After a false start in which I snapped off the bow extension when removing the bulkhead former from the sheet!  Things seem to be going well now.  The two sections of the bulkhead former were glued together and the rabbet strip glued in place.
The stem pieces and the keel  were sanded on their faces to remove laser car but the edges were left unsanded.  The treenails were simulated as described by chuck using a 0.5 mm drill and filling with neutral filler.  After a coat of wipe-on-polly they were glued to the bulkhead former and fitted well with out the need for fettling.
As recommended by Chuck no laser char was remove from the bulkheads and all fitted firmly.  Care was taken to retain each one square in all directions.
The bow and port filler blocks are added.
Next comes, for me, the challenging process of fairing the hull correctly
I think I have a way to go yet but trial battens are beginning to look close. I am taking a rest now.  I think patience is the key here I am a little concerned about taking too much of the stern as others report it getting too narrow here.
John
Edited by bartley
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Schooner for Port Jackson
Looks like a good start.  It will be nice to see another addition to the Cheerful fleet.  I look forward to following this build log.
Ryland
               - Nautical Research Guild
Hi John,nice to see another Cheerful being started. Blue Ensign has an excellent build log in the kit build log forum here on MSW. My own build is almost finished,scratched except for the windlass and guns. I will be following your build also.
Dave :dancetl6:
Unfortunately there are lots of photos of this step but obviously good planking depends on this step being correct.
Test battens seem to sit flat on most bulkheads but it is a bit proud at the bow.  So I thought I needed to take bit more of the marked bulkheads.
Obviously it is difficult to see how good (or bad) this is without seeing the actual model but this is the best I can do at this distance
Edited by bartley
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Post 4
I have now finished the Gun-port linings.  I used the method recommended by Chuck using a batten to obtain  smooth curve.  Although I eyeballed  the port and starboard battens to make sure they were the same.  I also double checked by using a level as here:
Edited by bartley
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
A word of warning.
Chuck warns about this later with respect to the stern ports but it is also important to make sure that all the gun-port sills fit snugly.  If they are a fraction long they will push the bulkheads out of square and negate all of your careful fairing because it changes the angle.  This happened on a couple of mine but fortunately I noticed the bulkhead move  and so took a little off the sill in question.  It doesn't take much.
John
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Post 5
Framing the Stern
Following Chuck's suggestions, I first glued in the main outer frames (z)
Then the outer frames themselves (zz) are glued to these:
And the whole assembly faired to match the hull:
After installing the central frames, the gun-port sills and lintels were installed.  As reported by others, I found this step surprisingly tricky and I had to un-glue and reinstall several times!  I used a level and a sized block to ensure that each was level with the waterline and sized the same:
Here is the result
Edited by bartley
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
On 2/21/2019 at 11:13 AM, bartley said:
Stage-9.thumb.jpg.ebd123d7dd5bdb77e3c87604508cb3c7.jpgPost 5
Framing the Stern
Here is the result
Post 9
Wales and Molding Strip
The red that I am using here is Vallejo Flat Red.  .  Synthetic dies and bright colours were not developed until 1856 and even then they were expensive.  So the paint at this stage would have been red lead - cheap but effective. I feel that this colour is close to the red lead paint we used on our barns when I lived on a farm as a boy.  I dilute the paint down considerably with 50:50 Vallejo thinners and deionized water and then apply about seven coats.
John
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Post 10
Planking above the wales
Planking up to the Molding strip was straight forward:Stage14.jpg.2abe3df618b36390958adca14de4e6ed.jpg
However planking around the gun-ports was tricky (for me at least) and took some time. However it is a nice little feature once done
Previous builds have involved continuous planking up to the sheer and then cutting the gunports into those planks an lining afterwards,  Chuck suggest that the rabbet should be 1/64 ‘’.  This is 0.39 mm.  I was not confident I could do this consistently so I made mine 0.5 mm.  I also found that for the fairly constant gaps amidships pre-making a set of planks  helped me to get the rabbet parallel to the port.  This is not my idea and I must  thank Rafine for the suggestion:
So here is the result:
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Chuck,
I obviously need to sand this back quite a bit to level up the planks but I am not sure how aggressive I can be here.  I am used to double planking where a bit of bog can be used to help but this is a new world.  I guess 3/64 is quite thick and any deviations are only a few thou.
John
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Post 11
Planking the Stern
First the outer frames had to be thinned down.  Pretty scary this!
Then the actual planking.  Planking the counter was OK.  I had more trouble with the transom.
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Chuck,
I have been experimenting with some treenailing above the wales.  I have a couple of questions>
Between the bulkheads I find I am drilling right thru the plank.  Presumably this is Ok since it will be covered by the bulwark planking?
Secondly: How do you avoid filling the caulking line between the planks?
Edited by bartley
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Post 13
Chuck suggests adding the second layer to the Wales at this stage. However, others on the site have suggesting added the next two layers of planking first and so I adopted this course of action.  I found the drop plank a bit tricky to fit but after several paper patterns I developed a better understanding of what the shape should and I am now satisfied with the fit.
Edited by bartley
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Post 14
Finishing the wales.
The second layer of the wales was added and painted black.  I painted the edges first as I was not confident that I could do this afterwards and not get paint on the planking.
Edited by bartley
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
Post 15
Lining out the hull.
I did this several times but in the end the difference between the various versions was only around 0.5mm.  There seems to be no tapering required aft of about bulkhead B.  I hope this is correct!
Medway Longboat
Completed Builds:
Concord Stagecoach
HM Cutter Cheerful
Royal Caroline
