14 hours ago, rvchima said:
Harry,
The guns look just fine to me. They are parallel  to the deck and to each other. When everything is painted they will look perfect.
Rod
Thanks Rod,
Moving on with the build.... 🙂
Location of parts over multiple "Issues" takes time and careful consideration. (Final Turret components.)
Not a rapid build at all.... Never mind, it's not a race either.... 🙂
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
Hi All,
Update:
Completed Main and Secondary Turrets and Guns.
Lots of masking and tiny bits of PE for the Secondary Turrets.
The only problem was dropping a small plastic Periscope for one of the Mains. I searched for a ages but to no avail.
Made a replacement from a bit of sprue, not perfect but they are so small that I don't think anyone will notice.
I think that the Mains could do with a bit of a "Tickle" where the wooden circular bases have a "Step."
I'll give all Turrets some Semi Gloss to protect.
To round off the day, I'll finish constructing the Forward Mast and have a play with the Boats.... 🙂
Cheers....HOF.
Photos:
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Looking really nice.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Thank you Sir....
I think it's getting somewhere slowly.
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi All,
Bit of an update, HOF has been working on Ships Boats.... 🙂
So, seven of the eleven are now what I'm going to call complete.
Two Dinghy's and two Longboats were easiest until I decided to re-paint the internals with Vallejo "Wood Grain"
A very careful removal of the PE was a heart in mouth time....
The Motorboat was next being the smallest, tiny PE but a good learning....
Two Launches, quite complex but I got through o.k.
(The Bow PE piece did not want to play nicely at all so I made my own from Brass Wire for both Launches.)
All propellers were a pain to fit onto thier Shafts, in the end, I opened up the hole in the center of the Prop, it made things so much simpler.
The Boats look a little untidy, (In my mind.), up close but look much better viewed "Normally" if that makes sense.
(My hat is very firmly off to those that build 1/700 scale!! 🙂)
I now have the four "Service" Boats to complete and I guess on to Forward Superstructure PE. (Unless I go down another Part-work rabbit hole!!)
Cheers....HOF.
Photos:
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi All,
Small update:
HOF has been playing with Boats again.... 🙂
Spent the day finishing the four Service Boats.
These went together o.k., not too much PE, just enough to keep me honest!!
As I mentioned to Rod, (rvchima), these won't be mounted on the Ship for some time yet but good to have them complete.
(It's another 4 magazine "Issues" out of the way.)
Eleven Ships Boats total count.
I think tomorrow, I'll deal with a partly consumed PE fret containing components for the Funnel Searchlight Platforms and a coupe of Ventilators that will get mounted on the main Hanger....
Cheers....HOF.
Photos:
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi All,
Small update:
I have fallen into a bit of a "Part-Works" Rabbit Hole....
Not too bad though....
Got through two further "Issues" but took me a couple of days.
  • Constructed and installed a couple of Ventilators, Port/Starboard by the Main Hanger Doors. (Why this could not have been a molding, we'll never know.)
  • Constructed and installed Searchlight Platforms Port/Starboard funnel, (11 PE pieces each) Platform,), and installed Searchlight Covers.
I am now left with a complete PE Fret that covers the previous two "Issues" that deal with the Admirals Bridge and associated Conning Tower.
I am pretty sure that I'll get this out of the way before Sheathing the Forward Superstructure.
I'll post some photos after the Conning Tower PE is attended to.
Cheers....HOF.
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi All,
Small update:
I'm about 1/2 way through installing the PE sub-structures on the Conning Tower, more tiny bits to go....
Admirals Bridge Platform and Railings complete and given a bit of paint as this will be covered.
That's about the size of it for the morning.    🙂
Cheers.... HOF.
Photos:
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Forgot to mention,
I'll have to develop someting to hold the Conning Tower....
The more PE that gets added and the more "Protrusions" the easier that it is to accidentally knock something off!!
(Been there, done that.... 😀)
I'm thinking of a blob of "Blutack" on the plastic base onto a small block of wood....
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
19 hours ago, rvchima said:
Those supports on the side of the funnel are really hard. Congrats on completing that bit.
Rod
Thanks Chap,
They are not prefect but they will do.
I agree, they were a ral pain..
I am finding that the PE for the Conning Tower is more of a challenge....
I should be able to complete this step today, (Hopefully), but not all of it as this is the method that Partworks use, they  "jump around...."
If I try and complete fully, I'm going to have yet more bits to "Put aside."
I found the Hanger Boat instructions in the next installment,, (119), and, the Jig.... We'll see how that goes....🙂
(As you found, it looks like I'll have to move the Ladders on the Hanger.)
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Keep at it  doing  really  well.
OC.
Current builds
Completed works.
OC.
Thank you Sir....
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi All,
Small update:
PE now complete on the lower Conning Tower. (Don't know why the instruction call this a "Mast.")
When I say complete, I left 4 pieces off, Webs under the Central PE Platform, no biggie, no one will notice or look for that matter.
I managed to break the RHS Rear Platform Railing, so made a replacement from 0.5mm Brass Wire, as with both Rear Platform outer Rails, I got fed up with trying to balance these on the Platform edge waiting for the CA to set-up and after loosing one to the "Carpet Monster" I decided to make my own.
