On 4/21/2019 at 4:01 PM, TUEL said:
I glued in the completed companionway, and then the cockpit wall.
I used the balsa insert to make a pattern out of some heavy paper stock that was the size of the inside diameter of the cockpit. I trimmed the edge so that it fit to the companionway doorway.
I folded and attached some scotch tape so that I could more easily insert and remove the pattern. I also made a couple of duplicate patterns in the same heavy stock paper for use later.
I have a small protractor that I used to make a circle on graph paper, and divided it into 60-degree segments. I then drew diagonal line between each 60-degree point through the center of the circle. This identifies for me where each of the 4x4 mm supports for the cockpit bench will be located.
Laying the pattern on this circle allowed me to mark the location of each seat support.
The companionway is in the upper right area of the pattern as you can see in the photo. I moved the two bench supports beside the companionway over 2 mm so that the bench aligns correctly. This is the pattern with each slot cut out.
Here is the pattern inside the cockpit.
Here are the bench supports glued in, followed by the pattern removed.
I used one of the extra paper patterns to make a pattern for the bench top.
The pattern measures to be 45 mm in diameter. Per the kit drawings, the bench top is 5 mm wide. Using a little geometry, I located the center of the pattern. Then I used a compass to draw the interior circle, then cut it out as a pattern for the bench top.
I used this pattern to mark the edges on a sheet of 0.5mm walnut. The top hand rail of the cockpit measures to be 3mm wide on the kit plans. I allowed for the interior to overhang the inside of the cockpit by 0.5 mm, so I drew one circle on the walnut sheet to have a 44mm diameter. On the same center, I then drew a 47mm circle, then cut both out with my band saw. After a little sanding, this is how each turned out.
Next I applied one coat of tung oil.
I cut a small piece of plywood, and sanded it to fit the head of the tiller-bar. I used 5-minute epoxy to attached the tiller-bar to the wood piece. This gave me a solid base to glue wood-to-wood in mounting the tiller bar. I painted it black, but I failed to make any pictures of the mounted tiller-bar before I covered it up with the bench top. I glued the bench top and top rail. Here are several pictures of the finished cockpit.
Great and clean finish!
On 5/18/2020 at 11:53 PM, Dr PR said:
Very nice work!
You said you thought this wasn't a good kit for a first build, but in your case I think that is wrong. You have stuck with it and are doing a great job. And you are learning the frustrations of kit building and ways to work around the problems. That is good experience for a first time builder. When you are finished you will have the satisfaction of having overcome the limitations of the kit to build a nice model.
Your next build will be easier as a result.
Phil,
Thanks. It's definitely been a good learning experience. I really expected a learning curve here so my frustrations are limited. I'll definitely know what things I need to do better on the next build. I'm sure that will be another learning experience too. I voice frustrations, but I've really enjoyed building this kit.
Tim
My approach to the sails was to make a copy of each sail to use as a pattern to mark and cut the cloth, and for the location of seams and eyelets. My first step was to make a copy of the sheet with the sails printed on it. My first attempt was to use my laser printer to make the copy of each sail, however it would only print 8.5”x11”, and most of the sails would not fit on one sheet. I probably could have used 8.5”x14”, but I would still have to piece each sail copy together. I copied portions of each sail with the intention of taping the pieces together to make the full sail pattern. My seamstress wife advised me that it would be much better to have each sail pattern on one sheet not pieced together. I took the plan sheet to a local copy/shipping store and had them to make two copies of the sheet, then cut away the portion with the sail patterns on one of those copies.
Next, I cut each individual sail from the sheet.
I continued to look at the build logs of Hamilton, Greatgalleons and Flyer. Hamilton provided very few pictures and limited comments in regard to the sails. The other two have more detail, and that was helpful. One of the build logs showed the edge of each sail being folded over once, but being left unfinished. The other log showed the edge being cut, folded over and glued, also unfinished. I showed these to my seamstress wife, and her recommendation was to fold each edge over twice and stitch it so that it has a finished edge. Looking at the patterns in the pictures above, you notice that some of the edges are not even. This was due to the position on the plan. Looking at the edge of each sail, it shows a 3mm overlap. To fold it over twice I needed 6mm on each edge to allow for two 3mm folds. I cut pieces of paper and taped to each edge where necessary, then cut each sail to have 6mm from the edge of the sail. Here is the result of each sail pattern, with the 6mm edge.
