Thanks for the likes and encouraging comments.
Forward Braces
Looking at the main yard braces, the plans show they are tied off to the bowsprit bitts but I’d tied off the inhauler to one of them. I reviewed all my bowsprit rigging against the photos of the model in the RMG and other references. In the photo its not clear that an inhauler is present and Marquardt refers to Lever saying that on small ships, an inhauler was not rigged. For this reason (and for expediency), I have decided to remove the inhauler.
The main yard braces are 0.66 times the appropriate stay. I used 0.6mm rope. They are spliced around the end of the bowsprit, lead through the brace pendants and back through the outer sheaves of the triple block and tied off at the forward bitts.
The topsail yard braces, using, 45mm rope, are spliced around the yard arm, run through 3mm blocks hooked into the eyebolts at the cranse and run back to the crossbeam of the forward bitts.
I left both sets of braces slack but some more work is needed to make them hang satisfactorily. I use dilute pva and weight the rope along its length with paper clips.
Aft Braces
Prompted by Andrew, I considered the aft braces. There are none shown on the museum model of Trial but all the of the cutters photographed by @tkay11 show them fitted and Marquardt also lists them. I decided to fit them.
Looking at the photos of the 1763 cutter, the aft braces are shown threaded through a sheathed hole in the stern and I’ve tried to copy this effect. An eyebolt is glued in far aft and two holes drilled in the side forward of the eyebolt. The eyes of ringbolts are Ca’d over the holes to add to the effect.
The braces are rigged in a similar manner to the fore braces with pendants on the main yard and spliced to the arm of the topsail yard.
The main yard brace is tied to the eyebolt, passes through the brace block, leads through the forward hole in the stern and is belayed at the aft cleats.
The topsail brace goes through the aft hole and is belayed to the nearest timberhead. Like the fore braces, I have left them slack.
Bowlines
Bowlines are not present on the Greenwich model and maybe it’s not appropriate to add them when there are no sails on the model. Marquardt says that the main yard bowlines are threaded through a double block on the end of the bowsprit. Although I tried, I could see no way of adding a block easily with all the other rigging in the way so I decided to added only topsail bowlines. These lead through thimbles stropped to the end of the ‘sprit.
The thimbles are difficult to see with all that's going on.
The bowlines are hitched to the yard in-board of the yardarm cleats with a timberhitch and lead through the thimbles. I was running out of suitable belay points up front so they are tied off to the winch standards. I used 0.35mm rope.
I’ve gone beyond my original rigging plan and the model now looks very busy around the bowsprit. and I’m calling a halt.
It’s time to tidy up all the trailing ropes and make some hanks and coils, not one of my favourite bits of the build. I’ve tried various methods of making hanks but I struggle to make them look very convincing.
Ah well onwards..
David
David
Previous Builds
HM Cutter Hunter Mamoli 1:74
Baltic Ketch Scotland - Corel 1:64
HMS Fly - Swan Class ship sloop - Victory models 1:64
HMS Diana - Artois Class Heavy Frigate - Caldercraft - 1:64
HM Cutter Trial 1790 - Vanguard Models - 1:64
18th Century Merchantman Half Hull - NRG-1:48
HMS Speedy 1782 2023 Edition - Vanguard Models - 1:64
Current Build
HMS Harpy 1796 - Vanguard Models - 1:64
Great job David.
I like the busier look on models. All the pictures you see from the era, the ships looked very cluttered and so I feel you need at least a bit of clutter to make it feel authentic.
That looks outstanding David, really pleased you have blazed the trail for me and others to follow on this fine build. I also like clutter, looking at the contemporary models of Cutters like Trial & Hawke then they are very busy looking and cluttered with details like rope hanks anchor bouys and boats even.
Are you hoisting a flag at all?
Edited by AJohnson
Andrew
Completed (Kits):-
Thanks Andrew and Thukydides for your kind words.
I will be pressing my daughter into flag making as the very last step, although she doesn't know it yet! Kate made such a good job of jacks and ensigns for Fly and Diana that she is designated Chief Flag-Maker. 😃
David
David
Previous Builds
Current Build
You have made lots of progress since I have been away on holiday and good to be back and what a surprise to see how far on, you are. We'll done and as expected she looks amazing.
Edited by DaveBaxt
Completed     St Canute Billings            Dec 2020
Completed    HMS Bounty Amati          May 2021 Finished
Currently building HM Bark Endeavour
A quick update.
