OC, I would guess that there's several ways of locking out wing rotation.  The simplest would be the landing gear indicators.  When the gear down and locked, the wings would have to be in position.  With weight on the gears, no rotation possible.
Weight on wheels switches are fairly common. Helps keep landing gear down, primarily for takeoffs. Some fighter guys liked to flip the gear switch  up as they started rolling and you could get the gear up faster. Of course, if you had a problem at rotation and wanted to stay on the runway (assuming there was enough in front of your to allow stopping) , you could be sraping along on tanks and partial gear.  Hard to stand up to the Boss and explain that.
Ken
Started: MS Bounty Longboat,
On 11/14/2020 at 1:14 PM, Canute said:
I'd bet there was a lockout of some kind to prevent tilting the nacelles from the vertical position, on the ground. As long as they've been around, I've never read about that happening.
Actually it depends on where they are located when they are on the ground, typical take off procedure is to do a rolling takeoff from a runway.... (when one is available)
Generally, although capable of taking off vertically, they usually do not.... I'm sure they have a warning indicator of some type if they are tilting the engines too far forward when on the ground
Edited by Egilman
Quote:
And, the original transformer....
Startup and Takeoff
Edited by Egilman
Quote:
there are those vents again...........on both sides of where the wing mates the fuselage.   I think that the ones where I didn't see these vents,  were ones that weren't equipped with the folding wing......they were fixed.  I should do it in the lighter gray.......it does look good.  really neat to see one fold out....thanks for posting the videos :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
as mentioned........the rotors are huge!  seeing them assembled......I can just imagine them on the finished model.
the instructions direct you to paint the insides of the engine.......I did not.  rather than do that,  I just painted around the vent openings,  and the insides of the vent parts.
so that when the vents are added to the narcelles,  they will appear darkened.  I did paint the exhaust port in the rear of the narcelles.
not sure what these parts are......they may be lights,  but they were added to the spinners.
I would have used some of the bomber instrument panel decals to add to the panel in the cockpit......but I noticed the absence of gauges.  so I just painted the detail to the panel.......and the side panel on the starboard side.
some touch up needed....not the best work.  with the glass in place,  this might be tougher to see.  the cargo door(s) have been painted.....I did the bottom to look like the interior floor.
I've been doing paint in other areas.......here is the beginning of the wing.  still needs touching up.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Some good progress there mate   - coming along nicely.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Denis, these more modern a/c have fewer obvious gauges, since everything is digital flat screens.  My wife flies in the Civil Air Patrol using a tablet and a few gauges in the Cessna 182s they fly.
Ken
how do they expect us to model,  when they keep changing the playing field???   :wacko:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I'm guessing that in the next few years, some of those "computer" control panels and instruments will be operational.   They might not be seen after the model is built but the builder will know that they are there and work.  :rolleyes:
I was play'in with the prospects of Christmas........if Santa thinks I've been good enough,  I should be look'in at a whole lot of fire power ;)   did a bit more paint today,  along with some of the glass......alas though,  no pictures.  I should have some soon when I reach where I'm try'in to get to.  also got some sawdust under my fingernails....if I scratch,  the itch goes away.....but the intervals seem to be getting shorter ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
hurray.......some progress .......and pictures too! :)   I'm trying to get the cockpit done,  so I can get the interior in.  then I can close the fuselage up and finish the exterior painting.  the camera is still something to get used to......I'm trying to live with the flash.  pictures are darker if I don't....  I've also finished covering the gaping hole that used to be our cellar bulkhead.....I had mentioned about a month back that someone crashed into it.  he missed negotiating the curve by our house,  went out of control,  went over the two driveways {ours and our neighbor's}.  grazed the house,  which sent him into the 'doghouse' that was the cellar entrance.  the house shook........I scrambled outside,  where I saw the car backing out of our driveway.  I tried to flag him down,  but he took off.........on four flat tires!  they were flattened from hitting the curbings.  he didn't get far.......I told the cops the make of the car and a partial plate number....they seemed surprised that I was able to give that much information.  the landlord came by last week and took down the 'doghouse',  and left the stairway to the cellar exposed........I asked him about it and he didn't think it was a big deal.  leaves have already filled the bottom of the stairs.......the cold and accumulating snow should have been something he'd be concerned about.  ......some landlord........sheeesh! :rolleyes:
the seats were painted.......I painted the cushions and the seat belts....and added the frame in the back.
excuse the blurry......
I did touch up the passenger section a little.......with what you'll be able to see,  I only did what was visible.
the glass was added here as well...the one in the cockpit,  the door,  and at seat #18........  I painted the exterior before the glass was added.
the bottom will be done when I get the two halves together.  once the fuselage is together,  I can add the tail section........that has also been painted.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
there are a pair of vents that go on the outside of the fuselage.  as I was cutting them from the sprue,  one of them broke.....so it's on the mend at the moment.
the cockpit was finally assembled and cemented in place........the passenger section was then added.  it was allowed to set for a short......it didn't make sense to me.....so the fuselage was cemented together.  the lower section of the cargo door snapped into place along with the assembly
the exposed venting was painted flat black before the upper paint was done.
I did some touch ups on the cockpit........I should do more.
I started to paint the glass frame.........
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nice work mate  - coming on nicely.
OC.
Current builds
Completed works.
thanks OC........and thanks to all who hit the like button :)   not much more has been done,  other than to cement the tail section on the fuselage.  the upper part of the cargo door has also been added,  since installing it depended on being able to spread the opening to slide the pins in place {unlike the bottom section}.  the only unmatched area of the gunship gray paint is at the nose....I kinda figured that would happen.  but,  gluing the tail on......both sides are a perfect match ;)   but where are my manners........I can show you :)
as I mentioned......the bottom section was put in place as the halves were joined......duly noted.  the top section was put in place after the model had some time to dry.
the door was already painted........
it was at this point,  that the tail section was cemented in place.
by this time,  it was time to take the admiral to her doctor's appointment....and shopping on the way home.  it had a few hours to dry.  at this point in the assembly,  the model is definitely tail heavy  ;)
there is tape on the nose......can't show you the mismatch paint lines......but I can at the tail.
so now it's clean up the messy glue lines and paint the bottom.  I think that when the wing and engines are in place,  the model will balance out.  if not "ve have vays of dealing vith them..." :ph34r:
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
That's gonna be some  kit when she is finished  - some size aswel.
OC.
Current builds
Completed works.
Hello Denis!
Just found your build on the Osprey!  I'm sneakin' in the back to watch and carrying a clipboard.  (If you carry a clipboard around, you become invisible.  Everyone thinks you're doing something when all you're doing is walking around carrying a clipboard.
Tom
Edited by CW_Tom
USS Tinosa (SSN 606) Fast Attack Submarine - Scratchbuild
Pretty sharp, Tom.  But don't tell the Es any more of our secrets. We'll have to actually work. :ph34r: What am I talking about, I am/was an aircrew and never worked for 20 years, just flew my jet around the friendly skies. Back in the early 80s i spent time with my Uncle Mike. He was always asking me when I was going to get a real job.  Didn't think flying a Phantom defending the Free World was a "real" job.
Ken
I do the same thing at work.......I always have a tool in my hand.   that way,  if I'm shoot'in the sherbert with a co worker,  and the boss sees me,.....he think I'm just answering a question,  or help'in the worker out ;)   pretty spry.........right?!?!?! :ph34r:
nothing too great at the moment.......I did the underbelly painting,  and more on the narcelles.......but other than that,  I've been help'in the admiral.
pictures soon.......... ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
just a small update......I am making progress ;)    the underside has been painted.....I did manage to repair and trim the last vent for the port side.  I added it to the model today........
I'll get that painted up........I've also been doing the paint for the rotors......kind of a two step process.  no pictures yet......   I've done more on the narcelles as far as detail work......
.....touch ups on the wing.......and the pods that the narcelles are connected to.......
the spinners are pictured here.......they already have been painted.  more to be done....
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Looking good Denis.
OC.
Current builds
Completed works.
thanks OC......and thanks to those who hit the like button :)   your Chinook should be a rather large model....what scale is it again?  but yea.....with the tail and wing on it,  it is a fairly large model.  last night,  I though to get the windshield framed out.  I was in Michael's the other week,  and I bought a package of Testor's pin striping tape.......comes in three different widths.
looking in the background,  I did the frame around the roof section and the center divider.  I'm adding the side columns here.
the frames are really faint,  making it hard to mask them off.   there are sliding windows on both sides that needed to be done in two steps......down and the one that boxes this window in.
I did a dry fit over the cockpit........
here it is with the wing dry fitted on.......
the vent has bee painted :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
My Wokka  is 1/48  scale  mate,    your  windows are looking  really nice mate.
OC.
Current builds
Completed works.
OK....so your model is just as large as mine.  I'm pleased with the way the tape worked out......and to think,  I usually did it by hand.  I was amazed with how light the frame detail was on this model......I thought it would have been more defined.  I did the roof square with normal masking tape.....it did alright,  but the other frame parts needed something more 'pinpoint'.   that and I didn't want to see the tape stripping off what I already laid down.  I gave the first part of the process a day or two to cure before I did anymore....the rest I only gave it an hour or so.
anyway.......I have more progress to report.  I started to work on assembling the narcelles to the wing.   first was to cement the pods in place.
the spinners were added to the rotors......
since I wanted to build her with the rotors in the raised position,  I had painted up the actuator arms that connect the narcelles to the pods.  they are affixed to a pivot.  if I built her with them in the fixed wing position,  I could've omitted the actuator arms...but I like to use as many parts as possible.
there are still a few touch ups I need to do........
for the grand chuckle......I thought do a dry fit of the state of her affairs.   one thing's for sure......I'll never get 'er back in the box!  :D
I'm going to have to see about getting a larger crane lamp........there is simply not enough light at the desk!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Looking good Denis   - certainly taking shape now.
OC.
Current builds
Completed works.
thanks OC :)    thanks all for the likes!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I got some time in on her today......mostly painting and some decaling.  added a few parts to the nose as well.....
I also added some {what look like} lights here too......but the pictures were too blurry and I chucked them.  for decaling,  I added the insignias to the wing and started to add the stripes on the rotor.
there is a bit of a snag here........on the rotors are some white stripes.  here is what the decal detail looks like for the rotors.....
it is a bit of a crap shoot how far to place them.....did it with a ruler.......look good on the top.........
but underneath is another story.......they kinda fall short....
here I have two options.......I can leave them as a single stripe and patch them up with the second set,  or I can bridge them with some paint and do the second stripe.  had to go Christmas shopping for the admiral,  so I left it here to ponder over.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
