 Each new post is a delight, Ilhan.
Beautiful rials.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
30 minutes ago, wefalck said:
Nice clean work!
How did you do the profiling of the roof, with a router, or by scraping with drawplate?
Thank you Eberhard.
Roof is from tree seperate sheets glued on top of another. I only shaped the edges by sanding before joining.
2 hours ago, Ilhan Gokcay said:
Beautiful work Ilhan,
I love the techniques you are showing on this build. Very nice painting job, Also great, the aft grating....
in all an amazing build !
Nils
Current builds
-Lightship Elbe 1
Completed
10 hours ago, Ilhan Gokcay said:
Engine/Boiler room house/casing. Polystyrene on plywood.
Beautifully clean work IIhan. What glue did you use to bond the plastic to the wood?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks Keith,
I used rapid epoxy glue for the roof parts (not for the plastic to plastic) and CA Gel for the side panels.
Engine room house and funnel.
Trying to build the funnel I was very lucky to find a plastic tube with exact diameter.
Edited by Ilhan Gokcay
That looks so good Ilhan.  I now have to go back and possibly adjust the funnel on my Victoria as I didn't even think on hand rungs to climb the funnel.
Great seeing more of your quality work.
cheers
Pat
 Super fiddly work on the skylights and they turned out beautiful, Ilhan.
13 hours ago, wefalck said:
'Normal' people would use PE, but Ilhan has to do all by hand 😲👍🏻👍🏻
Thanks Eberhard, 1/75 is a very difficult scale for this ship.
If it was 1/100, PE would be ok, but not at 1/75. It would look like a bit simple.
On the other side if it was 1/50 it would be much easier to make these parts. I did not realized this in the beginning. So I'am struggling as best as I can.
 I wish my struggles were as successful as yours, Ilhan. You're doing amazing work.
Been enjoying your log....and I must say...you produce some of the finest quality work, I have seen.
Great job.
Rob
Current build:
Finished build:
Current build(On hold):
Just amazing work on those skylights.
Rob
Current build:
Finished build:
Unbelievable meticulous gorgeous work, Ilhan.
