HM Cutter Trial 1790 by BrochBoating - Vanguard Models - 1:64
Slow and steady is the way to go, you are doing great.
One further minor comment. The ring bolts on deck look like they are sticking up more than they should be. Technically the "circle" should be partially submerged in the deck. At the very least there should be no part of the "stick" showing.
Link to comment
Share on other sites
Thanks, good tip :)
Simon.
Current build HM Cutter Trial - Vanguard Models
Previous: Saucy Jack - Vanguard Models Polaris - OcCre
In the stash:
HMS Speedy v2023 - Vanguard Models
Nisha - Vanguard Models
HM Gun Brig Adder - Vanguard Models
Link to comment
No progress but another addition to stock arrived so the shelves have been updated.
Simon.
In the stash:
Link to comment
11 minutes ago, AJohnson said:
Nice shelf collection, that would be years for me to build and fill those shelves. 😆
You're not alone there Andrew. Won't stop me getting more stock asap though. Need to get a bucket of Vallejo Off-white.
Simon.
In the stash:
Link to comment
Terrible pics but experimented with Vallejo wood colours and pleased with the results from prime, colour, dry brush second colour. Will do a proper update asap.
Simon.
In the stash:
Link to comment
Working my way through the deck furniture. Very little work for the drop keels. Just a little filing at the deck and the keel then all was well. I put that all together then wound the keels back and applied some dilute PVA to the cord on the drums as suggested. Clips to hold it in place till dry.
Superb piece of Vanguard attention to detail, the PE winch handles have a prefab crease in them so they fold at exactly the right place!
Hand pumps fiddly to put together but good. It seems something below was misaligned as the 30mm dowel was far too long and despite using a round file I couldn't get the height right so removed and trimmed about 12mm.
Rest of the afternoon painting and putting Cannon together, ran out of time for Caronnades today. Little bit of paint touchup to be done later.
Simon.
In the stash:
Link to comment
I think that's the deck nearly done! Just anchors to do before it's time for masts and rigging. Gulp.
Will have to scope round and see how everyone has done rigging the cannon to the deck. Need to get more eyelets.
Simon.
In the stash:
Link to comment
9 hours ago, Isaiah said:
Looking great Simon, you’re flying through this build!
I’m looking to buy the Sherbourne from Vanguard Models so the Trial is also a good reference.
Thanks. Very enjoyable kit, learning a lot. I think Sherbourne is next for my stash.
Simon.
In the stash:
Link to comment
Just a little progress. Not absolutely perfect but happy with these as they're so delicate. Worked from the top down and used a little flexible masking tape between parts to try and keep things even. A tiny dab of gel CA on each piece so there's a little bit of working time to nudge into place. Then once dried a coat of varnish to hopefully make things secure.
Simon.
In the stash:
Link to comment
As this is my first military vessel can anyone advise if any of these configurations are vaguely accurate for Trial? If so then I can try and work out which to try and approximate once I get some more eyelets.
Simon.
In the stash:
Link to comment
6 minutes ago, chris watton said:
You have some eyelets on their way to you :)
(Forgot to tell you....)
Thanks a lot Chris :) Not messed any since change of tack lol.
Simon.
In the stash:
Link to comment
Looks good, wish I'd seen your lining up trick for the numbers earlier.
Link to comment
Only invented this morning lol. To be honest was despairing how to do it but happy with the result for first go
Simon.
In the stash:
Link to comment
Huge thanks to @chris watton for the eyelets, currently primed and painted.
Used the last of mine to start getting them attached to the gun ports.
I try and use CA gel by putting an amount on a piece of paper that I can dip the piece into before holding in place. Usually makes for more accurate placement with less excess.
Then start attempting to make the guns looked rigged. They aren't accurate but I wanted the practice. The blocks are far too big but are what I had to hand, next time I'll order extra nice blocks so this works out better.
One of each in place. Sure the rest will gradually improve.
Simon.
In the stash:
Link to comment
This blocks were far too big and ugly so I’ve removed them and tried to approximate rigging in the hope that they’ll look better not seeing them there than being so big they draw attention to them being wrong.
Simon.
In the stash:
Link to comment
3 minutes ago, chris watton said:
If it were me, I would add only the breech rope.
The larger of the two round the rear of the barrel?
Simon.
In the stash:
Link to comment
1 minute ago, Thukydides said:
It might be easier to do the breaching ropes off the model. Then you can attach them and the cannons to the ship. Also make sure they have enough length for the cannons to recoil.
My problem was how to attach them as the hooks I have for the eyelets are too small for that rope.
Simon.
In the stash:
Link to comment
9 minutes ago, Thukydides said:
Don't you have ring bolts? I am pretty sure some come with the kit.
I’ll take look what else I have. Thanks.
Simon.
In the stash:
Link to comment
Thought cartridge paper would be awkward but worked well.
Simon.
In the stash:
Link to comment
Turning to the masts etc. What's a good method to square off the top section of the main mast? Does something as simple as a file work?
Simon.
In the stash:
Link to comment
It did, but the stock looks like it is on upside down?
Cheers
Craig
Current Build
HMS Indefatigable
Erycina - Vanguard Models
Finished: HM Bomb Vessel Granado - Caldercraft, HMS Pegasus - Victory models, Nisha - Vanguard Models
Link to comment
It would.  I used files on my first build to square off the top of the mast.
You can also go the other way of using square stock and rounding off the trunk of the mast.  Particularly useful for top masts given the change in shapes across the length.
Cheers
Craig
Current Build
HMS Indefatigable
Link to comment
Drat
Simon.
In the stash:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
