Evening all,    thank  you  for all   the  likes and   replies,      my next  bit of work  is   to  create  Four  epaulettes   out  of  some arms  -  fiddly work  as they will  need  hollowing out  from the back  before trimming away from the  spare arms.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Evening all,   as   I  mentioned  earlier  I have had  to make  a  couple  of  shoulder  pads   -  delicate  little things,   and while  detailing  I added a  sword  scabbard,  they  will  need  priming after.
OC.
Current builds
Completed works.
Beautiful work OC.  The muddy footwear on the injured looks great.
I apologize if you’ve answered this before and I missed it, but do you ever use a liquid mask when painting these intricate figures, or is it all freehand?  Your detail work is always so clean and crisp.
Gary
Completed Scratch Builds
Gary
Hiya  Gary,     its  all  free hand  work  - its  taken me a bout a year  to master it  and  devise a tech  for  steady  brush  holding,  also  its  useful to paint the  straps  first  and  fill  in around the  straps and belts  after,   and  very important  is  great light  and  good  eye  magnification.
OC.
Current builds
Completed works.
Evening all,  some  progress  today  -  I  put down a  couple  of layers of White  on the  straps  -  face's painted  and  the  trousers got a couple of coats of  light buff.
OC.
Current builds
Completed works.
46 minutes ago, Landlubber Mike said:
Really great work OC - epic build!
Thank you  so much  Mike.
OC.
Current builds
Completed works.
Eveninga all,    no progress  (I have been lazy  lol)   but  just a  heads up  of my  next  move  with this  -  the  second Cuirassier  will  be  an officer -  his  shoulder detail  is  different  as  he only has  detail  on his  Left  shoulder  and  next  to nothing  on his  Right  -  and he has a  silver colour  not  Yellow (Red  I mean)  like the  normal  ranks,   so  I will  make another  one  for  him.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Couldn't have been too lazy if you've figured out the differences in colors for these French cavalry types.
Ken
Started: MS Bounty Longboat,
Thanks  Ken,     lots  of  research  and  internet  studying  -  so  perhaps  not so lazy  lol.
OC.
Current builds
Completed works.
Evening/morning all,   bit  of a  re-think about the Cuirassier  officers  epaulette   -  he  had it  shot off  in action   (well  to be honest I could not  get a  good one  to  look  ok  -  so  I chickend out)    so  I will  show  a  bit  of  it  on both sides  with  Silver paint.
OC.
Current builds
Completed works.
Morning all,   I have discovered a  Boo boo  with  my build  ( I wanted it  as  historic  accurate as possible)   when  I cut back the  wall  near the  pond  I cut out  the  gate  leading from the pond  into  the  orchard  -  "Yep  I should have  cut out  and  fitted the  gate"   so guess  I have to  take this  one on the chin.
OC.
Current builds
Completed works.
Evening all,    after doing some  thinking  I think I may  be able  to  come up  with a  gate/door  from the  pond area  into  the  orchard,   I could  make  up a  faux  door  from paper  with some over layed  pieces  to  mimic the planks,  I could  also  use  some  wood  to  make  a  small  frame  - that should  give a  3d  look   and blend in when  all  painted Black.
OC.
Current builds
Completed works.
OC, I daresay that if you hadn't  told us, we wouldn't have known about the boo-boo.   I believe you'll have it repaired and any one seeing it will never know.
Thank you kindly  Mark,    I  did  have the  gate  included  in the  wall  section  -  but  I  had  to  remove it  when I reduced the  length  of the wall,  and  forgot to  work it into the  smaller wall   -  kind of got  distracted  by the  other  areas  of the build.
OC.
Current builds
Completed works.
23 minutes ago, king derelict said:
I think it would be worth trying a false gate if it will still look good in the shortened wall. Otherwise I suspect there will be so much going on in the scene that the gate will be lost in the action
Alan
Thank  you Alan,  I think it will  bug me  if I don't   try  to make  one.
OC.
Current builds
Completed works.
OC, if you have wood coffee stirrers, they look like boards for a door  and framing after you stain them. You could use an oil paint wash for a stain. Water washes may curl the wood.
Ken
I have  some  similar  (Lolly sticks)   but  they will   be  too  thick  to use  for the door panels,  I can use them to make some  thinned down  frames,  but  the faux  door  needs  to be a  thin as possibly  literally  paper thin  as  they will be glued on the wall  both sides  mimicking  a  door,   with  the  frame  disguising  the  depth of the door  in a kind of 3d illusion.
OC.
Current builds
Completed works.
So  how  will  I make  my faux  doors?   I will  use  Two pieces of paper  layed ontop of each,  I will  then mark out the  doors dimensions  then cut through both peices  creating Two doors  the exact same size.
Then I will  cut out  strips of  the same paper  to  simulate the  boards and Two  cross boards,   these will  then be glued  down using my PVA  leaving a slight gap  till  both are completed.
When dry  I will  paint  both  doors  in flat  Black  and  after  I will  do  a bit  of  washes  and  dusting  to weather them.
I will  also  make  some frame work using  some of my  wood stock,  these  will then be painted  flat Black,  and  when  dry  I will  glue them both sides of the wall  macking sure  they lign up on both sides of the wall,  and when dry  I will  glue inside on the walls  the Two doors  -  hey presto.
OC.
Current builds
Completed works.
This  is  the plan  -  kind  of.
OC.
Current builds
Completed works.
22 minutes ago, king derelict said:
I think the plan to use a raised frame and paper gate will create the illusion of depth without looking odd on the walls. It is definitely worth making the gate. It would be irritating to know it should be there.
Alan
Fingers  crossed.
OC.
Current builds
Completed works.
4 hours ago, Canute said:
Best of luck with your plan, OC. 🤞
Thanks  Ken.
OC.
Current builds
Completed works.
Evening all,   more  progress  with  the  Cuirassiers  adding  some colour.
OC.
Current builds
Completed works.
Evening all,   I have  started the  orchard  doors  -  I started  off  by  sizing them up  then I sat Two pieces of paper  together  then after  marking the  size  -  I  cut  through  both  pieces  with my  blade,  next  I  squared up  some  thin  wood  stock  and  worked out the  correct  width  and  trimed  away  with my blade,   a  little  sand  then both  edges  where cut to  length  along with  the top rail,  I then  fitted them on the paper  square  with the edges.
I then  I cut some paper  strips for  the  planks  on the  long  runs,  these  where  cut the  same width  then  glued  down  with a  slight gap,  next  was  the  cross  support  planks  -  again  these  where  cut  to  size  and glued on.
The  bottoms  where  trimmed  on the  one  door  -  still  needs  doing to the  other.
OC.
Current builds
Completed works.
42 minutes ago, king derelict said:
Great start.It looks like the gate is going to work out nicely
Alan
Thank  you  kindly  Alan,   they  wont look too bad  with  some Black  paint on them and weathered.
OC.
Current builds
Completed works.
