You might also wish to try roughening up the cast piece with some sandpaper before you try and glue it to wood.  100 grit should work.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Does anyone know where I can find the site about ship modeling?  I think it's called MSW 2 or something like that.  I think that is where build logs are posted and pictures of ships can be found...... :P :P :P :P :D :D :D :D :D :D :D :D :DB)
It seems I've lost my way.....
:cheers:
Jim
Completed      Robert E Lee, Misisssippi riverboat
Completed,  HMS Victory Bow Section
Completed,  Wells Fargo Stagecoach...Picasa album....
Completed,  Lackawanna tugboat converted to private yacht...
Completed:  Sopwith Camel, 1:16 Scale, Model Airways...at another location...
Completed:  1961 Ferrari F-1 Sharknose
Completed: (sorta)  OcCre BR-18 Locomotive
Completed: 1/35 Pz.KPfw.III
Completed: Allerton Steam Pumper circa 1869
Jim is hitting the nail on his head!
There must be somewhere a build log…….
And guys,
I sand all the metal parts before I put glue on it.
I even call a welder…….
But I hope it stays now.
I'll have to go to work ,so I don't touch a thing!
Maybe that will works  :P
See you tomorrow again……( if I can find the time )
Sjors -
I found this while I was walking along the shore this evening in New Hampshire and thought it may have been dislodged from your SI...ship-captain-smiley-emoticon.gif
Hope all is going well - how are you making out on the metal work?  Seeing the rest of your success on this beauty I have no doubt you will overcome this obstacle as well!
EDIT:  I just noticed - 12 more posts and you will have the distinction of becoming the first non-Moderator Commodore!  A worthy rank for a mariner of your stature with your fleet of mighty cottonball carrying warships nearing completion!!!
Edited by trippwj
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Sjors,
What sort of glue are you using for the metal parts?
Hi Grant,
I was first using UHU glue and that didn't work so the next glue was special for model building.
Small parts worked perfect but the lower part of the quarter gallery is solid metal , so that didn't work also and at least I try two components glue and that work!
When I want to remove it, I have to cut a hole in the hull…….
The first two parts of the gallery are on it and need some paint.
Maybe I can post tomorrow a picture of that.
Not the late shift today but a shift that is between morning and late…..
Starting at 13.15 PM till 21.40 in the evening.
So only a little painting and then back to work again…….
Sjors -
Hi Wayne,
Everything is ok.
When you are at Maine and you start up the PC, maybe you see a little update  :)
Can I order a few hundred of those little "balls" ? :D
And thanks for the confidence !
I smell a little fear??????????
We are so lucky that we have a fleet of cotton balls warships they we don't have the fear that we have some boll weavers in the house…..( I don't know if it is the right word but there was a song in the 60's that was going about a boll weaver or something like that?
Maybe someone else can shine a light on it ?
It calls the bollweaver song…..
Edited by Sjors
Ok, here are the first pictures of the lower part of the quarter gallery's….
It's not perfect but I am pleased with it, so I keep it this way.
A little paint has do be done.
Because them also, they have every confidence in your ability to succeed... :D
In fact, for metal parts they use molds. At first, they can form once the mold quite perfectly then all results would be perfect... They are craftsmen I believe but I can not understand why the outcomes are not clean, symmetric, in good trim...
Best Regards…
Ferit KUTLU
Under construction: Frigate Berlin (Brandenburg Navy)
Hope: Frigate Wappen Von Hamburg (Brandenburg Navy)
Very nice work on the galleries, Sjors, doesn't it feel great to be able to make your own ship parts? B)
Be careful my friend, the pull of the dark side is strong, and I sense much force within you  ;)
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Hey!  Someone snuck in here and uploaded pictures of a ship model - kind of breaks the flow of things, don't you think?  The gallery is looking good, as is the transom.  Keep up the good work, Sjors.
Now back to the topic at hand - is this the song you are talking about?
Let me tell ya a story about a boll weevil
Now, some of you may not know
But a boll weevil is an insect
And he's found mostly where cotton grows
Now, where he comes from, hm, nobody really knows
But this is the way the story goes...
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
Sjors,
I asked about the glue as you seemed to be having trouble getting it to adhere. I was going to suggest using a two-part epoxy for these metal parts, but from the sound of it you figured that out already. I'll leave you to go back to playing with your balls now. :P
Yes Andy, then it all crashed and burned ------ again!  The visual imagery around here is sometimes frightening.
That said, the transom and galleries look great and Sjors has made progress in mastering adhesive technology.
GREAT JOB!
Augie
Previous Builds :
OK, OK, enough is enough guys, I will speak in defense of my good friend Sjors: No more hitting below the belt OK?
.....we all know what's down there :D
Best regards,
Aldo
Currently Building:
Past build:
Frightening is not the word here.... it's utterly disturbing.....
Of course.. I admit I have to restrain myself from pulling the "flush" lever on this thread.... being party to a group of stereotypically dirty minded sailors and all.... :blink:
And Aldo..... that didn't help :P
**Grabs the whistle pull cord again and sounds 5 short rapid blasts**
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
of course gentlemen......we've only seen a side view.   now to wonder what the balcony looks like with the face on ;)
........more pictures Sjors!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Sjors, your fix looks greatpost-127-0-17607600-1371752545.gif Be very proud of your accomplishment!!
As for the other topic that seems to have taken root here....I will refrain from comment...trust me, I could make the hardiest of you sailors blush !
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Nicely done my friend.
I wonder if the humidity has got something to do with glue not sticking well, we have had some warm wet days lately. :(  :(
Ive  had some trouble with my plates not sticking very well, :angry:  :angry:
I don't know about the visual imagery being frightening, it's the stuff nightmares are made of. :D
Your getting there, keep it up mate.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Thank you all.
@ Grant,
I have to try everything to see what's holding that metal.
Now I can go on with the other metal parts…...
The quarter gallery goes higher and higher.
@ Augie,
Thank you also.
I almost glued my fingers together with the amount of glue I used  :D
@ Robbyn,
Also thank you !
I happy how it look this far.
Only one day free of work so I think not much progress.
@Mobbsie,
Maybe you are right about the humidity.
We want sunshine, now we have got it…….
But it is already over.
Two days of 34 degrees Celsius and the coming days it goes down to 16 degrees Celsius…...
Winter coat out of the closet again…...
Thanks for the head up  :D
Edited by Sjors
CAN WE HAVE A DRUM ROLL PLEASE ???????
I predict that, within the next few minutes, we shall all witness a promotion the likes of which has never before been seen on MSW 2.
Captain Sjors is about to be launched into the stratosphere.
Congratulations (in advance) my friend :champagne:
Augie
Previous Builds :
I think he is savoring the moment, maybe waiting to be prophetic or have a really deep thought appropriate for a commodore,.... waiting... waiting Commodore.
Congrats in advance whenever it does happen then :)
Do I still have time to cobble together a catapult to help with the launch? (Or an air canon?) Maybe someone can help with a JATO bottle or something?
:D
I'd say try me... but you're supposed to be among the bunch that keeps things PG around here... :P :P ;)
Oh and Sjors, congrats on the quarter galleries... hope you need less glue going forward... ;)
Andy
USF Confederacy
Andy
exactly why I am behaving myself....having a bit of trouble being the good girl too
Robbyn
Current builds
AL San Francisco II
Completed Builds
In the closet
Battle Station
Good morning all,
Yesterday there was no reason to post because there was nothing to post for me.
And to post something without a reason is for me no post.
But……now you gave me a reason  :D
Thanks Augie, Aldo, Randy for the champagne…...
Have I to sit alone at the table now?
@ Andy,
Thanks.
I should be happy when I can go back to the wooden parts.
There is not much you can do with metal.
You can not shape it, bend it, glue it  :(
Bob
Hi Bob,
I missed your post  :(
No worrie, I was the one who posted the pictures  :D
And that's the song I was talking about !
I knew that some one knows it…..
