This is my first ship build other than the odd plastic kit version. I normally build plastic kits, mainly aircraft but over the past 12 months my modelling mojo has deserted me and I’ve only finished two builds.
I mentioned the above to @James H and he said he would send me something completely different. How pleased was I when this beauty arrived in the post complete with a keel clamp and plank nipper that James didn’t need anymore.
When finish she’s supposed to look like this:
so I sat down at my bench and this after got a good start.
All being well I should have some more done tomorrow. Please do leave suggestions and tips, I’m new to this 😀
Nice to see you make a start on this one. Terror is a lovely kit and I'm more than sure you'll do it real justice.
Looking forward to the rest of the build.
Oh....and this...
 :sign:
Ongoing:
Looks like a great start! Are you planning on penciling in the decking after you place it all? I’ve never done planking so take this with a grain of salt, but I believe that I have read people gently rubbing one side of a plank with a pencil to accentuate the lines before placing them. My next build will require planking and I was planning on experimenting with this.
Welcome,
Great start on the Terror, Looking forward to this build. This ship is on my bucket list after watching the Terror series on TV last year.
I think you will be very happy with the Occre kit, there customer service is awesome.
  • 2 months later...
Finally managed to get back to the modelling bench.
planking now ‘pencilled in’.
Then the first coat of Oak varnish
I have now started ‘roughing out’ the hull frame ready for the inner hull planking.
Thanks for looking more soon I hope.
Yes! I Love it! I just received my Terror kit along with the Essex from the OcCre factory. Have To finish my Bounty and Hermione before I get to this one, so I’m going to follow along with your build. Great start!
Completed Builds: AL Bounty Jolly Boat, Constructo Enterprise (logs lost in the great crash)
Current Builds: Constructo Bounty, AL King of the Mississippi
Up next: undetermined
Love it! You're a natural to this 😎
Can't wait to see you start to plank this one.
Ongoing:
I am a complete novice at wooden ship building, so you should be able to learn from my mistakes 😁
Thanks, I'm approaching that point with some trepidation. 🥴
This was my very first build! I loved it!
You can see pictures in the Gallery.
I hope you don't mind a little constructive comments...
Planking is probably the hardest part of the build... maybe right beside all the rigging!
Planking should be done with a few planks along the top and then up from the keel. Once you have 2 or 3 boards on one side at the top and bottom, switch to the other side.
And continue doing the same throughout the planking.
The problem with doing one side is that it does tend to pull the model out of shape!
The planking at the stern should have continued up to the transom. You may need to remove some of it and redo that part.
If I can help in any way, let me know... I finished mine in February and it's still fresh in my mind.
And boy, did I make my fair share of errors! Attached a couple of pictures to show what I mean
I hope you continue to enjoy the build!
57180330785__EBCE5228-1337-4CC0-83BA-BA6C905E7AF4.JPG.1a13e0bc4e4ba5b0862471b529b28a64.JPG
57265586346__40EFDD25-0F5C-44F2-AA61-E457A8D1A1DC.JPG.167a661e5c6b36d93aae5e422eb9829b.JPG
Good luck!
Lyle
"The only thing that stays the same is the constant state of change"
Completed Builds:
Occre HMS Terror - https://modelshipworld.com/gallery/album/2065-hms-terror-occre/
NRG Half Hull Project - https://modelshipworld.com/topic/23546-half-hull-project-by-lylek1-nrg/
1:130 1847 Harvey - https://modelshipworld.com/gallery/album/2125-1847-baltimore-clipper-harvey-1130-scale/
Scott Miller's Sea of Galilee Boat https://modelshipworld.com/topic/29007-sea-of-galilee-boat-by-se-miller-120-scale-lylek1/
In progress:
Artesania Latina HMS Bounty - https://modelshipworld.com/topic/26817-hms-bounty-by-lylek1-artesania-latina-148-scale/
Waiting for dry-dock space:
Model Shipways - USS Constitution
Master Korbel - Cannon Jolle 1801
A Scratch build -TBD
Thanks for the pics, the supplied planks were not long enough to reach all the way to the transom so I’m going to cut them back a bit and add extra
They are not meant to be "full length" planks.
This a double planked hull so you can hide any seam or errors, it's the next layer that needs to be your best work!
Lyle
Completed Builds:
In progress:
I realise that, that why I’m going to have to lengthen them.
Hi,
Nice progress! Doing my first build Terror also.
Cut those planks back 1-2 frames as Keith said and you be fine.
An other suggestion would be not to push nails totally in leave them little out. You will sand yourself mad with them in there. Remove the nails after planking is done for better sanding.
More progress on HMS Terror. The false keel is nearing completion. I have revised the way I have been laying the planks to make bending around the stern and bow.
Following advice I have revised the planking to make bending the planks. I have also started sanding the planks on the finished section ready for the final planking.
There are a lot of "Little Terrors" going together at the minute. Including yours, I think there's six of 'em! Lots of inspiration.
