Looking for ideas on separating planking and decking sticks by size.
Norwegian Sailing Pram 1:12 Scale. 2nd boat in the learning series.
In Dry Dock:
Muscongus Bay Lobster Smack. 1:24 scale. Model Shipways, 3rd in the learning series.
Not sure what'll be next, probably the Santa Maria by Artesania Latina 1:65 scale. Unless someone has a better suggestion for a beginner.
Pride of Baltimore. Model Shipways. Clipper used in the war of 1812.
Black Falcon. Mantua Model. 18 century corsair brig.
CSS. Alabama. E. Manolie? Can't read the font. Build in Liverpool in 1862 for use in the American Civil War by the Confederates. Steam and sail, sloop of war.
Of all the things I've lost, I miss my mind the most.
A baseball cap my Dad wore.
Not sure exactly what you need help with here. Separating by size could be as easy as measuring the width and thickness of the "sticks" / planks?
Perhaps you meant something else?
Previous build: NRG Half Hull
Previous build: MS Bluenose
Brian,
Which ship?  There are sources based on contemporary contracts and folios with scantlings for beams, carlings, ledges, and the flat (planking) on each deck of various size ships from the late 1600's to the early 1800's.
 If you bought the dory kit designed by David Antscherl, who is a member here, you will get the best help possible and it has a great reputation as a fantastic starter kit.
Allan
Hmmm. I want to separate them and store them in such a way that I can look at labels and grab what I need. I'll measure and keep them separated.
In Dry Dock:
You can use a piece of tape with the size written on it around 1 piece and band them together with a rubber band.
I think I'm going to try to make a box with separators so I can stand them vertically. I could use painters tape to write down the size and when I go to another ship I can just lay down another strip of tape.
In Dry Dock:
  • Solution
Just go down to the hardware store and look for plastic pipe of a diameter that fits what your storing.  Cut into lengths, again to lengths a bit (an inch or two) shorter than the wood.   You can stand them up or lay them on their sides.   They also make end caps so you can pick up one tube and not have the wood falling all over the place.   If I remember right, they have both round and square tubing.
In my shop, I use the square fence post covers, cut down to about 2 feet long and stacked on their side.
Hey, that's a great idea, thanks!
In Dry Dock:
Agree with the tube ideas... I do the same thing!
Lyle
"The only thing that stays the same is the constant state of change"
Completed Builds:
Occre HMS Terror - https://modelshipworld.com/gallery/album/2065-hms-terror-occre/
NRG Half Hull Project - https://modelshipworld.com/topic/23546-half-hull-project-by-lylek1-nrg/
1:130 1847 Harvey - https://modelshipworld.com/gallery/album/2125-1847-baltimore-clipper-harvey-1130-scale/
Scott Miller's Sea of Galilee Boat https://modelshipworld.com/topic/29007-sea-of-galilee-boat-by-se-miller-120-scale-lylek1/
In progress:
Artesania Latina HMS Bounty - https://modelshipworld.com/topic/26817-hms-bounty-by-lylek1-artesania-latina-148-scale/
Waiting for dry-dock space:
Model Shipways - USS Constitution
Master Korbel - Cannon Jolle 1801
A Scratch build -TBD
Similar idea but I use square mailing tubes where I cut an opening in the top. Stackable and I can write what's in them on the front.
 think having your stock lay flat beats every other option
Alan O'Neill
