Glad you were able to save and bring her back to her original glory Pat. Nice!
GEORGE
nice recovery Pat......very nicely done!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks for looking in one and all; nice to have that support behind you when you experience these 'issues'.  While this instance is not as bad as some other modellers have experienced/related here, for me it was heartbreaking at the time - that is now the 'three' out of the way I hope ;)
Boyd, you can never be too careful :)  Danny has opened a very useful thread on correcting oopsies, some of the detail helped me in deciding what to do about this one.  The big lesson learned here (apart from being less clumsy) was to take a short break (no pun intended) away from the model to calm down and determine what the actual issue is then look for all possible solutions.  When I first saw the damage my immediate reaction was that OH NO!  another rebuild coming up.  However, when I looked at the extent of the damage and assessed the 'real' issues,  it was possible to break the problem into manageable areas - in this case:
1.  remove the old futtock shrouds and deadeye lanyards.
2.  reglue the breaks on the trees (these were longitudinal and with the grain so should hold) and apply clamping pressure
3.  redo the futtock shrouds and relace the lanyards
4.  re-tension the crowsfeet where I had to manoeuvre the clamps in and out.
et voila - a reasonable repair that I can live with :)  The very close-up photography has highlighted a few craftsmanship issues that I will need to address in future builds  :blush:
The bonus (if you wish to call it that) is that I can revisit the topmast stays and preventers and add the mouse detail that Steve (shipaholic) has found (using Elastoplast) which nicely mimics the woven finish.
Thanks again all
Pat
Edited by BANYAN
Pat,
Excellent recovery and great tips on how to recover.   I'm happy you didn't have to do a massive rebuild.
Thanks again all
Pat
Pat,
I really appreciate you taking the time to give us more details on the steps you took to recover.
I've captured many of your pictures and narratives in my archives.
Coming from a very unforgiving profession (Information Technology), I learned many years ago that “The Devil is in the Details”...can't do enough research and planning...and it looks like this applies to wooden ship building as well.
Great advise on your part...step back and think it through before you jump.
I spend hours and hours reading logs like yours and preparing for each step on my build (my first) and still I find myself up to my elbows in alligators  :)
But the nice part is I have no deadlines to meet…just taking my time and having fun.
Thanks again for your excellent build log  :)
Boyd
Boyd
Current Build - HMS Bounty - Artesania Latina - Scale1:48
No problems Boyd, that is what this site is all about - I have learned so much from others on this forum including Chuck, Russ, Danny, Jim Lad, Druxey and man others. Without this site I think the modelling world would be all the poorer.
cheers
Pat
Nice repairs in the shipyard Pat.
I've got some of Cucks hooks as well. Now ? need to test them before I use them.
Thanks for posting the repairs, we all learn from others.
Thanks
Dave R
Dave R
Measure twice, cut once.
Current Build: HMB Sirius 1786 - Flagship of the First Fleet to Australia (Scratch Build in the Shipyard)
Finished Build: HMB Endeavour 1768
  • 5 months later...
Nice recovery and great looking build!  I have been looking at some of the plastic hooks that you used that broke.  Question to you, was it just the excesive force that caused the break, or do you think they are a weak point being plastic once under some stress?
Current build: MS Sultana; Corel Endeavour
Previous builds: MS Phantom
Under the bench: MS Syren; MS Bluenose II
Hi Byron, in all honesty I think a bit of both.  Chuck is very open as to their purpose and I don't thing he intended them for this use, more for gun tackles etc where there is no force.  that said, I have redone them with the plastic hooks and they have held; even with the additional stresses applied during 'rattlin' (see following post).  If you are careful they should hold unless you are applying a lot of 'load' (strain).
Thanks for looking in.
cheers
Pat
Hi all, a long overdue update.  I have been busy with life (health issues), revamping my workshop and working on our club's build of HMCSS Victoria (see separate post) but have had time to progress.
