15 hours ago, Old Collingwood said:
Oh - and the bombs need painting
HArdly worth the trouble if you throw them out anyway ;) Like those bomb doors, and the entrance with their small looking glasses
Carl
I'm thinking of writing on the side of them  "loo rolls inside"🤪
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
45 minutes ago, kpnuts said:
That's a super looking build mate.
Thank you Kindly KP.
OC.
Current builds
Completed works.
Yeah for the after action resulting from the actual action....
Quote:
19 minutes ago, Egilman said:
"loo rolls inside"
What else would you put on them? After all they are, "Bomber Poop".
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
More progress this evening  -  I Painted and fitted the entrance ladder  - fiddly to fit  upside down  and get the drop right,  next I fitted the prop/spinners,   she is coming on  just a few touches left to do.
OC.
Current builds
Completed works.
16 minutes ago, marktiedens said:
Looks ready for take-off:D.
Thanks Mark,
OC.
Current builds
Completed works.
2 hours ago, Edwardkenway said:
Quite business like now! Looks great OC
Thank you Edward.
OC.
Current builds
Completed works.
Hi all,
After having our first walk out today  walking the dog,  I decided this eve to attack the aerial and  comms wire, the idea was to drill a tinny narrow pilot hole in the front edge of the tail,   (not the easiest operation)  - so right,   I tried it but combination of not being able to see what I was doing and tiny hand drill bit drifting  - result  a few scratches where the bit had drifted,  eventually  a pilot hole was made,  next job was to push the end of a piece of fuse wire into the hold and add a bit od ca to hold it, then I glued the PE aerial put a pool of CE around the base and heated it with hairdryer.
Then I tried to pull tight and glue (again with CE)  the wire to the aeriel   - but this was a fiddly  not very sucessful  operation  so I gave up  cut the wire away  and just left the aerial in place to set.
So I have given up on the idea of a comms wire  and have marked the tail a bit  (never mind)
OC.
Current builds
Completed works.
First steps into weathering OC ;)
Carl
Yep,   one of the ERK's  threw a rather heavy hammer at the tail.
OC.
Current builds
Completed works.
3 minutes ago, cog said:
Flew under a low bridge ...
Landed on the back of a low loader and drove under a lowe bridge.😁😁
OC.
Current builds
Completed works.
So,   tomorrow I must paint me Bums.😆
OC.
Current builds
Completed works.
Just now, Javlin said:
She will make the grade OC ;) Kevin
Thank you Kevin.
OC.
Current builds
Completed works.
Good day all,   next stage in the Mossie saga  - 500Lb painting,   first I had to mockk up  some kind of frame work  to allow me to hold  and spray  - best I could come up with  Peggy and Springy, I will paint this way then when dry  spray the  other end.
OC.
Current builds
Completed works.
5 minutes ago, Landlubber Mike said:
Love the Peggy and Springy - I'll have to try that sometime :)
They did start to complain but I said  "shush  or I'll  spray you"😀
OC.
Current builds
Completed works.
Just now, Canute said:
Hey, they work. I use them like that all the time.
Plan is  - when dry  hold them from the other end  (protected with some tape)  then spray the un-painted ends.
OC.
Current builds
Completed works.
Facinating video on Mossies  curtosy of my friends  over at The Peoples Mosquito.
OC,
Current builds
Completed works.
More words  - no pictures  (I know  - boring)    so  after letting the 500 pounders dry - the one way up,   I worked out a stratergy  -  sit them nose down (painted ends)  in blue tak   on a  block of wood then just spray the  tails.
Just had enough pain to do the job.
OC.
Current builds
Completed works.
A bit more  weathering on mossie,   the aerial  broke away  (I hit it with my brush)🙄   so I glued it back down by making a puddle of ca, aerial  not looking too good  - but it is what it is,    so I'm calling the airframe finished  - just waiting to fit the bombs  when thay are done.
Got a few pics for you ........
OC.
Current builds
Completed works.
Interesting view looking up the hatch into the cockpit. Nice work OC.
How much pain does it normally take?:D
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Upss, I dropped me T   dont tell the admiral  she loves Tea.😊
OC.
Current builds
Completed works.
One fine looking bird brother....  sure looks the part...  The shot through the access door is a great one...
Thank you for sticking it out...... it is a treat...
EG
Quote:
