Centurion Mk.1 by Baker - Airfix - scale 1/76 - PLASTIC - an Airfix Centurion conversion
This will be an attempt to convert an old Airfix Centurion (Mk.8) into a Centurion Mk.1
General Centurion info: Wikipedia  https://en.wikipedia.org/wiki/Centurion_(tank)#Centurion_production_mark_numbers
While looking for parts for another project I came across this old "box with parts". And i knew I once had a description of how to build a Mk.1 "somewhere".
This will be a build that will end in one of 2 different possibilities.
1: A model in the cabinet
2: plastic waste in the trash bin
Base
An Airfix Centurion. An Airfix magazine from 1977 and a book Centurion in action from Squadron / Signal publications.
20201223_190810.thumb.jpg.ef66349bbb5d21fca46e1947e5896859.jpg20201223_190822.thumb.jpg.4fc7a8d172d85ebeffefff042ee847c7.jpg20201223_190835.thumb.jpg.291bd3fce2cffbf0bbac5a9e3f800007.jpg20201223_190852.thumb.jpg.28e138d74ee4d5ae83975f89ce92cb14.jpg20201223_190857.thumb.jpg.c7e181990909b2ba0d3eb542c48e887e.jpg
The hull of the Mk.1 & 2 was longer than the later models. This is also stated in the Airfix description.
Plastic Surgery needed...
20201223_192840.thumb.jpg.b843d5a18d6ea2cf0baf7ee06af10625.jpg20201223_194020.thumb.jpg.769c7cce150e5be8f48b75b61515689b.jpg
Let dry, and fingers crossed for a successful build :Whew:
I understand fully, but I think you've got it handled Patrick....
Ambitious project.....
Quote:
Was this from one of Airfix  poly bags (some were not put in boxes  but were in a clear bag with a stapled piece of card along the top)   dating from the 70s?   if so I too have built one of these  as a kid.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
14 hours ago, Javlin said:
Cool! :imNotWorthy: Kevin
10 hours ago, Canute said:
Very nice, a kit-bash. I'm in, too.
Thanks everyone and welcome
I think so, and it did come out later in a box.
With few modifications, different models can be made, and I think the kit in the box represents a Mk.5.
My Airfix Centurions
178 463/BG73 Centurion (10,5cm diesel)
179 539/GB81 Centurion Mk.2
180 544/GB82 Centurion Mk.3
181 58/GB10 Centurion Mk.5
182 646/GB94 Centurion Mk.5/2
183 1414/GB176 Centurion FV-4005 18,3cm
That is one Lethal box Patrick!
I would think that with that many completed Centurions there is a possibility you may be the local expert on the design.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Thanks,
Airfix sells / sold this kit as a Mk.8. This is certainly not a Mk.8, but a Mk.3 or 5.
Extending the hull was successful. Reinforcements have been added inside, so later on there is only some cleaning here and there.
The chance that this model ends up in the waste bin has become very small :Whew:
20201224_165605.thumb.jpg.d8afd03fd311f20ae3880b9ee6192d4d.jpg20201224_165619.thumb.jpg.4d5c58c782b2aba2cc4a744a40b34480.jpg20201225_112115.thumb.jpg.6ba261019121cb8ab08e870679af24fd.jpg20201225_112122.thumb.jpg.2eff0b6d7d82f786f935a0906b7f3af4.jpg
Discovered something, this build cannot go wrong
The kit was "born" in 1964 (and that was a very good year ;)
Thanks for following,  and a merry Christmass and happy new year
Edited by Backer
A very good year indeed 😁 I'm in Patrick
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
After the top plate was applied, cleaning and sanding of the hull started (with a too sharp knife 👍👎)
The mudguards are cleaned up, extended and glued
20201228_191108.thumb.jpg.ff2a19c2f1234b3dd4105278c03c5f8e.jpg20201229_185959.thumb.jpg.c064614158fe19a44aaa85ce28d0c4a1.jpg
The upper part of the hull is adjusted and the engine exhausts extended. And i have a full bag with new clamps.
Extra detailing on the hull. A previously built Mk.3 serves as example.20201230_194708.thumb.jpg.8a152f67d20568e9591bf0712fee0f0d.jpg
I will see you all back in 2021  :champagne-popping-smiley-emotic
Edited by Backer
Ouch.... I hope no stitches were needed.  There's an old saying around these parts... "there will be blood".  Luckily, it's not always enforced.
Finger healed 👍. And continue to build the Centurion.
Additional details on the front and top.
20210105_185922.thumb.jpg.b9c8219b814f95775c5fd2724847fbe1.jpg20210105_185952.thumb.jpg.d5436f8357ba70fe22b36028324064b6.jpg
Now we will continue with the back and the top of the engine compartment.
Thanks for folowing .
very nicely done Patrick!........love what your doing here!  ;)   I've had a few cuts in my day........glad you healed up OK :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Continue with the hull.
The modifications for a Mk.1 on the engine compartment with plastic strip
20210105_193922.thumb.jpg.3c1787442a636e64cfc28bec1241c855.jpg20210107_194623.thumb.jpg.cbdd9eb2f20ca97e3eaec425d42d7622.jpg
Extra details and cabels at the rear.
the Turret ..
The author of the article explains the construction method very well. Unfortunately, it does not provide any dimensions or clear construction drawings.