Next, we pinned each sail to the cloth included in the kit.
I needed help and advice, but this is not what I had in mind.
Here are the sails pinned to the cloth and cut, allowing for the 6mm edge.
I had planned to attempt sewing the seams and edges, but my wife wants to do it so she has a contribution to the ship. She has a Husqvarna sewing machine with a lot of features and adjustments.
After a couple of test seams, we decided a stitch length setting of 1 had the best appearance. My approach is to use the paper pattern pinned to the cloth as a guide for the seam locations. Here is the reverse side of the seam.
This is the completed sail. We realized through the testing that the sewing machine needle perforates the paper, so it should be easily removed.
This is the reverse side from the paper.
As you can see here, the sections of the paper are easily removed because of the perforation in the paper made by the needle.
That’s it for this post.
I made an extra copy of the sail patterns when I made the original copy, so I was able to use those to overlay the sails. This allowed me to determine how I would handle edge, and also to locate the position of each eyelet. I decided that I would try to make a finished edge on the sails. To do this I would need to allow enough extra around the edge of each sail to allow it to overlap twice. The drawings show a 3mm edge, so I cut the edges 6mm from the edge of each sail. My wife helped me a great deal with the sails and after we worked with a couple of the sails, we realized that 6mm wasn’t enough, but by then the cuts had been made (measure twice, cut once sure applies here).
I used a product named Stitch Witchery. This is a bonding web for fabric and can be purchased in various widths. It is a polyamide fusible bonding web material that is heat activated. We cut it to the correct width, placed it between the fold of the sail fabric, placed a damp cloth over it and ironed it. I think it is much superior to trying to glue the fabric because it allows you to have just enough bonding material to bond the fabric, with no permeating into the cloth.
Here is one of the sails completed.
I wasn’t really satisfied with it. I believe we cut the edge too tight, and consequently it was very difficult to keep it straight. Also, the bonding material appeared to shrink and pull it in in some places. This experience to file away and use on the next build. Here are all of the completed sails.
I turned my attention to the eyelets. The issue with this kit is that the eyelets are very tiny (~1-1.5mm). I think I need a 1mm tool to set them, but if that tool exists, I can’t find one. As a compromise, I purchased a 1.5mm tool. This tool has to be inserted into the eyelet and hammered. My preference would have been to find a plier type setting tool, but I wasn’t able to find one for this size of eyelet. The setting of these eyelets was not a good experience for me and I was not pleased with the quality of my work.
I spent some time trying to find information as to the procedure for setting the eyelets. I was not able to find a great deal of information on MSW. There are plenty of comments about eyelets and pictures, but practically nothing on setting them. I did numerous Googles just trying to find some guidance but didn’t find much.
I used the extra patterns to overlay the sails and mark the location of the eyelets on each sail. I didn’t make any pictures of that process, but I started by make a pin hole in the center of each eyelet location. Next, I used a sharp pencil to mark the cloth with a dot beneath each pin hole location. I have a soldering aid tool that has a chisel on one end and an offset awl on the other. I found I could place the sail over some hard cardboard, and use the awl end to punch a hole at the eyelet location. I would set the eyelet in the hole, turn it over and then use the eyelet tool to hammer the end. The I would use a small hammer to flatten it the rest of the way.
I had a lot of issues due to the setting tool being a 1.5mm size, and some of the eyelets did not collapse evenly. Once that happened, I had to remove the damaged eyelet and set another one, sometime damaging the cloth around the hole. The kit came with 138 eyelets, and the sails required 115. When finished I had 3 eyelets left over.
My next step is to attached the rope around the edge of each sail.
