Blades for Artesania Latina Cutter
Go to solution Solved by Gregory,
This isn't going to be a review of this cutter, I'll do that in the review section.  Not sure what these blades pictured below are called, but does anyone have any recommendations on blades that don't break with light use?
This cutter came with about 5 extra blades and I have already gone through 2 of them and I have cut probably less than a dozen pieces using this tool.  The first blade snapped on a piece of 4x4 sapelli, so I have stuck to cutting 2x5mm strips, after a handfull of them I glances at the blade and the new one was already chipping.
First blade that broke after cutting a piece of 4x4mm sapelli
Second blade after about a dozen pieces of 2x5mm basswood
These are the blades the cutter uses, is there a name for this type?
Get your money back.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
That blade is a razor blade from a classic machine, I think it's very soft for cutting wood.
Try to replace it if possible with a carpet cutter blade or similar.
The blade in the image measures 39 x 18.4 mm. The measurements of a razor blade are 43 x 22 mm.
Salutacions
Belco
Sorry but I disagree.  Properly heat treat steel tears.  It does not chip like these blades did.  Ordinary steel used for consumer products is relatively soft and ductile.  It cannot be hardened by heating and cooling.  To produce steel suitable for holding a sharp edge it must be alloyed with something else, the cheapest way being to increase the carbon content.  This “tool steel” is hardened by heat treatment. After heating to a high temperature, it is rapidly cooled by quenching in water or oil.  In this state it is very hard, brittle, and can shatter under impact.  To make it usable it must be tempered at a low temperature.  It would seem that in producing these blades the final step was omitted.
Long story short, they’re defective.
Roger
Amati sells such blades like this one, but have a look around as there are different types of them.
But this plastic tool is not designed to cut such thick strip as the 4x4. For that one you will need a saw. The use of this is to make repeated cuts by the same length or same angle, like cutting deck planks from thin strip (after adding a stop to the tray).
If you can't cut the strip by a handheld knife, neither this tool will do.
Past builds: Prins Willem,  Amati Coca
Current Build: Occre Diana
Why would one cut 4 mm x 4 mm wood with a gouillotine and not properly with a saw?
There are probably several factors that led to the blade failure in these application: too thin blade, blade sticking out too far, and not stiff enough tool. All these are inherent in the tool, which probably wasn't designed for such an application. If you'd use a stronger/thicker blade, something else will break or wear quickly.
HI brunnels,
I have a pack of identical looking blades which I inherited about 20 years ago. They are called Balsa hobel klingen (plane blades) manufactured by a German firm called Martor in Solingen. I've only ever used them for scraping decks etc,they're good steel and hold an edge. I suspect your blades are likely a product of the PRC.
Dave :dancetl6:
Because one is new to the hobby and wasn't sure what the tool would be able to cut.
Edited by brunnels
Kurt is right.
If chop is the way you wish to go
Harbor Freight has a mini chop saw that will cut thru thicker stock rather than crushing the fibers
It is Harbor Freight  so it is not a Rolls.   The table wants a layer to bring it up to the level of the bottom of the "vise".
It wants to sling the off cut.  You do not want your fingers as close to the blade as it would take to hold and prevent that.
StewMac has a Japanese Curved-edge Mini Saw  that I like - cutting on the pull stroke- good.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
36 minutes ago, Roger Pellett said:
If your need is to cut wood strips for planking a POB kit hull, a Model maker’s razor (Hand saw) works fine.
Thanks, that is what I already have and use and it is great.  The AL Chopper was a gift, I am trying to be polite and find some use out of it with better blades.
  • Solution
They have these at Cornwall Model boats
You might be surprised how low the shipping can be. Very competitive with cost from someplace like Micromark or ModelExpo.
Ages of Sail has what looks like the same thing for a different tool.  You would have to check the dimensions.
Edited by Gregory
Removed store info for Arizona - Poss SCAM
― Jimmy Buffett
Slow crawl:    Rattlesnake
