USF Confederacy 1778 by wernerweiss - Model Shipways - 1:64
  • 2 months later...
Hello modelers,
with this post I continue the gallery with the latest pictures, but first some remarks:
  1. Even if you build very carefully, for example the bow curve of the finished hull may differ from that of the prototype. Due to the bow curve of my model I had to make the shown adjustments with the cheeks to fit on the bow curve. The laser cut cheeks turned out to be too straight, so I hat to reshape them with a rounder curve to fit to the hull.
  2. Regrettably the cast trailboards were not inversely equal. The starboard trailboard was a bit longer, thicker and wider than the port one. This is not what I would call high quality.
  3. My next step will be the installation of the main head rails. Between them runs the so-called head beam, and sheet one shows two knees connecting this beam to the main head rails. These knees are not mentioned in the instructions, so I have to decide whether to omit them or not.
  4. At the end of chapter 15 on page 134 it is suggested that the catheads are glued in place. I would suggest not to do so at this time. In the next chapter the main head rails are installed and for that purpose an appropriate angle has to be sanded at the corners of the beakhead bulkhead showing towards the stem. This is much easier without the catheads as an obstacle for the sanding tool.
See yourself, questions and remarks welcome.
Link to comment
Share on other sites
Hi Werner, your build is gorgeous, everything's so neat and tidy. Very inspirational!
Harshil
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
Link to comment
Really stunning build. I love the yellow ochre on the hull.
Link to comment
Link to comment
49 minutes ago, Chuck said:
Lovely progress....well done.    A pleasure to follow your log on this kit.
Chuck
Hello Chuck,
thank you very much for your personal appreciation! I would never have thought so far when beginning with the build......
Best regards
Werner
Link to comment
  • 2 months later...
Hi folks,
here some pictures showing the progress of the last weeks.....catheads done, main headrails and 10 of 12 head timbers done so far. The middle rails are ready to be glued, and next I´m working on the cathead support knees and their joint segments towards the middle rails.
Regards
Werner
Edited by wernerweiss
Forgot to attach file
Link to comment
Hi Werner, the headrails look fantastic! This is probably the most trickiest part of the build.
Current:
Complete:
On the shelf:
Link to comment
Hello Harshil, thank you very much!
It is DEFINITELY the most trickiest part, especially the curved sections of the middle rails between the bow sections and the support knees of the catheads. The adjustment to the curve of the hull and the transition to the knees demands patience....actually I'm working on the starboard side.
Regards
Werner
Link to comment
Hi modelers,
here the next steps to be posted.....the middle rails and the cathead support knees are done, the framing for the head grating is done, and I started with the grating timbers.
Note the additional stripes along the framing and the main headrails as a support for the framing timbers.
The cathead support knees were notched instead of removing the hull molding stripes.
Greetings
Werner
Link to comment
  • 3 months later...
Dear modelers,
tomorrow my last post is exactly four months ago, and there is much progress with the model. The ship´s boats were placed only for the photos and are not yet glued.
I intend to have the model finished soon, because the next model is waiting....
Comments and questions welcome.
Greetings
Werner
Link to comment
Hello Werner,
Your build is superb!  I have this in my queue and am reading your log with much interest.  I like your color scheme and have a couple of questions about what you've done.  In most of the pictures the decking looks almost like it's bleached.  Did you apply some sort of whitewash?  Or perhaps it's the species of wood if you've substituted?  I've read some information to the effect that an actual deck would probably look bleached out like this.
Also, the red you use for bulwarks and deck fittings looks to my eye like it would probably be more accurate than the brighter reds that you usually see, as iron oxide paint can be pretty dull.  What have you used here?
Thanks and kudos for a masterpiece work!
Rick
Current Build: MS Mayflower II
Completed: MS USF EssexMS USS Constitution Cross SectionMS 18th Century Armed Longboat
Link to comment
59 minutes ago, rlwhitt said:
Hello Werner,
Hello Rick,
thank you very much for your appreciation!
1. No, I didn´t use any whitewash or special wood at all, I just used the provided 1/8 x 1/16 inch basswood stripes. The only treatment was sanding the deck when finished.
2. As red for the bulwarks (Schanzkleid in german) and deck fittings I used red ochre as recommended by Caldercraft especially for period ships, see the pictures below. It is easy to find when you google....
I hope I could help you
Werner
Screenshot(650).thumb.png.0e8e411d435443acc7d4fe030cb0718f.pngScreenshot(649).thumb.png.d940d3597d57080a303994aab90eaddc.png
Link to comment
  • 2 months later...
Hello Werner,
Your model is absolutely stunning and a masterpiece!  I can only hope that my attempt at the Confederacy will be half as good as yours.
Kenny
Current Builds:   HMS Winchelsea   MS US Frigate Confederacy
Link to comment
3 hours ago, KennyH78 said:
Hello Werner,
Hello Kenny,
thank you very much for visiting my build log and your appreciation!
Besides mine there are many other build logs here where you can profit from.
Greetings
Werner
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