I’ve spent the last few days making hanks and tidying the deck.
I have used the method of wrapping rope around pins arranged in an elipse but have always had difficulty making the hanks hang realistically, especially thinner ropes.
I now prefer the method published by @carlo_l How I make rope hanks, fast and easy technique - My JIG - Model Tips and Tricks and Making Jigs - Model Ship World™ although I change it slightly by tying off the hank and then making the loop.
The coils are made in the normal way by laying rope down on the sticky side of masking tape and fixing with dilute pva.
David
David
Previous Builds
Current Build
Thanks for the likes and all the very kind compliments.
Anchors
I attempted to make the anchors back in November but broke both of them when trying to fit the anchor rings. The replacements arrived soon after but left it a while before having another go.
Despite being as careful as possible, I still broke another anchor when trying to insert the ring. Thankfully Chris had sent me three replacements and the final one was drilled out and the ring inserted without any damage. Puddening of the ring still took a lot of care. I used 0.45mm dark brown rope and 0.1mm thread for the seizings.
The cat block is a 4mm double block with hook made from 0.7mm brass wire and blackened. The iron band is represented by heat shrink tubing. The cat block is rigged with 0.35mm rope. It is tied off at the inner eyebolt on the cathead and threads through the block and both sheaves in the cathead and tied off at a cleat on the inboard side of the cathead.
The anchor is lashed to a convenient timberhead by the shank painter and at the arm.
The ensign will be the final touch which will be added as soon as my Flag Maker has space in her busy schedule!
Thanks for looking in
David
Edited by dunnock
David
Previous Builds
Current Build
Looking very good David, I am suitably warned about the delicate anchors! Seems inevitable, given how clumsy I am, that I will be breaking them also! 😆
Andrew
Completed (Kits):-
Quote
Thanks Andrew.
I thought that the anchor ring was a bit under sized so made a new  one. This necessitated drilling out the hole, by which time there is precious little shank left. If you go with the kit anchor ring, it will be more robust.
David
Previous Builds
Current Build
Anchors
David
There are always frustrations along the way but credit to you for overcoming them and making a really nice example of the anchor rings.
The Ensign has been painted by my daughter Kate and I have rigged it on a separate line. I used steam to set it and tried to impart some feeling of movement to it. I’m not sure if I’ve succeeded or whether I like the way it hangs. I’ll think about it for a while.
Anyway that was the finishing touch and so my first effort of building a ship from Vanguard Models is complete. I like the way that the basic hull slots together so easily and the laser etched bulwarks and deck add to the simplicity of the build. Trial was fun to do and makes a lovely model
I have already received my next ship, HMS Speedy, from Chris but I’m inclined to lay my own deck and bulwarks on this build. I’ve a few weeks to mull it over while on holiday in Shetland before making a start.
Thanks to everyone for looking in and for all the helpful comments and support.
David
David
Previous Builds
Current Build
Thanks very much for your kind words and compliments
@Thukydides, @DaveBaxt, @No Idea and @DonSangria
When I get back I'll try to take some shots with a better background
David
David
Previous Builds
Current Build
Quote
Very well done, David, I think this is the first one I have seen fully complete, she looks very nice indeed!
Many thanks Chris, that's very kind of you and especially encouraging coming from the designer of this great little model.
Quote
Wonderful work.  Looking forward to watching your log of Speedy.
Enjoy Shetland!
Thanks Craig.
Really looking forward to Shetland. We've been to Scotland and many of the islands but this will be our first trip to Shetland.
David
David
Previous Builds
Current Build
David, she looks fantastic. Well done.
Dan
Current Build: Yacht Duchess of Kingston (Vanguard Models, 1:64)
Previous Builds: Fifie (Vanguard Models, 1:64), Nisha (Vanguard Models, 1:64), Zulu (Vanguard Models, 1:64), Saucy Jack (Vanguard Models, 1:64), Erycina (Vanguard Models, 1:64), HMS Alert (Vanguard Models, 1:64), Grecian (Vanguard Models, 1:64), Ranger (Vanguard Models, 1:64), HM Gun Brig Adder (Vanguard Models, 1:64)
Waiting to be Built: Speedy (Vanguard Models, 1:64)
Thanks very much Dan.
Your Adder's looking great too.
David
David
Previous Builds
Current Build
Congratulations David, superb finish, does your Daughter take orders for Ensigns? 🤣
looking forward to seeing your Speedy log
Andrew
Completed (Kits):-
