Placing the lower sills now, I took a couple of days to keep looking at and adjusting the battens first. I might still have pushed down when marking it (the batten wasnt pinned on every frame) because a couple of the sills are not on line with the other side; I think I may have to cut them loose and try again. Overall smooth progression though!
Scott
In progress: 1:48 HMS Surprise 1796 (DeAgostini/AL)
                       1:16 New Bedford Whaleboat (Model Shipways)
Parked:     1:48 HMS Winchelsea 1764 (NRG group project)
Finished:  1:48 City of Buffalo Lake Steamer 1890 (Dumas)
                   1:48 Lackawanna Steam Tug 1900 (Dumas)
                   3/16" (1:64) Kate Cory whaler 1856 (Model Shipways)
                   1:48 Puritan 1885 (Mamoli)
Sills are in and working on fairing them. One question- some of the top sills are higher than the bulhead ends, should I plane them down even?  I’m happy with progress so far and looking forward to the stern framing! Have test fitted them and may have more questions before gluing them in place.
cheers! ScottE860BE84-05B3-4E85-AA5D-261758282806.thumb.jpeg.2fe637e98546a5af13f2bda19bd530e1.jpeg03F4D777-0955-4A35-8DC9-A9C4FA932C7C.thumb.jpeg.8bcf5624aa0ac763ef2b89707dd73a92.jpeg
Scott
I would leave them as is until you take some measurements from the plans to confirm what is the correct height.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
 I second that
Mike
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
On 9/23/2020 at 6:38 PM, Stuntflyer said:
 I second that
Mike
Sounds good, thanks Mike and Rusty, on to the stern framing!
Scott
Stern framing-I thought it was going ok at this stage but a top view says otherwise.
 I think it will be hard to force the curve now, I guess my angling of the filler edges was off. Support for taking the frames out and trying again?
Scott
Ok, the sills and fillers are out without significant damage but it appears the frames themselves need adjustment. I’m surprised that the wood glue seems to pop off of the yellow cedar quite cleanly.
Scott
I’m feeling much happier now!
Scott
That looks much better!
Rusty
Second attempt at framing port side, I think I have a nice run of the cap rail now. I had to lower the last three gunport sills by a couple of mm to make it work. Still needs to faired in, and I’m going to redo the framing on the other side to make the angles consistent (the last frame is still too high and causes a bump on the cap rail run :( ).
Thanks for the kind words and encouragement!
Scott
Bollards shaping, not quite complete yet, still some traces of laser char, and the caps haven’t been sanded down yet. First try and I’m 99% happy with them!
Scott
And Chapter 1 nearly completed! Just need to angle the bollard opening and finish fairing the inner bulkheads. Mainly aft in the qdeck section. Time to start ripping some planks methinks!
Scott
Fairing problem at the bow. The very bow end of the first plank keeps breaking about 1/4 inch out from the rabbet. This is about as close as I can get the plank to the first frame without it snapping. Does that mean I should try to make the bow formers a bit more acute, so the plank comes into the rabbet at a slight angle? (not at 90 degrees to the keel).
Scott
Yes ....it looks like you need more fairing close up to the rabbet and stem.  More is certainly needed but you also need to pre-bend those strips properly.   It sounds like you arent using heat to bend these strips enough before they are inserted into the stem.
Its probably a combination of both those things.
Thanks Chuck, I watched your videos and this is the first time I’ve tried ironing in the plane of the plank. Here’s the pictured plank after I took it off, and its predecessor with the snapped end. So more bend in the plane? Plus I’ve adjusted the filler angle now.
Scott
Ok, this does seem much better!
Scott
More bending the other way....you need to bend it edgewise but also the more typical way at the bow which you see everyone doing.  I use a hair dryer for that if its needed.   Also not a twist if that is needed also.   Its very complex and you should experiment.
  • 4 years later...
IMG_6955.jpeg.0c63a6f391d8ceb582e5ca74d84caab0.jpegWell, it’s been over 4 years on the shelf, after a couple of disasterous falls onto the floor. The first one took out one of the stern posts, and I never found the lost piece. The second one, in the pandemic years, took out most of the fore frames and the stem.
IMG_6956.jpeg.c98e1b96fef3ebb8e8b4f348c96ac5a1.jpegIMG_6957.thumb.jpeg.796b39bb05620983973e2301b0884f65.jpeg
I find myself in need of advice- the damage seems too extensive to hope to repair… and I was barely beginnning Chapter 2, although I bought parts thru Ch. 4 or 5. Question is, start over from scratch, ordering new frames and Ch 1 parts? If I go this route, I am thinking to use cherry as the yellow cedar does not do it for me. Great to see so many of you have finished!!
cheers- Scott
Scott
In my opinion do not see anything that cannot be repaired with some replacements...
I would go for a repair, as you have come so far already and which is just all fine!
Frank.
cheers- Scott
Current builds on MSW:
HMS Winchelsea 1:48
Prior builds on MSW:
None
Thanks Frank, that gives me some hope! I won’t lose anything by trying repair, right? Now i need to make a pattern to remake that stern frame :)
Scott
Hi Scott,
Exactly, and as far I can see, all that's broken now, won't be visible when finished, but try to repair in a good and qualitive way, so take your time to do that correctly and thought through, important for sturdiness later on.
Good luck, I think you'll be good!
Cheers,
Frank.
HMS Winchelsea 1:48
None
