Battle of Waterloo Attack on La Haye Sainte Farm 1/56 28mm
Three nice sections of road you had made OC 🙂
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Share on other sites
Indeed mate  and so cheap  under a Tenner  including delivery.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
OC.
That's a good price, as they're basically custom made 😉👍
Current builds;
Completed:
Link to comment
Thats what I thought mate  - especially  taking into account how many days he was working on them - first class work.
OC.
Current builds
Completed works.
Link to comment
Nice that he added the foliage along the road. Good looking road for your diorama. Shaping up nicely, OC.
Ken
Started: MS Bounty Longboat,
Link to comment
Thanks Ken.
OC.
Current builds
Completed works.
Link to comment
they're really gonna add to the dio.........the roads look great! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thank you Denis,    I though all things considered  it was worth it  compared to what I could have done myself.
OC.
Current builds
Completed works.
Link to comment
I need a  Marshal Ney  to attack the farm  so I have  sent off a bid in Ebay  - its a pre painted one  but  I will re paint it in my own style should I win it  - wish me luck.
OC.
Current builds
Completed works.
Link to comment
I won him  (Marshal Ney):dancetl6:
OC.
Current builds
Completed works.
Link to comment
Bit of a downer this eve  - my brother is in hospital  for un associated  reasons  - but while in there  he came into touch with someone covid positive  - yep you guessed it  - he is now  positive  but so far no symptoms,  he is Isolated and beieng  checked and tested regular.
Nothing I can apart from checking up on him over the phone.
OC.
Current builds
Completed works.
Link to comment
Link to comment
58 minutes ago, Ekis said:
Courage for you, and a quick recovery for your brother. 😐
Thank you so much.
OC.
Current builds
Completed works.
Link to comment
27 minutes ago, Jack12477 said:
Likewise from me OC.
Thank You  Jack.
OC.
Current builds
Completed works.
Link to comment
Feeling for you OC,  my mum  had much the same experience 😑
Current builds;
Completed:
Link to comment
Sad to hear this, OC.   I'll be hoping for the best for him and for you.
Link to comment
We'll keep y'all in our prayers. And crank up your vitamin regimen, OC.
Ken
Link to comment
Thank you Edward.
OC.
Current builds
Completed works.
Link to comment
Thank you Mark.
OC.
Current builds
Completed works.
Link to comment
Thanks Ken,   Im already on a Vit plan  - have been  over the last  year, If I took anymore I would rattle.
OC.
Current builds
Completed works.
Link to comment
Got you and yours in my prayers brother, hope it turns out well.... (if god has anything to say about it, (and I know he does) it will turn out well)
Keep the faith my friend...
Quote:
Link to comment
Any way keeping my mind occupied........the figure I won  the seller his going to take it off the base as it will make it easier for me  when I come to fix it down onto my dio,   I will be doing quite a lot of  re painting and face work, to get it the way I want it.
The history  behind Marshal Ney  at Waterloo  - he was  about Third in command   and commanded the Left hand colums, they were responsible  not only for attacking  Wellingtons center  but also  Hougoumont Chateau  and La Heye Sainte,  he gave orders first for an advanced party to attack and take L.H.S  but they were driven back, after  he was responsible for a couple of attacks on the British/German  flanks,   also  he led the  charge with the French cavelry units against the  combined British  quares, then he was given orders direct off  "Boney"  to lead an attack on  L.H.S   and  only then did he drive the KGL  out due to them running out of ammo.
I intend to place Ney  close to the  Farm  along with the attacking  French units.
OC.
Current builds
Completed works.
Link to comment
Thank you kindly Brother,    trying to keep my mind occupied   - guess its the normal thing to do.
OC.
Current builds
Completed works.
Link to comment
OC.
Ney at Waterloo cost Nappy the battle...... LHS was the key to the British position, the longer it held the longer they had to prepare for the centre assault they knew was coming.... When Ney finally took it the British were prepared for the final act with cannon overlooking everything with the French channeled into their fields of fire....
He did not understand fully the importance of the position and why Nappy wanted it taken early....
Quote:
Link to comment
Indeed brother, made worst by Ney  acting on his own instructions  when he led  that charge on the squares  thinking the allied forces were  retreating  and re grouping/moving the injured,   those squares were amazing  that day.
OC.
Current builds
Completed works.
Link to comment
Yes this and the time and manpower expended attacking Hougoumont, which was doing exactly what Wellington wanted it to do, presenting an obstacle to any attempt by the French to outflank the allies. Typically the French tried brute force of the massed columns against a veteran unit of the Guards who knew the destruction platoon volleys could do. Despite high casualties in the first assault the French just kept feeding  the men in.
Current builds;
Completed:
Link to comment
Yes perfectly sited and positioned to achieve mass fire power from all sides upon an enemy between the squares.
Current builds;
Completed:
Link to comment
Indeed Edward,   between  the Two obstructions  I think it  decided the battle  on the allies  side  - not foregetting the Brilliant squares aswel.
OC.
Current builds
Completed works.
Link to comment
I was thinking about the scale of the battle  (I thought my little dio is going to be big enough at  36 X 20Inches)   imagine if I could have built the whole battle field in 28mm  ............I would need about  100feet  square I  would think.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
