  • 10 months later...
Long time since last post. frames finally ready/symmetrical. Bearding line chiseled in. As seen on @gsdpic's build log, the laser etched lines are way off. Not only is spacing for frames too wide, the rabbet line was set way too low. See picture, I had to sand down between frames N and M to make the garboard plank fit correctly to the bearding line. See the difference between frames M&L. Roughly a 1/16th to 1/8th inch difference. I will have to sand down all the remaining notches to match.
Edited by Sterlingclements
I missed this build log until now.  Looks like you are off to a great start.  That framing jig looks like a lot of work but I am sure it will serve you well, and reduce the stress of gluing the frames to the keel.  The aft skylight deck beam assembly looks great....I remember really enjoying that part of the build.
All deck beam assemblies complete, with the exception of the cockpit assembly, which is the most complex one. It is under construction at the moment. Thanks to gsdpic's log, I took extra care drilling and mostly sanding the various holes. Pretty satisfied with the results. I plan on leaving the deck partially unplanked, but do plan to plank the center rows....about as wide as the mast pads.
At long last, after checking each measurement multiple times and  dry fitting deck-beam assemblies to verify timberhead heights, I began glueing the frames to the keel. I started with frame 18, just fore the break in the deck, and worked my way forward through frame 1. I took my time making sure that the frames were not only square to keel/horizontal but were also symmetrical in height port/starboard and in width from center line to outboard edge. Results pictured below, including temporary installation of sheer clamp so I can further check planking fit and complete any touch-up fairing as needed. I also included pictures dry fitted deck-beam assemblies and a few keel-line views.
Master piece. Do you plan to plank it fully? Would be shame to cover that magnificent work completely.
"A smooth sea never made a skilled sailor."
Completed: Smuggler
I do not plan to fully plank. I plan on doing a couple rows of planks on the deck center line and maybe one or two outboard. I plan on 1 to 3 rows of hull planking top and bottom. Need some planking to attach rigging points/deck furniture.
Great craftsmanship.  I’m about to pull the trigger and order the kit so I’ll be a few months behind you and will be referencing your build log quite extensively.
Keep up the good work and please keep posting.
Much appreciated
Bill
Looking very nice!  I struggled a bit with the transom but yours appears to be in good shape and good alignment.
Just curious what kind of surface prep you did on the companionway before applying the tung oil.  I've always liked the look of that finish and yours looks great!
Dan
very nice hullbuilding Sterlingclements,
looks like you have chosen a good and recomenable kit, congrats
Nils
Current builds
-Lightship Elbe 1
Completed
Dan
Just progressive sanding, with final sanding using 400 grit. Then apply tung oil with a lint free cloth, rub it in like car wax. In the above pic, the sill piece directly aft of the companion way doors (and fore the cockpit grating) is dry, no tung oil, for a good comparison of what a difference the finish makes. Both sill and companionway are made from the same piece of mahogany stock.
