Really nice cannons Michael  :cheers:
Karl
Karl,
Thank you. Nice of you to visit.
I have been, silently, following your Billings Vasa - Nice (:-)
Regards,
MIchael
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Absolutely stunning Michael!!!!!!!!They are a model in there own right!Excellent work.
Kind Regards
Nigel
P.S.you can just put the small parts in a bowl of water and stir to rinse them off ;)
Nigel,
I have been meaning to respond. You are much too kind. Your words, from such an artist as yourself, are wonderful. Thanks so much. I've actually finished them. I'll post some pics.
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
Hi Mates,
I have come to realize that each of you will most likely build three more ships before I finish this one. (:-)
But, here, surprisingly, are the completed cannons. Each of which incorporates fifty-five parts inclusive of the ropes, blocks and the single nail for anchoring the carriage to the deck (drilled a hole at the bottom of one of the four wheels for each carriage). I'm really irritated with my lack of knowledge regarding the axle pin poor locations. Darn, Nigel had the perfect solution, but it was too late...
You will note that my first attempt at devising a carriage anchoring method was, in retrospect, silly. Those long nails would not allow the barrels to slip through the deck openings. This did not even occur to me (such a novice) as I was attaching them. I tried shortening the nails, but then I could not locate the tiny pre drilled hole in the deck; uncharted territory for me.
So plan "C" should work, a small nail through one of the rear wheels in each carriage. Hmmm. The also really uncharted waters for me will be rigging all of these. (:-). I will use JanV's idea from his build.
I promise that I won't post any more canon updates until I have them rigged and mounted! Might be a long while (:-). I so appreciate all of your really super nice comments, so encouraging, thanks for also just looking in.
PS: ropes and blocks are from Chuck's at Syren (:-)
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
Vivian,
You are always so kind with your posts. Muito obrigado.
Michael
Under the table:
Completed:
Vasa-Corel -
Michael, for whatever it is worth (I am a very much a novice at this hobby), I used Plastruct liquid cement to help keep the small rigging blocks and lines at their positions. It is not a very strong cement (except on plastic) and it seems to be holding for now. It dries very quickly, is practically invisible, and a little goes a long way.
Dave
Dave,
Thanks for the suggestion, as well for visiting my build. I will check this out.
PS: I have been using the product pictured below for invisibly seizing rope knots. I have not tried it for rope coil placements as of yet. I discovered this glue while following Ferit's  (AlphaUrsaeMinoris) amazing Berlin build.
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
Hi I am just starting my build a bit of an odd one a billings kit but coral fittings
What paint did you use to paint the gilded items they seem very shiny to let the paint stick.I did think of stripping them but either my paint stripper is old or they can't be taken back to the base metal
Thanks Andy
Andy,
I washed the gilded pieces with dish soap. After drying I used standard flat paint for model kits from Model Masters, Testors, and Floquil. The last brand is primarily used by model railroad builders. Stripping is unnecessary. The only variable is time. I don't know how that will affect the decorative pieces, as I did not use a clear flat sealer.
Good luck with your "hybrid"
Michael
Under the table:
Completed:
Vasa-Corel -
Lawrence,
Thanks for your kind words. I'm in the process of disassembling all the carriage axles and following Nigel's brilliant solution to the errors that I noticed after installing all of the wheels.
I have an incorrect space between the wheel washer and the axle pins. Nigel suggested that I remove the axles, cut them in two, remove the spacing gap and re-attach each axle in two parts.
Looking much better. Note the main pic from left to right before and after.
Nigel if you happen to read this A BIG THANKS my friend, as usual very sage advice.
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
Hi Michael,
I salute your progress, your determination... Your carriages look very nice. Very fine details...
(The pins of the guns on my Berlin were just like yours. Me, I have cut the pins, drilled a hole there, inserted a belaying pin inside and painted them black.)
Best Regards…
Ferit KUTLU
Under construction: Frigate Berlin (Brandenburg Navy)
Hope: Frigate Wappen Von Hamburg (Brandenburg Navy)
Hi Michael, I salute your progress, your determination... Your carriages look very nice. Very fine details... (The pins of the guns on my Berlin were just like yours. Me, I have cut the pins, drilled a hole there, inserted a belaying pin inside and painted them black.)