That is why we start with the bottom plate and some "frames" as supports for the sides and tops of the turret.
20210108_192817.thumb.jpg.f9f288a45c0185618a1e3856b3450390.jpg20210108_195051.thumb.jpg.17ab6d1c08b8fb6e0b137e06fed6546c.jpg
To be continued, thanks for following.
sounds as bad as I am........I never write down measurements :blush:  I take it for granted concerning the scale I'm working on and try to stay with the scale.  as you've done,  it's always best to start at the bottom and work your way to the top  ;)   it does appear that your working from text,  so at least you have something to work with.  very nice detail work!
I just noticed it.......but it appears that your missing a tooth on one of the track sections on the front of the body {left one}.    looks easy to add one :)   I'm not nit picking,  but I can see your a man of perfection ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Well spotted 👍    Went to the dentist to get a new tooth for the Centurion 😬🤣
The turret (the basic shape) is made of plastic plate and plaster.
Yes plaster on plastic. I have been using it for over 15 years and am very satisfied with the results.
Building the turret
20210111_191902.thumb.jpg.028415c115e7f45eff70934f6e8a1695.jpg20210111_195454.thumb.jpg.3af971b4e2cade60cc91d4a173556e5e.jpg20210111_195506.thumb.jpg.0fa4979a255ba983c4cd871da0bc6124.jpg20210112_193436.thumb.jpg.5afa0dd2e2769dc476ab761867c8c79b.jpg20210112_200326.thumb.jpg.09c93dda280d3101c83b55e5d0e64fe0.jpg20210112_200338.thumb.jpg.4b53943bf152a19ed7ac4aae15509846.jpg20210112_203925.thumb.jpg.23c18e1b55563ad7f936801a28ad5115.jpg20210114_182241.thumb.jpg.d9147545a6db4ef8109dd54c4f20b596.jpg
Dimensions look ok
But the rear needed to be made thinner.
the basic shape of the turret is ready, he looks pretty ok to me
20210115_193921.thumb.jpg.9779842ea952290b3652d4165ffb70f4.jpg20210115_194430.thumb.jpg.e3a1c24994a4c31e7bdddf9b17a279de.jpg
To be continued, thanks for folowing
Neat idea Patrick, is that just basic ready mix Polyfilla?
Great work on the scratch elements 😁
Current builds;
Completed:
Yes, a ready mix.
With a lazy Saturday and bad weather. There was a lot of "Centurion time".
Building the mantled and a"canvas" cover from tissue
20210116_145839.thumb.jpg.63182dc0ecb5e38caf5eb33b12d83927.jpg20210116_150210.thumb.jpg.3ffc630b313a8e332b76e1cf3e41266a.jpg
Discovered a 17 pounder in the parts box (ex M4 from Matchbox)
20210116_152835.thumb.jpg.5ff1fa0a224b9ea9a16da6c26e8cce9a.jpgToolboxes are made from lamineted plastic sheet
20210116_170516.thumb.jpg.c0aa29a4ad05d1fb3d8d47f3aba4323f.jpg20210116_185359.thumb.jpg.b6ac1d8ac4d70e5cc5f3f44f67fefb39.jpg
Hatches, ventilator and MG mount20210116_194659.thumb.jpg.8a03f7bd7f8c662cfeaa4b3f627f5861.jpg
Current status of the model  20210117_183829.thumb.jpg.abae0fe0c312fa066a278c35a118e6d0.jpg
20210117_183843.thumb.jpg.a38b97ce6d4330dea7c1b8e6f13ff094.jpg20210117_183855.thumb.jpg.89e88fa82bb1f0f961bae4ed74bfa2b1.jpg20210117_183907.thumb.jpg.751b65bcf6e74f3dc74b3df0a58c0a9b.jpg
This little experiment is going in the right direction.
Amazing bit of scratching there  - looking lovely.
OC.
Current builds
Completed works.
You know as well as I do brother, once you learn to scratchbuild you can build anything in almost any scale with the proper references.....
And your a master at it....
AS far as following, I wouldn't miss it for the world my friend.....
Quote:
That's an understatement. Nice work Patrick
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
OC.
On 1/18/2021 at 3:09 PM, Canute said:
Great job enhancing this conversion, Patrick.
Thank you, thank you .Far too much credit for me 👍
I came across another abandoned project.
A batch of M29 's.
One example in resin (no manufacturer) bought somewhere long ago at an exhibition of IPMS.
Stupid me sold the series of magazines ( Vehicule Militaire International) which contained the building descriptions. And did not make copies :default_wallbash:
This will probably be a project for next winter.
Can't keep you down mate   - more the merryier.
OC.
Current builds
Completed works.
A batch of M29 's.
489th transportation company, US Army October 30th 1944, Tacloban, Leyte.... Red Beach One....
Ducks and Weasels..... Serving up supplies for the 24th Division.... 19th Infantry.....
My father was there....
Quote:
17 minutes ago, Canute said:
Maybe those magazines are archived online somewhere? A research project.
Perhape we can have a look online for them?
OC.
Current builds
Completed works.
I found this  not sure if it will help?
http://www.peachmountain.com/5star/Tanks_Patton_Tanks_M29_Tank.aspx
OC.
Current builds
Completed works.