Don't know what the Rectangular protrusions are on the Rear Platforms but the instructions call for them to "Articulate" and they do....🙂
The whole structure in "The Raw" looks really scrappy but I think that a judicial application of Acetone and  dose of Light Grey will make things a whole lot better and hide the misdemeanors.. (I'll do that tomorrow morning.)
I found this structure really "Fiddly" and did not assist with my usually calm countenance. 🙂
(It's also reasonably fragile, so care necessary when handling.)
Cheers....HOF.
Photos:
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi All,
Cleaned up and gave the Conning Tower and gave it a dose of Primer.
Not perfect but better than it was.... 🙂
(It is what it is.... Just noticed in one of the photos the top PE ring on the Starboard side needs a "Tweak.")
I can now move on with another "Issue."
I think that I'll have a go at the Hanger Boat supports and see how that goes....
Amati/Partworks supplied a bit of strip wood to construct a Jig for these.
Cheers....HOF.
Sorry to plague you with Conning Tower photos....
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
I need to stop "Stressing!!"
I placed the Conning Tower structure on the Forward Superstructure.
Once done, any tiny errors disappear with the sheer size of the Ship.... 🙂
I guess I'm being over critical and striving for perfection.
I have to remind myself that this project is also my first serious foray in the use of Photo Etch.
HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi All,
Small update:
Decided to assemble the "Service Boat" storage racks that will be positioned either side of the Main Hanger.
(The other two Service Boats are accommodated on the Hanger Roof.)
I assembled the Jig last night and used some candle wax on the surfaces of the Jig that would be exposed to CA.
The Jig worked o.k. in terms of correct spacings but required a small clamp to prevent things moving around.
(Even though I have not yet fitted the Racks yet, I'm reasonably confident they'll fit with ought too many issues.)
Cheers....HOF.
Photos:
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
First of all, I love the photos with all of the PE pieces laying around on the black background. It looks like you took a fire cracker to your model like we all did when we were kids.
Second, I don't know what those things are either, but they are a pain to deal with and just hang off into space on the finished tower. You could consider just gluing them down.
Finally, your jig for the lifeboat racks is brilliant! I wish that you had gone first so I could copy. Now be careful not to bump those flimsy rails.
57 minutes ago, BobG said:
That's some fine work on very small, storage racks, Harry!
Thanks Chap.
The reason that I bothered to post this was that the Amati kit does not seem to provide a Jig for this particular element but the Amati/Partwork version does.
So, in order for those attempting the Amati Version, they may wish to construct the Jig.
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Thanks Rod,
I will try to ensure that I don't make any sudden movements around the Rails!!
Before I install, I need to ensure that the Superstructure is prepared as much as possible....
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Very interesting! It's too late for me but it might help someone else if you could post a drawing for the jig.
Hi All,
Small update:
So, progress has been a little slow, due in no small part, to battling the COVID thing.... ☹️
I climbed back into it today and made a start on the forward Superstructure. (Jumping back many issues.... After clearing the Decks and placing sub-assemblies into secure storage to mitigate any accidents....)
The exposed Decks, (No Printed Deck covering), I gave a dose of Sanding Sealer as I want to minimize any grain showing through post painting these areas. (I extended this to the Aft superstructure "Painted" deck areas as well.)
Up until now, I had not attached the Fore Superstructure Decks, (1st Tier), I am pleased that I did so as the aft structure was slightly "Racked" but pulled into alignment with lots of clamps....
I guess when I sheath this stuff it will show any issues, I hope not!!
About six "Issues" should see the Brass sheathing more or less completed.
So, onward.... I'll post some photos in the next few days.
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
1 hour ago, hof00 said:
Hi All,
Small update:
Cheers....HOF.
Sorry to  hear you have been  rough with the  (thing)   all the best   plenty of  vits  is the key.
OC.
Current builds
Completed works.
OC.
Thanks you Sir!!
Good to be back at the workbench, great for the mind, body and soul....🙂
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
I'm sorry to hear this, Harry. I hope you're on the road to recovery.
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Thanks Chap!!
All good thanks, performed a RAT Tuesday - Now negative.... 🙂
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Wow! what a build.  very impressive - and it looks very small and fiddley.
Sorry to hear about your illness!  I hope that your well soon!
I wish you the best my friend.
You're an inspiration!
cheers
Marc
cheers
Marc
Thanks Chap,
It's my first model ship with "Guns.... 🙂"
As mentioned somewhere near the start of the log, I spent so much "Coin," NZD $16.95 per issue X 140 issues), years ago, seeing other Bismarck builds here, It piqued my interest in this, time to carry on with it.
Yup, it is "Fiddly" very.... However, I needed to learn more, esp. Photo Etch.
(It's not that small at around 1.4 meters but the PE and other aspects tends to be at 1/200.)
A bit of a departure from models with "No Plastic" bits, (Multi-Media) I think it'll come out o.k. in the end.
The 'Sickness" has thankfully run its' course..... 🙂
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
