Hi George,
If you want to fix them in now you could do a dry fit with the steps and mark out their new position, remove the steps then fix the cleats in place, if it were me I would fix them now before it gets too tight for space.
I'm not sure how much pressure these cleats are going to take so I pinned and glued mine, that's why I didn't move them, I don't want to do any damage to the deck.
I'm sure the fix whatever you choose will come out looking good.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Here's  where I'm up to at the moment. Can't think of much else that needs
doing on the decks. I might put a couple of carronades on the forecastle.
Not made my mind up yet.
George: Great job on the Agamemnon. Im working on the kit as well and just finishing up the deck furniture on the gun deck. I noticed you used netting for the storage rails along the edges of the deck. What did you use as I was planning to do the same thing and I haven't found anything that gets the look that I want
Mike Draper
Whitehorse, Yukon
Canada
Mike Draper
Whitehorse, Yukon
Canada
Member, Nautical Research Guild
Mike Draper
Whitehorse, Yukon
Canada
I also forgot to mention that I noticed you fully rigged your guns.. good on ya.. I think it always adds that extra level of detail that is often overlooked.
Mike Draper
Whitehorse, Yukon
Canada
Mike Draper
Whitehorse, Yukon
Canada
Cheers Mike for the kind comments. The netting is called Tulle I believe, my niece gave it to me but I don't
think its hard to get hold of.
I soaked it I tea for a while to get a better colour, the original colour was too white. Although black is as good
took me a while to decide which colour to use. the photo's seem to have washed it out but it does look
quite good in natural light.
George
George
George: thanks for the response. I never have heard of Tulle but I will have to look around and see what I can find about it. Did you sew it on or glue it to the brackets?
Again.. a great job at your Agamemnon. a lot of work to get where you are at.
Mike Draper
Whitehorse, Yukon
Canada
Mike Draper
Whitehorse, Yukon
Canada
Mick,
 I sewed it on, not great at sewing but once I got going it wasn't to bad.
George.
Mick,
George.
George: Figured as much.. thanks for letting me know.. I glued on netting on my last project Model Shipways Constitution and it was a bugger to get it taut.. looks like you got the look just right on your aggy...
Thanks
Mike Draper
Whitehorse, Yukon
Canada
Mike Draper
Whitehorse, Yukon
Canada
George,
What a beautiful journey your taking with this build! Hope you don't mind if I jump on board and go the rest of the way with!
What a massive and beautiful ship!
Warm Regards,
Bill
Passion is Patience...and I am a carpenter in any scale.
Current build;  Endurance - 1:70 scale, Occre
Current build;    H.M.S. Surprise - 1796, 1:48 A L
Hi everyone,
Here's my latest update. The stern took quite a few hours to say the least. A few minor adjustments
were needed. The cast decorative strips were poor quality for a kit of this standard and having to join
them was a real pain.
Hi All.
Just a few more pictures, Fitted the lamps on the stern and fixed the figurehead on.
I drilled a hole through his hand so I can push a brass rod in, instead of trying to straighten
the spear that he's holding. Also replaced the belaying pin that came with the kit for the longer
more correct type.
Hi George,
It seems endemic with most kits, the stern transoms need to be adjusted in most cases, I had to lift mine by about 5mm, quite a lot really, this then results in all manner of changes that need to be made.
Having said that your doing a great job on her, keep it up mate.
Be Good
mobbsie
mobbsie
Next Build :-
Cheers Mobbsie, appreciate the kind words. Getting towards the end of the building
of the hull now. Never thought I'd get there.
George
She's looking real smart George, well done.
Good luck with the channels and chains mate.
Be Good
mobbsie
mobbsie
Next Build :-
Wow George,
That looks fabulous !
I hope I can reach your level with my Aggy !
Thanks for the great pictures !
What colour have you use for the Stern ?
Black, white and ?
Cheers Guys,
Mick.
 Just checked out your Badger build, Excellent work my friend.
I received the Badger as a Christmas present. Be a while before I get round to it but when
I do I know which log to go to if any problems arise.
Sjors.
  I use Vallejo Paints. The Stern as most of the ship is in Yellow Ochre 121 and Matt Black 169.
George.
Very impressive model George
Well done !!
I love the Details and the scale Chosen for this one...
Nils
Current builds
-Lightship Elbe 1
Completed
  • 4 months later...
Beautiful work!  Inspiring craftsmanship.
Tom
Current: Sergal Sovereign of the Seas
Previous builds:  AL Swift, AL King of the Mississippi, Mamoli Roter Lowe, Amati Chinese Junk, Caesar, Mamoli USS Constitution, Mantua HMS Victory, Panart San Felipe, Mantua Sergal Soleil Royal