I’ve been purchasing all of my rope from Syren. Not knowing how to estimate it, I’ve had to order more 3 different times. It’s a bit expensive so I was trying to optimize it with each order, and I probably spent too much on shipping trying to do that. I’m using tan and brown rope, mostly 0.45mm diameter. As I began seizing around the blocks, I used some thread that I found at Hobby Lobby for the seizing. That thread matched somewhat, but it had a bit of a gloss to it and it just didn’t match well enough to suit me.
The 0.45mm rope is made from 3 threads twisted together. I realized that I could untwist the rope and separate the 3 threads, then use that thread for seizing. It appears to be an optimum size, and the color matched perfectly to the rope you are seizing. Here are a few pictures of the first step of untwisting the rope.
Once it is separated, it still has a twist in it as you can see in this picture.
I found that if I would pull the thread through bee’s wax several times it begins to take the twist out until it is relatively straight.
The down side I found is that it loads the thread up with wax, which in turn makes it somewhat sticky. That makes it a little harder to work with, but the results are still good. I began the process of stitching the rope to the edge of the sails. I used 0.88mm rope for the edges of the sails. As I worked through this, I separated the 0.45mm rope into threads, pulled it through the was until straight, and just sequenced through the stitching in that manner.
Here are the sails with the 0.88mm rope attached to the edges.
I ordered some additional .045 rope from Syren. I was selecting the rope I noticed they offered 0.20mm rope. I decided to include that in my order because I thought it would be a better choice for seizing the 0.45mm line I’ve been using. Once I received it was the correct size for the reefing lines. I proceeded to use it for the reefing lines on the mainsail, foresail and staysail.
Here are the finished reefing lines on each of the 3 sails.
Once that was complete, I began rigging the mainsail. Here are a couple of pics showing the progress.
Here is the finished mainsail.
In the process of working around the rigging and sails, two of the chain plates on the starboard side have come loose. Looking a little closer, it’s the same problem I’ve had before with the fatiguing of the white metal. I anticipated this and ordered some brass strips of various widths a few weeks back. I fashioned two replacements from the brass. It was so significantly easier to work with and I have now replaced the two failed chain plates. Now I will turn my attention back to sail rigging.
Tuel,
Awesome work with those sails - well done indeed.
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Thanks md1400cs!
I continued the rigging of the sails.
Then, I had a significant setback. I turned my chair around and the armrest caught the edge of the ship, and off onto the floor it went, bow first.
I haven’t worked on it for a over a week. One step forward, two steps backwards. I’ll start repairs in the next couple of days, but still pretty frustrated.
OUCH!  those kinds of mistakes are the most annoying, because they are so preventable. I think that most of us have been there maybe more than once -
Looks very fixable  - had it been the main mast that would have been ¨¨©˚øøˆ¥†ƒ
Under the table:
Completed:
Vasa-Corel -
It’s been a little over a month since I last posted. I took a hiatus from the build after my crack up I showed in my last post. I’ve posted in the past that we also plant a large vegetable garden and we’ve been picking and canning vegetables the past several weeks, so there really wasn’t much time to work on the ship. I’m back focused and have progressed on rebuilding the bow area. Here are a few pictures.
I’ll re-rig the bow area over the next few days and then continue with mounting the sails.
I continued with rigging the repaired bow.
I left some of the rigging below the bowsprit loose so that when I added the jib sail I could tighten them simultaneously with the rigging on the jib sail.
Here is the jib sail completed with the rigging tightened down and secured.
I’m now cleaning up the loose rope and will then mount the staysail.
Tuel,
Your sails are very nicely made! Ive never attempted hand made sails but i think i might on my current build. Thanks for the quick tutorials!
Bradley
Current Builds:
Flying Fish - Model Shipways - 1:96
Future Builds:
Young America 1853 - Scratch Build - 1:72
Completed Builds:
HMS Racehorse - Mantua - 1:47 (No pictures unfortunately)
Providence Whale Boat - Artesania Latina - 1:25 (Also no pictures)
Lowell Grand Banks Dory - Model Shipways - 1:24
Shelved Builds:
Pride of Baltimore 2 - Model Shipways - 1:64 (Also no pictures)
Thanks Bradley!
