Hello Johann,
thank you for the complement and all others for there likes.
Yes the holes are drilled in on the model and then I glued the copper bolts in with CA glue and filed them flush.
Regards,
Siggi
Recent build: HMS Tiger (1747)
Gokstad ship (ca900) scratch build
Captains Barge ca. 1760, scratch build
HMS Dragon 74 gunner 1760, scratch build
Hello Aviaamator,
at the rudder the pins where soldered just into the 90° bent of the arms
5ae5a5f796d96_Bildschirmfoto2018-04-29um12_59_01.thumb.jpg.6f447a9572c7be02e14da583985118dd.jpg
and for the brace I bent a short piece of brass to an U and soldered it to the arms. Then I bored a hole, slightly larger then the pin, in it and ready. I hope that this was a help for you, even with my not so good english :(
5ae5a5fbf0867_Bildschirmfoto2018-04-29um12_59_37.jpg.8d1590f2b020be9e2ae5ef445ecd7c7d.jpg
Edited by Siggi52
Regards,
Siggi
Hello,
today I finished the lower counter.
The only thing left here, is to cut the mortise for the gun port lid into the rail.
Regards,
Siggi
I'm glad I found your build before you are finished, or nearing the end as I did last time, Siggi. You didn't loose your touch after a year ... I think you even got better! I will enjoy your build from the side line
Carl
Siggi,
the planking of your model ist just perfect ! (spitzenmässig )
I took this opportunity in looking back to the early stages of your hull-building and am mighty impressed of your build and your skills.....
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
most excellent planking!
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                           Iron Clad Monitor (complete)
                           Sardine Carrier which I will Name Mary Ann (complete)
                           Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
                           Light House Tende Beech (complete)
There is the frame of thought that supposes that, if five people all build the same model to the same plans - then you are very likely to see five very different models.
While I believe that to be true, Sigi, I think your discernment brings you closest to the truth; a fantastic build in subject, form, material and execution.  For me, it’s all about the lines, and your lines look true to me.
Hello,
after I had to do some other things then shipbuilding, here now an update. I painted the under water ship.
Before I go on and build the upper part of the outside ship ready, I must build in the gun deck and made the inner walls smooth. But then the slots for the over head stand will get lost. So I painted it now.
In the first picture I made the water line horizontal.
Regards,
Siggi
Hello Steve,
you could ask questions and I should answer them with my poor english :(
Ok, it was a 1,5 cm broad mink hair brush. Hopefully that this is the right term for it. But I made several layers, I think 4, of diluted paint. But even then you could see different shades. Especially in the yellow areas. That would be a real challenge above the wales with all the gun ports and riggols.
Regards,
Siggi
Whatever inconsistencies there may be in color tone, they don’t show in the photographs.  Though these are diluted wash coats, I would think the color would even out after a certain number of applications.  If not four wash coats, maybe 6?  Perhaps, also, making up a large enough batch of diluted paint to do two to three wash coats from the same batch, might improve the consistency of the color.
Hello Hubac's Historian,
it is't so bad, but you see different shades in the color. But even when you diluted the color, in the corners the color build up piles. So you have to stop it someone. I will let the ship now dry for a week and see then what to do next. I think, when I'm ready with the antic finish ore aging it a little, you would't see it no more. At least, I think that the original ships where not so clean painted then our models today.
Regards,
Siggi
Yes, I can see that aspect of your dillema, now - the accumulation of color in corners and how that would be especially apparent around the rigols, for example.  It seems to me that the antique wash coat will help a great deal with that issue, and I like that you will “dirty” her up a bit, as anything that goes into the sea does not remain pristine for long.
Hello,
thank you all for your kind words and likes.
During the paint on my ship is drying, I went to Hamburg and visiting the „Maritimes Museum Hamburg“. There I saw something all of you with the problem, where to store all these models, would be interested. Next we build all smaller models. These are may be 3-5 cm long!
Or if there is space enough, a diorama. This one is from Helgoland in the 19. century. The ships are not really larger then the one before.
Regards,
Siggi
Hello,
because we have here the best weather since years, I haven't been much in the basement at work, but more in the garden or at the house.
I did a lot of painting and dirt finishing the last weeks. So the ship has now a vintage look. ;)
Yesterday I started to remove the old false gun deck and build a new one from 0,8 mm plywood. That looks now much better.
I thought that I would first build the gun deck mostly ready, before I start to build the outer surface of the ship. So that I would't damage so much there when diving into the ship.
Interesting in this case is, that the ships plan and the plan of the gun deck are not fit in all parts together. So I stay with the ships plan.
Regards,
Siggi
Hi Siggi,
the Tiger looks great, wonderful the figurehead, the lines of the ship, and now your new deck !
I also like the small self cast cubic lead weights you made....
Nils
Current builds
-Lightship Elbe 1
Completed
Hello,
thank you Nils for your kind words and all others for there likes, they are very appreciated.
Today only a small update, I build the gratings for the hatches. After such a long time I build them the last time, I had to think a lot how to do it. But at least I got it.
Regards,
Siggi
Hello,
for the internal works, I managed to get the old team from the Dragon again to work. And I think they did a good job.
With the hatchway to the bread room I have a problem. How was it made? All other hatchways have a rim, so that water would't run in, but not this one. See also the original plan. Was it closed with solid lid, or a grating?
At least the whole ship with its masts. In the foreground are laying the planks for the gun deck.
Edited by Siggi52
Regards,
Siggi
The scuttle (rather than hatchway) to the bread room was a lid in two layers. The top layer is the thickness of the deck plank, then a thinner lower layer running crossways and narrower all round, providing the lip. There are two ringbolts on opposite diagonal corners for lifting the lid.
Thank you Druxey,
then I could make it even with the deck. At the plan for the 1745 establishment they have two scuttles, one larger so as you describe and one as for the ladys hole to the left.
Regards,
Siggi
