Fist thing to do is to wash the resin hull in soapy water and let it dry. Then fill the minor holes and stuff with putty. I use automotive glazing putty, it is laquer based and dries pretty fast.  Here's the hull after filling and sanding.R2.thumb.jpg.7b26714354fd7f49376600c8a67e1c77.jpg
Next comes gluing a handle on the hull so I can maneuver it better. It's just a basswood block and superglued down. SInce there is a dack part to go over the resin, when I take it off and sand down, it will not show when the model is finished
R3.thumb.jpg.6c4581c9b3d091a16a81e085e7def6c6.jpg.
By the way, I started this over the Thanksgiving holiday. Here's how it looks after the first coat of primer and sanded down with 320 wet. That handle was perfect while spraying the primer.R4.thumb.jpg.41d2c361f113a4637ba5bcc699df9acf.jpg
And here it is after a second coat of primer, this time sanded with 600 grit wet to give a really smooth base, since the finish will be gloss.
I'll follow along.  I built "version 1" of this kit and the Endeavour some 20 years ago.  They still sit in their glass cases on my shelf.
And then I sprayed gloss white from the rattle can. Got a nice shiny finish, but when I pulled the making tape off, I discovered the folly of my ways. I didn't burnish the tape enough, and left a slight flap of overlap unsealed. The result is less than professional.
So now I have to mask off the white, and re-spray the copper. *SIGH*
I have often said that there are very few true craftsmen, the majority of us just learn how to hide our mistakes! (like me)
6 minutes ago, yvesvidal said:
You need to use a better masking tape. That blue stuff is too strong.
I would use Tamiya yellow masking tape. It is the absolute reference for the plastic modelers and small scale projects.
Yves
I'll second that.  I've been using the Tamiya tape for years and love it.  The only thing I ever use besides the Tamiya is the very narrow 3M pin-striping tape.  I used to use loads of both when I painted helmets for a friend's roller derby team.
Edited by shane762
 I have had the same problems with painting copper over gloss surfaces and vise versa until I was taught the following technique:
 - Spray a coat of matte clear over the entire model, including your topcoat, this will seal the topcoat and give both the tape and bottom paint a textured surface to "bite" into.
 - Lay your mask down, as was said, the Tamiya range of masking tape is the best.  They now make tape that fits contours.
 - Spray a coat of clear over the mask at your demarcation line, this will add an additional seal.
 -  Then spray your next color and let sit for at least a full 24 hours if its enamel.  It takes a long time for this to cure.  If not fully cured, it will peel off in sheets.
 - De-mask, inspect, wipe clean all mask residue with a mild solvent, then spray on a few light coats of clear gloss, let sit and enjoy the finish.
Scott
Edited by ScottRC
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
Inbetween coats of clear, I took the photo-etch pieces off and started to work on them. The skylights are half-etched to show the guard rods, but it is all brass color. I painted them with dark grey, then wiped off the highlights with a paper towel (dry) The net result I think gives them some depth.
Last night I attached the laser-cut deck to the hull.Having the locations of the major components cut in is a big help, no need to measure where things go!
To make a work cradle, I cut an oval out of a cardboard box bottom and lined it with foam. I used the waterline template as my guide, cutting about 1/2" larger all around.
Now I can start to do some fun stuff, like populating the deck and getting to the rigging. I consider the hull work a necessary evil that has to be done so I can get to what I like to do.
(makes no difference if its' a solid or planked hull)
Edited by MrBlueJacket
spelling
don't be hard on yourself....paint can be very unforgiving.   flat and gloss is two different compositions.......flat lack the suspensions that gloss paint has.   if that's a resin hull,  then that would account for more heart ache.   resin isn't enamel friendly,  so I've read.   I've never dealt with resin before.....I have the Polar Lights Batmobile and it comes with resin figures of Batman and Robin.....guess now I have my chance.
    I also have a few bottles of Copper paint......bought way back in the mid 90's.  I did the bottom of my United States with it,  with no ill effect.   of course,  it needed to be thinned down a bit more than if it was a fresh bottle,  but I'm good with that  ;)     the tip of giving the hull a clear coat before paint is a good one,  it will give the paint something to adhere to {be sure to use a flat and not a gloss}.  metallic paints are also different.....anything added to a compound will either weaken it or change it's structure.  it has the suspension additive,  but when the metallic additive is added,  it slows down the curing process and dries to a soft finish.   it needs ample time......I didn't touch my hull for at least a day or so.   even then,  it can be prone to finger prints and scuffs,  unless it is given a clear coat {I use a flat or semi gloss lacquer}.
very nice kit you have here.....small,  but all the processes are there,  so there's no loss of experience {just because it's a small scale kit}.  look'in good!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I missed that you gave it a clear coat afterwards.......see......you have things well in hand  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
