a mass of dead people, might be easier said than done, unless you were to use a modelling clay with bits of the soldiers added
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
I'm using the Perry  supplied  figures I have  - just need  to alter some of the arm positions   - will get there in the end  (I hope)  lol
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
keep up the great work
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you mate.
OC.
Current builds
Completed works.
Evening all,   the  bunch of  casualties  are complete  and  primed  - will be interesting  painting these.
OC.
Current builds
Completed works.
“Interesting” is one way of putting it!  Such a complex shape, to get your brush into every nook and cranny. 🤔
Andrew
Completed (Kits):-
I think the Black primer will help as it will help to form  shadows  - it will be a test  of my ability  and If I pull it off  should look quite interesting.
OC.
Current builds
Completed works.
Are you pre-positioning the bodies or will they individually painted and the re-piled?
Their  all glued together as a mass   - yep will make for some interesting painting.
OC.
Current builds
Completed works.
Evening all,   I have been working on a  wounded  55th Ligne  Fusilier, he will placed  slumped into the hedge, and also  see what's  arrived  -
OC.
Current builds
Completed works.
I am not too  worried about tha face on the  injured french man  (its not the best for detail  how it was sculped)   as  he will be partially burried  in the hedge  (will still be seen  but obscured a bit)
OC.
Current builds
Completed works.
So, after  some touch ups  and weathering to mr injured man, he will be put aside  and I will tackle the mess  (I mean pile of injured/dead)   my admiral is real keane  for me to start this  - as she has no clue how I will be able to pull it off  "I have my ways"  lol.
This is were  they are going to be placed  after I have doen some more groundworks - scenery at the back of the farm.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Evening all,   quite a bit done today  -  I finished the sole  injured  figure  and placed  him slumped  against the hedge.
OC.
Current builds
Completed works.
Next   I have started on mission impossible  - I have painted and detailed their faces/hands  and hair  details  and  the lozeng  hat  plates  and straps.
OC.
Current builds
Completed works.
And then  I cut the First Two  resin KGL 5th  figures away from the 3D pips,   the detail  on them is amazing.
OC.
Current builds
Completed works.
2 hours ago, king derelict said:
Impressive detail in those resin figures. Its easy to forget how small those figures really are. The photo of the lane with the injured soldier and the long shadows looks very convincing.
The pile of casualties is quite a challenge. I look forward to the end result.
Alan
Thank you kindly Alan,   I have tried to make the wonded/dead more sombre  with less colour in their faces.
OC.
Current builds
Completed works.
Evening all,   more details painted  including painting some of the Dark Blue jacket details  inside the pile up.
OC.
Current builds
Completed works.
Its amazing where the time goes  - Three hours  painting  just in those few details.
OC.
Current builds
Completed works.
Evening all,    I decided to scan over my build pics earlier  and it struck me  -  some of my 5th KGL  (Red Jackets)  I dd not paint the White stipes on their bird nest shoulder epaulettes,   trouble is they are placed in the farm / glued down  (a few under the doorway)   If I wanted to try to apply these incredibly small fine White lines  - how couuld I do it  - keep my hand staeady without a hand support  and even see  withought  being able to get  up close to them.     any thoughts or ideas  folks?
OC.
Current builds
Completed works.
Rest your wrist and hand on a sponge and use a 000 brush.
I bought the Qualrite set of detail brushes (note: these are artist’s brushes and not model brushes) off of Amazon and they have worked amazingly well for miniatures.
The 000 brush works great for insignia at 28mm scale.
The sponge soaks up the vibration from your wrist.
Given the choice, I would prefer to put my wrist down on something solid to ground it out, but with where you’re trying to work, the sponge would inflict less damage.
Edited by GrandpaPhil
Building:
Thank you kindly  Phil,   I have seen artists use a  stick  in one hand  balancing the paint brush hand against it.   I like the idea of the sponge  but alas I wont have room  to place that as the scene is quite congested and busy.
OC.
Current builds
Completed works.
Can you ground your wrist out on the building walls or roof?
I will try that  Phil,    thank you  for  coming up with some ideas.
OC.
Current builds
Completed works.
You could leave that detail off the troops that are very difficult to get at, only you and we few here would know🤫
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
OC, you could try the stick method a lot of sign painters use when painting a company name on their glass doors/windows. I would get a 1/4 or 3/8 inch diameter Maple (or other hard wood) dowel, put a rubber tip on one end, start with a 24 or 36 inch length, trim to comfort. It should be long enough to span your diorama and rest the rubber tip on a work table surface. Hold the other end with one hand , rest your painting hand on the stick. I've seen professional sign painters use one and it's amazing how steady they can be.
Jack
Current buildUS Constellation
Thank you Jack,   thats just what I have seen some artists do using a stick with a soft end,   will have to  suss  that one out.
OC.
Current builds
Completed works.
"Mahl Stick"    is what they are called  - just  found out.
OC.
Current builds
Completed works.
Evening all,   bit more work done to my pile  - vests and trousers  done.
OC.
Current builds
Completed works.
As some former military might say...  "Stack 'em. Pack 'em. And rack 'em."  Looks great, OC.
