Hi all, just got my first parts from Chuck/Syren, and excited to find this group build for a transition towards ‘all scratch’!
cheers- Scott
Scott
In progress: 1:48 HMS Surprise 1796 (DeAgostini/AL)
                       1:16 New Bedford Whaleboat (Model Shipways)
Parked:     1:48 HMS Winchelsea 1764 (NRG group project)
Finished:  1:48 City of Buffalo Lake Steamer 1890 (Dumas)
                   1:48 Lackawanna Steam Tug 1900 (Dumas)
                   3/16" (1:64) Kate Cory whaler 1856 (Model Shipways)
                   1:48 Puritan 1885 (Mamoli)
And shop for a scroll saw and a mini table saw (Proxon type!). First step, print the plans!
Scott
 I really like my Dremel Scroll Saw that I got through Home Depot (should be $60, maybe a tad less). The saw is very accurate and easy to use, the only one issue I have is no tilt-base (although I don't really need it thanks to my disc and belt sander). I have yet to get a modeling table saw nor do I have any lathe as of yet. Small steps but do what I can with what I have.
Brian :)
Thanks Brian! I may take that route, seeing as a 4” table saw runs $350-500 (!). Heres the dry fit of unsanded pieces for the stem!
Scott
Dont forget your rabbet strip between those.  That changes everything and you would be surprised how much the shape changes.  So avoid tweaking your stem until after you can test with the rabbet strip in position.
Chuck
Very good point, and a reminder to read the instructions carefully! Glued up and ready for softening the forward edges and tapering the head knee.
Scott
...and, mwelp, already messed up and sanded the keel end down to 1/8th”,042FD947-7F45-4727-BF93-1CC09E7B8FBD.thumb.jpeg.1a91193c76b0689e13ca7ecd00dc438c.jpeg DOH!
Is this terrible enough that I should try replacing with a new part cut from the 1/4” cedar?
Scott
Yes you should def. start over.  I could send you a new sheet of stem parts if you pay five bucks for shipping.  Send me a pm with your address.
Ok, going to start over. Put together a building board and practicing with new jigsaw in the meantime; practice pieces and trying rub-on poly on the cedar:
Edited by milw
add picture
Scott
Scott,
The knee looks nice! It looks like your trying to cut right on the bulkhead template lines. You could cut the bulkheads a 1/64" or so outside those lines to be safe. A lot easier to remove material than to add it.
Mike
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Thanks Mike, thats great advice. Now if I can only keep the cut line from wandering!
cheers- Scott
Scott
It’s the ‘new’ blade that came with the saw, but I can’t vouch for its quality. I’ve ordered a set of Flying Dutchman blades (seems appropriate ;)) and will install one of those. Any suggestion on TPI and speed for 1/4” ply?
Scott
Everyone has their own preference for blades and speed. I use a double tooth 24 TPI blade made by Saw Bird.
It's a very thin and has minimal tear out. As for speed I set mine at a middle speed.
Experiment with different blades and speeds on scrap wood and see what works best for you.
I hope this helps.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
  • 10 months later...
Approaching the rigging stage for my 1:48 HMS Surprise, so refreshening on the Winchelsea- I'm going to go with the laser cut frames from Chuck, otherwise this will be a 5 year project!
Scott
Frames! arrived today, 6 days after estimated delivery (thanks USPS new management). Lets see if image insertion direct from phone works!
Scott
Progress on the keel, adding the monofilament bolts. A question on the false keel though- is it supposed to be one strip, or shorter sections with joints staggered from the keel joints?
Scott
Thanks Chuck! At least I can get one side looking tight, the other... not quite as good. In fact, I think I should redo the gammon knee and extension.
Scott
I wouldnt worry about it.  The stuff on the stem will be all painted black so when the time comes you can just fill it and sand it smooth.  Not to mention that it would be near impossible to see that detail behind the head rails and head grating.
All frames glued up! Almost no issues, only a few needed opening up of the slots with a file. Test fitted all before beginning to glue.C28B5AF9-9577-452B-B175-E4C4B5D76569.jpeg.c29518dcaec2079bc5b5b561eb9bf7ef.jpegFA8E69B8-AE72-403E-A83F-7933B03019D9.jpeg.6e7bff49ff866970efe302ffe2c1e95a.jpeg
Scott
You're on your way now!
Rusty
Thanks Rusty!
but Sigh, there are at least two things wrong now. One easily fixed (I put all frames with etch marks forward) and the other, not so easy perhaps. I was puzzled by the Chapter 1 mentioning 3 bow filler parts; no I say in my mind, theres 4: 2 copies of BF2 (identical, so that counts as one, maybe?) and two different BF3, obviously one for each side.
Today I unrolled the plan sheet again (going to tack it up after this!!) and lo and behold, theres a 3/64 “BF1”! But wait, those BFs were 1/4”... it slowly sank in, and with my glasses on I can now see that there are 3 BF pieces per side!
Arrghhh. BFs 2 and 3 solidly glued in place, meaning the inner space between the BF3s is now too small by 3/32”....
I think I can trim the inner ply off of the BF3s to remediate the space, and perhaps add 3/64” to both outsides?
Other than that, I think I’m in good shape to begin fairing the frames. Wish me luck!
-Scott
Scott
That sounds like a plan....that will work.  Just mark the sides for 3/64" to be removed and use a file or sanding stick.
Good save Scott,  it's a continual learning process with these builds isn't it?
Looking good though,  those laser cut bulkheads look really nice.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Fairing underway, nothing like a long weekend to get stuff done! Nice weather helps too :)
Scott
