Also noticed
HAPPY BIRTHDAY Snowman...
Later 42rocker
Edited by 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Happy Birthday Shanon and a Happy Birthday to you too Sinan! :36:
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thanks guys, Slow building this week, and no web access for a few days. I managed to cut a couple of knees to shape but looking at them today I might make them again, they are a little rough around the edges.
Have spent some time restoring an old hand saw which came up well once finished, nice and sharp. Was my grandfathers and I have a couple of them with different teeth sizes to tidy up. Photo below shows the finished saw and one that was the same condition to start.
I removed the handle and the piece from the top of the blade. The handle was washed with a degreaser to remove the grime then sanded lightly. Finished with an oil and wax. The top piece wax sanded and a rust converter used to kill the rust then a black etch primer sprayed. Blade I went over with a scraper to reove rust and dirt. Then rust converter to kill rust and followed with sanding with a fine sanding sponge (about 1000 grit) to polish. Lastly a coat of metal polish to keep the rust off. I inherited a box of tools from my grandfather and there is a few that need a bit of work to get them into a usable state.
Made some of the knees agan today. A lot better than the first few made. I have left the templates on them for now until they are finished as they are marked with each location so I know where they are supposed to go. Might be easier to start cutting the mortices with the template in place too. They still need sanding on the inside radius which I will do once the paint is dry on my sander. I built a table for the sanding drum that fits on my dremel (read cheap copy) for the really small curved parts, and they paint was sprayed on today to tidy it up. I will put pictures of this up in a few days.
Couple of photos of the sanding table used for the knees and other small parts. Built from scrap mdf and timber them a coat of paint to dity it up. Not bad for an hours work. Overhangs the workbench so the flexishaft fits next to the edge. No wobble in the sanding drum that I have noticed, but have only used lightly so far.
and in use
Here are the larger sanding drums I use in the drill press. Largest is 75mm middle is 38 mm and the dremel type.
Ok, I need a bit of help. I have to plans that look the same except for part 13 - the hanging knees.
These are on drawings labelled Midship Cross Section 1 and Midship Cross Section 12.
I have pictures of the difference below and cant decide which is the shape to use. I guess the larger piece has more strength and would be easier to make but which is more accurate?
I went with the larger ones.  I assumed they others would be too thin and likely to break during manufacture with the timber I used.
Regards,
Grant.
In our original drawings, I see that the smaller knee was used for the lower deck. When we drew these plans about 6-7 years ago, we researched all the major framing members for general scantlings for this size frigate so that must have been where we got the size for that knee. However, if you want to use the larger knee, the shipmodeling police will not arrest you. :)
Russ
Just to confuse you more I went half way between the two. :)
Rusty
Always get a answer fast here. I have contemplated for a couple of days and decided to try doing the smaller size and see if I can make these without them breaking. Otherwise will do what Rusty has done and go half way. The more I look at the two pics side by side the larger looks too large, but that could be my eyes and staring for too long.
So far that looks very good. The waste bits in the bilges actually looks very authentic. That is how it looks a lot of the time in the shipyard. :)
Russ
The clamp on the rear beam on the left is where I ripped a chunk out where I wasn't supposed to - should be invisible when glue has dried and other pieces glued into place.
I can tell the forst mortice from the last but I am pleased I only had to make one of each of the beam arms. I have spare lengths of timber set aside so I would be able to redo when needed.
Edited by Snowmans
Your work as normal looks great and your wood colors look great also.
Enjoy the ride.
Later 42rocker
Got a few more beams in place over the weekend, they need to get a bit of a sand to tidy them up but they turned out ok. I dont have gaps that are too big, so I am happy about that. Still shaping the knees to fit so that will be next weekends job, hopefully.
Latest pictures
Hi Snowman.
You are making a brilliant job of this build..
Your choice of wood and colours is fantastic and does you and the model credit.
Please keep the pictures comming as I have yet to do my Trition build.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Everything is looking very good. Well done! B)
Rusty
Lovely work, Snowmans.  Very precise and clean.  And I'm with the others on the wood colors. Beautiful.
