6/5/2017 at 1:42 PM, Nirvana said:
I also have Gene's practicum for references while building the kit.
Please tell me more about that. I have Laucks practicum by Bob Hunt, but it's too simple. Not "learning" anything from it.
In Dry Dock:
Brian,
Click on the link for download of the practicum, this one is based of pof and totally scratch building.
But it does go into depth when it comes to explanation of building.
Respectfully
Am I missing a link somewhere?
In Dry Dock:
All the way back to page 1. I found the piece that goes parallel to the bulkhead, but not the other 2. I assume I can just make them, right?
In Dry Dock:
Look at the plans, there are two pieces for that bulkhead. One of the is supporting the planks on the foredeck.
I made both of them.
Edited by Nirvana
Respectfully
If I understand it correctly, I found one piece with the rudder and see where that goes. It had to be cut in half. Then there's the great beam that's .09X.2" and the shorter one next to that so that my sailors have something to trip over. I just don't see the pre-cut parts for the great beam. I can fabricate to within .02". It looks like it'd be about 1/64" off.
In Dry Dock:
The way I cut out the bulkhead tops was using my microsaw, cutting the tops into three pieces and from there using a cutting plier to remove the pieces.
This way I got a somewhat clean cut.
Respectfully
After installing the waist planks I had to adjust some of the stanchions, as I didn't a clean glue contact.
It's kind of obvious in this picture.
Respectfully
Nice saw Per.
Mike,
I bought that saw from UMM-USA.
Back to the stern construction.
There are two post to be added at the stern, I saw how they are installed they would be prone to break off once installed.
So I used this lateral plank for support.
Having the notches cut out I dry installed one of the post just to get a verification this was getting somewhat right.
Then it was just to add the glue and have them put in place.
Once the glue had set in a little I corrected the angle of the post to left.
I will use this setup and plank the inside first, doing so will create a sturdy area for exterior planking.
Respectfully
I have to make sure I do a backup of pictures for build log, this as I use both regular camera but also the phones camera.
Update from last night.
The interior stern planking is completed. And I didn't break the posts.
Remaining planking of transom/stern is now in progress (not for the moment this hour) ;)
3520.thumb.jpeg.56c57491d8821b408dd469768497f397.jpeg3518.thumb.jpeg.9493a9d628760b4d7e790e74eb1c44a2.jpeg
Respectfully
