The photoetch for OREGON arrived Thursday and I checked it out today, so Tuesday I'll be back on OREGON.  The development log (DLOG) for WYOMING will go into hiatus for a bit.  The development of the OREGON kit was fairly well along before I decided to create these logs, so I'll be including some prior work just to give you an idea of what transpired before.
The photoetched brass comprises three sheets: .005", .010", & .020".  Here are partial scans of each sheet (reduced):
.005" - turret rings, 6 pdr shields and shoulder rests torpedo tube covers, deck plates for various fittings, crane parts, coal scuttles.
.010" - inclined ladders, gunner's grates, jacobs ladders, bow shield, 6" casemate covers, hatch covers.
.020" - awning stanchions, main deck stanchions, railings, searchlight platforms, binnacle tower.
One of the initial challenges I came across in the early stages was the prominent anchor bills.  They are angular and have some difficult angles where the wedge shape meets the vertical walls.  I tried carving them into the hull, but wasn't satisfied with the outcome, as they weren't exactly the same.  So, I decided to cut a channel across the hull and laser-cut inserts that ensure consistency - worked much better.  There are two pairs of lifts that allow the builder some adjustment capability incase he/she didn't shape the hull quite to specs...🙄  The inserts are separate, as well, so the angle can be shaped before they are inserted.  Once the basic assembly is complete, the hull is filled and finish-sanded to shape.  A laser-cut deck of glued-up decking will be fitted, so the lamination does not affect the appearance.
These are the inserts, before (left) and after (right) shaping.
Lasered lifts for the anchor bills.
This is what it looks like much later in the process.
Edited by alross2
There are a lot of airports in the hull and little looks worse than a wavy line of them.  The kit includes laser-cut templates that are taped to the hull at the deck level with drilling dots that are inline and at the correct depth below the main deck.  Once taped in place, an awl is used to mark the centerlines.  The holes are drilled out with a 5/32" drill bit, lengths of aluminum tube are inserted into the holes and glued.  When the hull is finished sanded, the tube will be flush with hull sides.
Edited by alross2
I recall seeing a very nice large scale (1:96 or 1:48?) model of the USS Oregon in the maritime museum in Astoria, Oregon, about 45 years ago. I visited again a few years ago and the model wasn't there any more. I have no idea what happened to it.
Phil
Current build: USS Cape MSI-2
that looks fantastic
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
A test assembly of one of the exposed 6 pdr guns, less shield. It's a bit rough, but I was fiddling around with the pieces trying to figure out the best assembly sequence. It came down to lightly gluing the base and pedestal to a piece of masking tape around a stick, inserting the gun peg though the hole on the legs, gluing that assembly to the pedestal, cutting away the arcs holding the ends of the legs, bending down the legs with a hobby knife, gluing them to the base, and trimming them with the hobby knife. The tape is removed from the wood and trimmed away from the gun. It's a bit of a fiddly process, but comes out fine if you take your time.
Might I suggest some little laser cut ribs, to go inside the gun base, so you can bend the brass stock curves, smoothly? They could then be removed after the base is completed. Perhaps one set could be reused for the other bases.
Ron Thibault
On 4/7/2021 at 1:05 PM, Roger Pellett said:
Al,
What is the scale of this model?
1/128 (3/32" = 1')  Same scale as the MAINE and OLYMPIA kits from 2005, 2006.
I may make a resin plug as a bending jig.  If that works, I'll include it in the kit.
Today is going over the drawings day, checking out what's already done and what further ones are needed.  Because this is a solid hull, I'm including hull templates that are laser-cut from poster board.  It'll save the modeler a bit of time and expense.  In addition to the hull sections, there are templates for drilling the air ports, the stanchions, and a few others.  There are two more sheets besides this one, those being the plan and profile with stations.
One or two of the plans will be the normal large sheet (the general arrangement plan is 28" x 40"), but most will be in a spiral-bound booklet of 11" x 17" pages.  The drawings on the smaller sheets will be full size, so measurements can be taken directly from them.  The smaller size is just handier to use and doesn't take up a lot of workbench space.  It also isolates each component, making it less confusing than an overall drawing.
The large sheet (not quite complete) showing the overall model.  I still have to add rigging and a few other details.
A few of the 11" x 17" sheets will have a couple drawings due to the small size of the item being assembled/built.
Most of the 11" x 17" sheets will have a single topic to be addressed.  Both the main and superstructure decks have the positions of the various components laser-etched on them, making placement a bit easier than trying to measure everything.
Edited by alross2
A couple more drawings today.  These are for the 6 pdr guns, of which there are 18.
This is in progress and will eventually show the construction details, most likely in a larger scale as no measurements are needed.
For the superdetailers, I've done these in 1/32 scale, along with an actual size drawing.
Edited by alross2
I do like jigs. This is a simple one I created this morning, but it will be a time saver. It is for locating the bilge keels on the hull. When viewed from below, bilge keels run parallel to the keel. Because of the shape of the hull, when viewed from the side, they usually form an arc and this is sometimes difficult to achieve correctly. To use this jig, you place the line on its center on the centerline of the hull, drop a pencil through the holes and mark the position of the bilge keels along the hull at each end and the center of the bilge keel location. You then use a batten and pencil to connect the dots and it will give you a fair curve.
those jigs will save someone so much time
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
The pilot house itself is not a complex assembly and is built upside down over a form. The angled cuts at the back of the form are to prevent the sides from sticking to it when they are glued together. The sides are .015" laser board, which bends well.  The bluish green items are clear styrene strips which will be inserted after the pilot house is assembled and painted.
I always cut a slot for the bilge keels as it is sturdier than just gluing them to the surface of the hull.  After using the marking jig and using the batten to form a fair curve, I cut along the curve at about a 45 degree angle with a hobby knife, then use a slot head screwdriver to widen and deepen the knife cut to 1/16" or so.  If you take you take your time and don't force it, the screwdriver works well.  Once the slot is incised, you can dry fit the bilge keel in place to ensure fairness, adjust the slot if necessary, then glue the bilge keel in place.  A bit of filler will take care of any resultant gaps.
Edited by alross2
This one required some rework, but should be OK now. It shows the layout of the hammock storage structure. The gunner's grates are only 3/8" x 1/2", but are photo-etched and have the holes completely through. When not in use, they folded down. The pale yellow on the lower section represents silkspan which is used to simulate the canvas curtain over the hammock storage.
