Hi Aldo
Thank you.
Yes, I’m looking forward to that great feeling (I’m not yet there by about 30%) but…
…afterwards waits the dreaded sail making which is even more cumbersome with the stitching on of the bolt rope by hand.
But I forgot – I’m doing this by my own free will!  Aren’t we jolly masochists, altogether? :blink::wacko::)
Cheers
Peter
Well Aldo...
While working on the ratlines of the main topmast I realized that I forgot the jeer blocks for the main yard. Fixing them after the topmast shrouds required something like a minimal invasive operation. And…
...promptly I broke off the top of the completely rigged mizzen topmast. After some censured expressions (no fun) I fixed it with epoxy glue and a 0.5mm brass wire in the center of the mast. It’s hardly visible (except for a very slight bend) and I hope it will hold.
Lashings for the starboard jeer block
Both jeer blocks in place
Pleased to know you've fixed the mizzen top mast successfully Peter, it should be pretty strong once all the standing rigging is in place. Your top mast looks magnificent Sir, excellent detail work :)
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Hi Frank
Thank you. I’m still waiting for some barnacles to grow on Pegasus but perhaps its too dry. ;)
Cheers
Peter
Hi Aldo
Well, thank you – but that topmast looks a bit ‘minty’ and I’m not yet sure if it has to be replaced anyway after all…
Cheers
Peter
Edited by flyer
Nice shots of the masthead Peter, looks very business like with the jeer strops, shrouds and stay collars all in place.
The use of a long tackle block in a span for the lifts is indicated by Steel,(1794) and is shown by Lees as being applicable between 1719 and 1806, but then somewhat confusingly goes on to say that from about 1760 the block was seized to an eyebolt in the cap rather than being fitted with a span. this seems to be the system favoured by Antscherl who shows a single block hooked to an eyebolt beneath the forward end of the cap.
I will also be going with a Long tackle block if only because they are a more interesting feature. :)
Sorry about the mizen mishap, I hope the jury rig holds, not too much stress on the topmast.
Cheers,
B.E.
Hi Andy
Quite well hidden, ain’t it?
Hi B.E.
Thanks.
Yes, James Lees gives the same information about the lift, but, as you, I like it better that way. (I pretend to have had a rather old fashioned bosun when fitting out Pegasus.)
And yes, I still have hope although it’s rather difficult to continue rigging work with crossed fingers. :unsure:
Cheers
Peter
Nice work Peter! I've been following silently for quite some time now and I thought I should let you know...  :) I was also wondering where you got those nice looking figurines of sailors, they do add life to the model.
I have my fingers crossed for your topmast...
Padeen (Adeline)
"When there is a will, there is a way"
Completed build: Le Camaret - Constructo - static wood 1:35  (build log, gallery)
Current build (very limited modelling time at the moment...): HMS Fly - Amati/Victory Models - static wood 1:64 (build log)
Projected build: HMS Victory - Chris Watton's design - static wood 1:64 (when available..., no rush!)
Bonjour Adeline
Merci.
I got the crew figures (25mm height) via       http://www.cornwallmodelboats.co.uk/acatalog/amati_crew.html
They come in cast metal in the raw and you have to paint them.
Cheers
Peter
Merci Peter !
I think some hobby shop lurking in will be in order this weekend...
Cheers,
Padeen (Adeline)
The main topmast is now fully rigged. Once again the principle of starting the standing rigging low and aft (at the mizzen) and working forward starting then again aft with the mizzen top mast proves its worth. That way you have access to the tops where you have to rig up stays and preventers.
Last work on the backstays
Foretop with stay and preventer
Finishing work on the foot of the preventer stay
Main topmast
:huh::(:angry: *@*!!#§* :o :mellow:
 While working on the main top mast the question about the stability of the mizzen topmast has been answered definitely. Not the way I hoped. First I thought about repairing the mast by ‘fishing’ it but the remaining length below the top was insufficient (this would have been an interesting project). Then while dismantling the mast I asked myself if I could save the cap and replace only the part above it mortising it with the lower part within the cap. But I thought this not stable enough and the cap was broken apart to be able to take out the lower topmast (the whole mast assembly was fixed with epoxy glue and cannot be dissolved without destruction). The remaining question now is if I should also replace the mizzen top according B.E. research with a larger one. This would be a lot of work and I will have time to think about it while making the new topmast.
Oh, I don’t believe in flying horses…
Oh boy, so sorry to see that.  That's been a big fear of mine with my build, particularly as I've already had my clothing catch it a few times - not to mention, going to the bathroom and coming back to find my cat batting the bowspirit  :angry:  Good luck on the repair.
Hi Mike
Thank you for your sympathy.
Actually the mast broke twice. First at the point where the hole for the tie for the upper yard  was – unfortunately I drilled it into the smallest part of the mast and it was perhaps a little too large.
The second time it broke again after trying to repair it with epoxy glue and a stabilizing brass wire in the center (centre?) of the mast.
Fortunately our cat is about a hundred years old, only sleeps and eats and walks slowly from and to the respective places – little feline danger for my ships.
Cheers
Peter
Hi Spy
Sure I’m interested and very much so. And I dare say quite a few more as well.
On Granado I tried the fully furled version shown here on the lower yards because that way I felt justified to leave off much of the smaller rope work like leech lines, bunt lines or reef tackles. For that kind of furling on those upper yards you’ll need at least also the buntlines.
The sail bulge on my yards is really still too large. I did use the finest cotton available but the full sail area. Next time I will try to reduce it by one third and adapt the shape of the sail accordingly.
Take care
Peter
That happened to my foretop mast also. I just cut it off at the cap and made a whole new pc. from the cap up , then I drilled the cap and pinned the new top in. So far so good still holding up . Hope your solution is just as easy. :)
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
I feel your pain Peter, hang in there mate and all will come good.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Oh my!  Peter, I just popped in and saw what we all fear will happen.  You've done some excellent work, and so that snap has to hurt.  But you'll definitely work out something that is at least as good.
Best,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Hi Frank
Yes I was thinking about your solution as well but after the first failed repair I opted for the hard way and am making a whole new topmast. I’m glad you did more stable work on your fore mast.
Hi Mobbsie
Thank you, I’m hanging in but still think it was rather superfluous of Mr. Murphy to prove his law once again.
Hi Martin
Well, now I’ve done it, I hope Mr. Murphy will be satisfied and we all will now have some peace from him for some time.
Cheers
Peter
Hi Spy
Thank you for the great pictures and for making me aware of a special place. The existence of that harbor and the fleet of sailing ships was news to me. Now there is a new location on my to-visit-list.
Cheers
Peter
How's the repair coming along Peter, I trust your well on the way to sorting it, with all the cuts, blood and other ailments being suffered lately old Murphy's been having a field day.
He's got a lot to answer for.
Be good
mobbsie
mobbsie
Next Build :-
Hi Mobbsie
Slowly but steady. Pictures will follow. And that Mr. Murphy...a British subject, isn't he? Tut-tut!
Hi B.E.
Thanks.
Cheers
Peter
