Here's a more recent update. To build the Rodney with the Admiralty camouflage dating 1942 and beyond, the Pontos set is essential, since it incorporates all of the changes made to the ship. For example, around this time she had 17 20mm Oerlikon cannon, but the kit only provides 13, as well as the quad 0.50 machine guns which were deleted. There were also changes made to the bridge structure, and more pom-pom directors fitted. While the Pontos set is expensive, I figured that since this is going to be my one large battleship build, I might as well go for it. Hope you like her so far!
Cheers,  Tom
Edited by uncarina
uncarina,
Very nice work on the photo etch. The photos of the Walrus aircraft sitting on top of that turret made me wonder if they flew it off or removed
it before they fired those cannon...seems like if it was still on there the blast would shake that fragile air frame to pieces - any ideas on that?
I'm not well-versed on battleship operations.
What a Fantastic looking build  - can't wai to see more,    Warm welcome  to  the   "Plastic play Party"
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
2 hours ago, Shotlocker said:
uncarina,
Thank you! I'm using an Optivisor, two viscosities of cyanoacrylite, acrylic floor polish, bending tools, several tweezers, muttering, and some patience! They would remove the aircraft from the turret and stow it; even so, I imagine the blast would be a maintenance concern.
Cheers,  Tom
49 minutes ago, yvesvidal said:
Excellent choice on that newly released kit. And what a wonderful display of clean and fresh brass..... I feel like it is going to be a pity to paint all these beautiful parts.
Your craftmanship is absolutely beautiful, clean and precise. Bravo!!!
Yves
Yves, thank you so much! I agree about the painting...if the Rodney did not have such a great camo scheme I would certainly hesitate. In the meantime, I have to take photos of what lies underneath! Thanks for your support.
Cheers,  Tom
Yves, absolutely, and you are very kind! I use an Optivisor, a Xuron photoetch cutter or rounded X-Acto blade, a Smallshop photoetch bending tool, and several different tweezers. For adhesive I use gap-filling superglue, low viscosity superglue, and Future acrylic floor polish. I actually prefer to use the last whenever possible because it is more forgiving for positioning and removal. Otherwise, it's a mindset for the Pontos set: approaching each piece as a separate kit!
Hope this helps,  Tom
Yves, I find it to be pretty useful: as a durable clear coat for adding decals, as a barrier for enamel weathering washes, to protect and enhance the clarity of transparent parts, to simulate clear glass in instrument panels, and most recently as an adhesive and sealant. Plus it can be thinned with ammonia. Haven’t tried it on floors yet!
Cheers,  Tom
Same as Yves,    very nice work.
OC.
Current builds
Completed works.
6 hours ago, yvesvidal said:
It is just superb. I love your PE skills.
Yves
Thank you very much! After working extensively with 1/350 photoetch, it’s easier (many parts are larger) and harder (there are more subassemblies)!
OC.
Thank you!
Cheers,  Tom
