Hello Edwin, welcome aboard.  Congrats on acquiring the Morgan.  It's fun to build.  Hope you'll start a build log.  I highly recommend and encourage you to do so.
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Today's progress is that I have re read the tutorial on coppering the hull, sealed the lower hull with Sanding Sealer.  From all I've been told this is a very important step in assuring the glue on the copper tape sticks to the hull .... and not your fingers.  I might try to get a little copper tape on the keel and mark the rivets on the copper.   For reference, I'll try to document the coppering process for interested parties, with perhaps more pictures than so far have been available.   I have also started some work on the windlass and will probably get it mounted later today.  Not sure if I'll work on the coppering until I'm on the road or not.  Looks like a few days yet before the RV is repaired, so I might be able to sneak in some work on it.
John
Started working with the copper.  Those of you that are beginning to know me, will understand that I couldn't wait to go ahead and dig in.  So I practiced with the pounce wheel making rivets on a 3-3/4" strip of copper.  The sheets are to be 3/4" x 5/16".  The copper is 1/4", so the overlap should make it just right.  So at 3/4", I get 5 plates out of 3-3/4" strips.  Well it wasn't too bad. So, checking that the sanding sealer had dried sufficiently I lightly sanded any bumps away and attached the first piece of copper strip on.  I thought about 6" strips, however, the 3-3/4" is easier to work with since it is so thin, and has a mind of it's own once the backing is off.  I learned quickly to keep my fingers off of it or then it won't stick to the hull and essentially becomes useless.  Here's some pictures for anyone interested.
John
Sealed hull
John
Ran the port side keel line first.  Will cap it later I think.
John
The first 4 rows of plates are on. Working with the thin foil is tricky as is spacing. Trying very hard to maintain a brick pattern and it also gets tricky. It' better as you move away from the keel. The joint where the keel and the hull planking come together is difficult in that there is also a bend in the plateto follow the hull lines. With some work I think it is acceptable....at least I hope so. Not perfect but not bad.
John
Looks like you're off to a great start John.  Get your sunglasses....she's gonna dazzle like a new '57 Buick Roadmaster when you're done.  But it darkens with time (years!).
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
For reference, many of these strips have been 3" strips and I've started marking the center of the brick pattern, prior to printing the rivets on the plates.  This is an attempt to maintain a brick pattern, and keep these plates not only overlapping properly, but to line up properly.  The plates vary a little in size, but seem to be getting the correct (or close to it) pattern.
John
Hi Augie, thanks man. I'm trying to decide if I want it to tarnish over time, or to spray it with a clear coat. I guess I haven't seen enough of the natural aging finish yet. I do like shiny copper though, kinda like shiny brass or better yet gold! This is open for interprettion by anyone wishing to chime in. Got a ways to go yet before I have to make that decision. I do like good crisp finishes though. Meanwhile Augie, I've the sunglasses on it gets bright where I'm working on it.
John
By the way Augie, when I got my first car at (13), my dad gave me a choice of a '57 Chevy 283 2 door hard top or a '62 Chevy Belaire  2 door bubbletop, 409 2-4's, 4 speed, I chose the 62.....either car would have been incredible, but the 409 was a fine choice.....got lucky wish I still had it....they are now rare antiques....I wonder if that makes us rare antiques.....don't know about rare, but definitely an antique!  the Buick's were lot's of chrome!  Memory lane again
John
I had the '56 Chevy, John.  Cream over Adobe Bronze (just don't ask what I had for dinner) :D  :D
Chuck P. used some kind of suntan lotion that worked well for him.  But I forget the brand and it was lost in MSW 1.  Others will probably suggest other aging methods.  I'm leaving mine alone and it is darkening.  Should be perfect by the time I keel over.
Augie
Previous Builds :
Hi John,
You're doing an excellent work on your C.W. Morgan, she's coming along beautifully, your paint job and coppering look really crisp.
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Wow, I miss a few weeks and your almost done....
She so fine my 409. I loved the valve covers on the old 409's. 1962 was a Sweet body style also. I had a 65 Buick Riv GS with the 425 nailhead with 2 carter AFB's. Love those old muscle cars and the torque of a big block. The 4 mile per gallon, not so much....
I can't believe how fastly you've put her together, she looking great. Keep up the great work.
PS. the sopwith hit $199 at ME. If it gets to $175 I may not be able to control my other self :)
Augie, my 62 was that Champagne Bronze color.  Big tank of a car, but fast.
John
Thanks Aldo, welcome aboard.
John
Hi Keith, where ya been? Yes miss a week or two and I'm still progressing...I think. The old 409 was fun. Had 2 AFB's also. My next car (which I still have) is a 67 Plymouth GTX which I just finished a complete Concours restoration on. Got 2 Edelbrock AFB's on it with a bad cam. I might start showing it. (1 of 2,000 made by Chrysler that year). There was a Sopwith on eBay about a week ago that went for $125.
Here's the toys....no picture of the Bubble Top 62 in the computer. I have some old black and white's but haven't ever scanned them into the computer.
John
Updates have been slow the last few days.  The coppering is tedious and I wanted it to look as good as I could do it.  It was definitely a learning experience...trial and error emphasis on the error.  I do realize that it is one of the most important visual details on the hull so it has to look good.  This is not perfect, but I am satisfied with it.  I found I had to use Testor's Green glue for Wood & Metal models.  I'll include a picture with my next series.  By putting this on the hull it prevented the lift caused by finger oil or wood imperfections and down right buggering it up with clumsy fingers which I am notorious for.  The glue stopped all of that.  So with further adoo,  here is the port side, which now leaves the starboard side tomorrow.
John
The start of the starboard side
John
looking good John!  it should dull down with time ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
John, great work on the coppering!  Looks great,  will definatly dull up a little with normal wear and get a nice patina to it too.
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Thanks Augie, I'm glad you like it.  Your pictures in your early log really helped me.  I consider you, Grant and Mark mentors, and I appreciate all your pictures and help and encouragement.  One side to go and I can move on to the deck fixtures, buildings, etc.
John
Thanks Popeye, I think I might leave it alone and let it take a natural color.
John
Thanks Adam, I appreciate the kind words.
John
OOPS, I almost forgot Sjors as a mentor also.....sorry Sjors....trying to make up here.....
John
Great job on the coppering John - looks fabulous!
As for forgetting Sjors - simply not possible, much as you might try!!! :P :P :P
Sweet coppering, John.
Hi Grant, you're right ..... can't forget Sjors...that would be like being lost at sea without a compass....
John