Ferit,
Thanks for the idea. I went back to your Berlin just to look at the cannons, Gee I ended up reviewing your entire build; doors, sump pump, barrels, furniture, carvings and on and on....Please take it out of "moth balls" and get back to this beauty.
Regarding the belaying pins that great idea is really too late. I need to go forward to carriage blocks and ropes, and then building the lower and upper deck cannon doors. (:-) but thanks for visiting, its always nice to know that you are still interested.
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
Truly fabulous work Michael!!!!!Those gun and carriages look fantastic.The final result is a testimony to the amount of skill care and patience you have dedicated to them.They really will be the 'icing on the cake' of your build B)  B)  B)
Kind Regards
Nigel
Currently working on Royal Caroline
Hi Michael
After admiring your work silently for some time I have to say it once again: Brilliant.
Your example really tempts me to build the Vasa a second time.
Cheers
Peter
Peter,
Thanks again for your nice thoughts. Kind of you to follow along much appreciated.
So much more information has surfaced regarding this ship, and with the Vasa II book coming out later this year, you will certainly have much new easily available research. She certainly is an interesting build. I assume that this time you wouldl build one other than the Corel?
PS: Fred Hocker, the director of the Vasa Museum has mentioned that they are in negotiations with a company interesting in creating a Vasa kit. Who knows how far these ideas go, but......
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
Kind Regards
Nigel
Nigel,
Thanks so much for your very welcomed words. I have learned a lot from you, and I have happily incorporated your thoughts in this build. You, as you know "fixed"my carriage wheels (:-) (:-)
Cheers.
Michael
Under the table:
Completed:
Vasa-Corel -
What can I say that hasn't already been said. Hmmm... Excelso!!! :)
That comment about a Vasa kit with Fred Hocker involved sounds like a marvelous idea.
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Ulises,
Thanks for the nice words, as well as your visit.
If I can get near to your level of rigging quality, as your Vasa I'll be very happy. Seems as if the Corel plans are acceptable. A new updated kit would be great....
Michael
Under the table:
Completed:
Vasa-Corel -
Hi Mates,
A small update. Finally working on the carriage pulleys and ropes. What I thought would be monotonous has in fact been fun. I worked out, I think, a way of attaching the double pulleys to the weather deck in the same fashion as seen on the Vasa museum carriage reconstruction. I will work with bits of toothpick ends to fashion the  braces.
Kudos to Syrene for Chucks excellent ropes and pulleys (:-)
Thanks so much for all of the "likes"as I slowly move forward......
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
HI Michael,
Wow!  Very impressive! Your attention to detail and your patience in getting it right is amazing.
I look forward to more pictures in your log!
Frank
WOW Michael,that is some seriously impressive detail work !!!! :wub:  :wub:  :wub:  :wub: I couldn't help but keep enlarging the pictures!!
Kind Regards
Nigel
That is some very nice detail work on those blocks and tackle. I know the scale here and you have a gotten a good result for the effort. Very nice. Did you use CA at all to secure the line or milder fixatives?
Dave,
Thanks for your visit and kind words.
I do not use CA.  I have found it to be difficult to use when working with ropes. I instead use, with excellent results, GS Hypo Cement. I discovered this following Ferit's beautiful Berlin (AlphaUrsaeMinoris)
This glue dries clear and is, for-all-intense-and-purposes, invisible. The applicator has a tiny needle-point (perfect), and its cap also has a needle that inserts back into its shaft for closing.
This allows the glue to always come out when needed. AND this product dries quickly, but most importantly is super friendly to your fingers. CA, by comparison for this task is a mess.
For threading the pulleys I add a small drop to the end of a rope, twist my thumb and forefinger creating a straight rope tip. After the glue dries pulleys are easily threaded.
The pulley pic is just after application; it will dry totally clear and create a super firm bond. I can easily trim the ends right down to the buds without fear of knots coming apart. Highly recommended. Super find!!!!  Thanks Ferit.
Regards,
Michael
Edited by md1400cs
Under the table:
Completed:
Vasa-Corel -
Kind Regards
Nigel
Nigel,
You are so kind a big thanks  (:-)
Michael
Under the table:
Completed:
Vasa-Corel -
So gentle you are, my friend...
BTW your blocks seem really to be real pulleys... Carriages real carriages... Your Wasa will be reference work...
More you can hold your breath more you dive deeper... Details in details... I am afraid of her beauty if you begin to learn to breath undersea... :)
Best Regards…
Ferit KUTLU
