David
It may take a few thin coats, but I will be able to get it done. In all of the contemporary pics of these schooners, the chainplates and lower deadeyes are always painted, so this is really the way to go.
Russ
considering the scale of your build Russ.........they look very good!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks. I am taking refuge in the scale limitations and a coat of paint. :)
Seriously, I am hopeful that I can improve on this method as time goes on. It is always a learning process.
All the same, I think the next one will be at the larger scale. That will make things a lot easier. :)
Russ
A fellow modeler I know who goes for 1/350 WWII once told me that a well done coat of paint and hide a hundred mistakes.
David B
Edited by dgbot
The late great Donald McNarry said a good job of rattling down would hide or at least distract from a multitude of mistakes
Drown you may, but go you must and your reward shall be a man's pay or a hero's grave
Michael:
That sounds like good advice.
I hope to one day be able to do a better job at this scale. Practice makes perfect they say. I will settle for pretty good.
Russ
Sam:
Thanks for those too kind words. I am learning new things with every part I make. That is one of things I love about model building.
Russ
The main deadeyes and chainplates have been fabricated. I still need to make the cap over the edge of the railing. I am not sure if I will stick with these assemblies or give it another try. I am concerned about the inconsistent height of the deadeyes. Once the assemblies are painted, they will look okay, but....
Late tonight I decided to make a few more deadeyes and broke two consecutive pieces while making them. That told me to walk away and try again tomorrow.
Russ
Edited by russ
Having looked at the photograph and thought about it a bit, I have decided to do some experimenting to try and improve my technique for these deadeye and chainplate assemblies. They just do not look very good. I will let you all know how it goes.
Russ
Russ,
She does look good, beter even. Your remark about the deadeyes and chainplates made me ponder on it too. The deadeyes do look a bit small compared to the chainplates ... If you made the chainplates of soldered wire, would that not be more in ratio?
Carl
Carl:
Thanks for looking in and your kind words. I have been remaking the chainplates this afternoon and I will post photos of them later. I think narrower chainplates are what was needed. The wider chainplates made the assemblies look rather bulky.
Russ
That's exactly what  I meant. I'm looking forward to see your solution!
Carl
Here is a second pass at the main deadeyes and chainplates. The chainplates are much better in that they are nearly right on the design width, about 3/64". The height of the deadeyes above the rail is good and they are just about equal in height. I think once the cap is in place and everything is painted, this approach will work. The key for me is to keep the chainplate width as close as possible to 3/64".
Russ
Russ, one of the ways I have used for making brass stripping is to cement the sheet between two pieces of wood with contact cement. Then I would cut to width on my Preac. I have gotten down to 1/32 many times
David B
David:
Thanks for the suggestion. I have no problem cutting the brass strips. I have a handy pair of scissors that can cut just about anything and they do so without rough edges or distortion. I just need to pay more attention to what I am doing. I designed them at 3/64" wide and I lost track of that number as I was having too much fun drilling holes in the chainplates and soldering pins in them.  :)
Elia:
Thanks. I am much happier with these.
Thanks for the all the likes as well. I apologize for this bit of tedium.
Russ
Edited by russ
Russ,
I dont know about anybody else but the "tedium" doesnt bother me at all. I enjoy watching the process, it helps me learn.
and they look pretty darn good to me, even better when I think about how small they are.
Sam
Edited by src
Current Build Constructo Enterprise
  you have to experiment with it............some ideas take more than others  ;)     your second attempt looks very good.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Sam:
Thanks for the kind words. I do not want to bore anyone with my reports. I am glad if something I offer helps. I am always learning from others work here on MSW as well.
Popeye:
Thanks everyone for the likes. I appreciate it.
Russ
Hi Russ , do you have any contact with a jeweler? They have a roll mill. Some time ago I was at My jeweler friends place and ran a bunch of different copper wires through her roll mill and wound up with quite a few different coils of copper strips from the different wires enough in fact for a lifetime.
Michael
Michael:
Thanks for the idea. I have plenty of brass sheet from which I can cut strips of any width I need. It is a simple matter of me paying more attention to what I am doing and, you know, maybe checking my own plans every now and again. :)
Russ
I enjoy watching your build.
And I was wondering - When is the boat show?  I still want to see photos of the real boats (or replicas).
Cheers.
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
Ken:
Thanks for dropping by.
The boat show was back in May. If you look in the Model Ship Clubs and Exhibitions and Events forum there is a thread where I posted photos of the Billy Creel Memorial Wooden Boat Show.
Russ
