On 2/2/2022 at 7:46 AM, DavidG said:
Paul, your model looks excellent. Is it just me, or the letter "N" on the transom is upside down?
You caught the upside down "N" cock-up - Good! Glad you fixed the "X" too...🤣...
Very nice work. This is an advanced kit build and you're doing a great job for only your second wooden model ship.
Edited by hollowneck
spelling
Ron
Former Director, Nautical Research Guild, 2021-2025
@modelshipdood on Instagram
Current Build: HMS Diana Update
Completed Builds: HM Gunbrig Cracker #13 (HM Adder Gunbrig)Grace & Peace (Wyoming, 6-masted Schooner), HMS GrecianHMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
Appreciated
The gunwales look like you didn't struggle too much. They look just perfect.
Just a quick note to check this topic out for when your pictures are upside down:
Ongoing:
22 hours ago, paul carruthers said:
my rudder gap is too large but I’ve not the courage to try and remedy at this point.
What gap? Everything looks good to my eye.
Having seen so many build logs of the Sphinx from Vanguard here at MSW I got curious and went to the RMG Collections site.   The site has every drawing one could hope for to produce an outstanding kit, and Chris has achieved exactly that.   It is obvious a ton of study of these dozen or so drawings was made as the details from these drawings show up on the model.   https://www.rmg.co.uk/collections/objects/search/Sphinx 1775
Allan
That bow shot of the headworks looks good, and I like the white paint scheme of the wheel. 👍
As far as the masting is concerned, if you have a variable speed drill you can use it as a proxy lathe and hand sand any taper required, or if you're using square stock  the razor plane can be used to gradually round the  stick, finished off by hand sanding.
I don't imagine the lower masts will be too problematic because little if any taper is required, maybe some flattening for the cheeks. The tricky part will be keeping the masthead which is square in section true.
Were I doing it, I would cut around the base of the head using a razor saw 1mm deep,  glue a template of the square section on top of the dowel. Pare it down by degrees using a chisel or similar, and finish with sanding sticks, constantly checking the square.
The Topmasts are more tricky, having  an octagonal heel, square head, and flared hounds. On these I would personally start with square stock, as the rounding and tapering are easier to do, but if you're using round stock then a sharp chisel will be your friend. I would mark off each section using Tamiya tape, and begin with the rounding and tapering section between the heel and hounds.
B.E.
B.E.
Thanks for that, I guess slow and measure is the best way as you recommend
Excellent work. The planking, without excessive fill and paint over, is especially impressive.
While I now have a lathe I masted many models with the drill and hand sand method BE described. Just go slow and measure tapers frequently.
Regards,
Glenn
Current Build: HM Flirt
I’ve not posted for a bit, to be honest struggling with shaping the mast profiles but I’m getting there.
from the drawing hilited I’m struggling to understand the band running vertically, is it a metal strip?
thanks.