After cleaning up the loose rope and securing it to the various cleats, I mounted the boom to the staysail and installed the rope around the boom.
Next, I rigged the staysail onto the mast and installed the rope to secure it to the main mast and the bowsprit.
Next, I installed the brass rings on the upper part of the staysail.
Here are some pictures with the rope completed around the staysail.
Once the staysail was mounted, the last thing two things left were to paint the stand, and to make an American flag that was accurate to the 1851 timeframe of the ship (with 31 stars). The flag included with the kit was not acceptable. It a Betsy Ross flag (13 stars) from 1776 and does not look the least bit realistic. It’s hard to understand why Mamoli would not consult the history books and know this flag was not accurate. The flag included in the kit looks to be screen printed with high gloss cloth and ink and is only printed on one side. Very poor example.
I began googling to try to find an accurate, properly sized flag that could be purchased, but just couldn’t find anything to suit me. From there I began researching methods to make my own flag and have found a method that I know I will use over many times going forward. I found the method I used in a post on Sept. 25, 2017 on the Model Ship World forum by member Chuck in his build log for the HM Cutter Cheerful. Another member commented on his flag and asked how he made it, and that is the method I used on mine.
For context, I’ll repeat it here. The flag is made from the tissue paper you use to pack boxes or maybe a gift. Many people use this as filler in gift bags. Its white, and is very thin. My wife keeps boxes of gift paper and had some of this tissue paper so that is what I used. I made a PNG file of a flag I found on line that is the 1851, 31-star flag. I did a screen print and saved it to the clipboard, and then I used Microsoft Paint to resize it and clean up the edges. I determined the size I wanted through several test prints using an HP 7150 ink jet printer. I printed it on 24 lb paper so that it would be a little stiffer than normal. I determined the size I would use by measuring the flag provided in the kit and used those dimensions.
After printing the flag to the size I wanted, I cut a piece of the tissue paper about ½ inch larger on the sides than the size of the flag, then taped the piece over the flag image on all four sides. I reinserted that sheet into the printer and reprinted the flag. I let it dry for a few minutes and trimmed the tissue paper very close to the edge of the flag, with no white space on the edge. The tissue paper is so thin that the ink will soak through to the other side but not entirely. I then immediately sprayed the reverse side with Krylon Matte Fixatif (which I had purchased at my local Hobby Lobby). Per the post by Chuck that I am referencing here, you should not be afraid to spray too much. This facilitates the ink soaking through to the back side further and it will look like it is literally printed on both sides. Then after it dries flip it over and spray the front side.
Next you can shape it to suit, perhaps using various size dowels. You can also spray the fixatif more to really soak it because this makes it easier to shape...you can do this several times if need be. Once dry it holds its shape. Next, I placed some tape (I lapped the tape so that is was maybe 1mm x 2mm) just over the corner of the flag on both side to hopefully strengthen it a bit, then punched holes with a large hat pin to thread the halyard rope through.
So, I now come to this point where I can now say that I am finished. Here is a picture from yesterday with the stand not painted.
Here are some subsequent pictures from different angles after painting the stand.
I’m thinking I’ll do one more post in a day or so and maybe list some observations and lessons learned. I’m glad to get to this point and looking forward to my next build. As soon as time permits, I will post pictures of the finished ship in the gallery. Thanks to everyone who followed my build log and commented.
Beautiful ship and model.  I always loved this story about the original race.
 Legend has it that while watching the race, Queen Victoria asked who was second, and received the famous reply: "There is no second, your Majesty."
Beautiful model, well done!   And thanks for putting all the work into explaining what you have done, particularly with the sails.   One of these days I really need to get back to mine, and these posts provide some inspiration.
  • 11 months later...
  • 2 years later...
This has been done beautifuuly. I have one query before I fit the bowsprit on my own model. All illustrations of the time show a simple bowsprit without a dolphin striker or "jig boom". Other firms models have only the simple bowsprit. Where did Mamoli get the idea of a more involved set up, which was not uncommon on ships of the time?
Mike
