Ilhan, what a beautiful hull, such lovely lines.
A very elegant ship and very clean work.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Ilhan, that is very nice detail.  Thanks for posting the sequence of photos showing how you you are doing this.  I assume you will be bending the davit arms to a curved arc extending outboard at some stage.
I am following with interest as I need to do something very similar at scale 1:72  and you are showing what can be achieved.
cheers
Pat
Ilhan, Happy Holidays to you and yours and a Happy New Year.......Keith
Impressive work.
How did you make the wire eyes so small? Do you have very fine nosed pliers or did you use a different method.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
cheers
Pat
That's right Pat.
17 hours ago, KeithAug said:
Impressive work.
Thanks Keith, I did use a fine nosed plier, bend the brass wire around 0.5mm drill and pressed tight, cut again with a fine side cutter.
I wish you a happy new year.
  • 4 months later...
Painting of the hull is finished. I used Tamiya acrylic paints and an airbrush Badger 100 LG.
Edited by Ilhan Gokcay
Beautiful hull, Ilhan. Great to see a update.
  • 5 months later...
I'm going slowly on. Glued the rail made of 1mm pear strip and planked the forecastle.
Ilhan, great to hear from you, beautiful work as always.
Beautiful work, Ilhan.  Just a joy to look at.
Beautiful hull - impressive.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
  • 8 months later...
Beautiful work Ilhan,
I love your build log all the way from beginning up to present status. Also very good Photos.  You`ve done an excellent job on the white/red waterline. Am looking forward to the next sequences to come.
Nils
Current builds
-Lightship Elbe 1
Completed
  • 2 years later...
 Ilhan, glad to see you back working on the Loreley. Lovey work as always.
Wonderful to see this build back after a long absence. Good to see your skills have not suffered as a result of the layoff.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