I have completed the 'rattlin' of the lower shrouds on the port side and working across the upper shrouds.  I am using a template (see photo) which at scale provides 13" separation. Some of you may have noted my query re ratline sequence/pattern in a separate post/forum.  In the end I followed James Lees description in his great reference " The Masting and Rigging of English Ships of War1625-1860"  which is essentially what the replica has done with some minor adaptions which I have also applied.  His reference is based on contemporary models in the NMM and while there are difference between ships in this era, it is anyone's guess what pattern was actually used :)
I have also started rigging the shroud cleats - what a pain in the xxxx :(   I have tried various techniques and having had advice from Dan Vad and Greg Lester (thanks guys), still had problems holding these 'slippery little suckers' in place while securing them to a shroud.  even CA would not hold.  In the end I finally had some success using a tiny dab of CA on a half hitch around the base of each leg of the cleat (see photo), then half-hitching these and applying a dab of PVA to the hitch to temporarily hold them in place while I finish the hitches.  The PVA them leeches into the completed hitch and 'et voila'
cheers
Pat (and my 1000th post :) )
post-385-0-34801100-1444548835_thumb.jpg   post-385-0-78278900-1444548823_thumb.jpg
post-385-0-54372900-1444548840_thumb.jpg   post-385-0-82185700-1444548845_thumb.jpg
Edited by BANYAN
Thanks Greg, appreciate you looking in; and the many others for their likes.
cheers
Pat
Edited by BANYAN
Another question or two for you Pat, and sorry if the answers are listed someplace earlier in the build log, but I checked twice and can not see them....
I see that you replaced all (or at least most) of the rigging that came with the kit.  I really do not like the all tan approach that Corel supplies the kit with and and would much rather do the correct black standing rigging and tan running rigging.
So the first question is, did you happen to keep track of what sizes and amounts you ordered / made?
Secondly, did you follow the suggested Corel rigging or something else? I have a copy of the excellent Bark Endeavour book and plans by Ray Parkin, and while I haven't examined them in detail (as rigging in a LONG way in my future) it appears to have slight differences.
Thanks
Byron
looking really sweet Pat......yea,  gotta hate those 'anti 3M' moments {I hate it when things don't stick}  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Byron, no problems taking questions mate, that is what these logs are all about :)
My kit was the Artesena Latina (AL) but probably not that much different wrt their content.
I stopped using all AL parts and accessories about 2/3s way through the hull build, so all my rigging and deck furniture etc is either scratch or after market.  My rigging is a combo of Morope (tan) and home made (black).  I had already purchased the Morope before acquiring my rope walk so I was compelled to use it or waste my money - easy choice :)
Essentially, I used the rigging calculator (spreadsheet) developed by members JimLad and DanVad which is available on this site.  I simply rounded up and down the calculated sizes and simplified the range to 4 tan and 5 black sizes, and applied the general rule of diminishing rope size the higher in the rigging.  So while not absolutely scale correct, it should be close.
As to references, I have not bothered with the AL instructions at all.  I have basically used the AOTS book Capt. Cookes Endeavour by Karl Marquardt as my primary guide, but where there have been obvious or contentious issues I have also used the Replica, Ray Parkin and the feedback of some of our members to steer me.  James Lees (The Masting and  Rigging of English Warships)  has also been very useful.  In a nutshell, there will be difference to other builds; this is simply my interpretation.
FYI - Ray Parkin and Karl Marquardt were members of our club and there were some interesting debates about the differences in ship construction/fittings and rigging :)  Yes, there are differences between these authors interpretations, and with the NMM plans, the replica rigging  etc - although the vast majority of the rigging is generally the agreed.  Have a peek at MSW members Greg Lester Mike C and Shipaholic build logs to read of some of the issues that have arisen.
cheers
Pat
Edited by BANYAN
Hi Pat, magnificent job with the repair work and the "ratting" I am ratting too. will post pics soon.
cheers Mike
Thanks Popeye, Mike, Brian and Mark for looking in - appreciate the interest.
Having fun with the rattlin Mike :)  a tad tedious huh?
cheers
Pat
Edited by BANYAN
I think "ratting" is the closest thing us guys get to knitting. :-)
Edited by mikec
Well the 'knitting' is now done with all ratlines finished :)  That is milestone completed and another started with a good start made on the jib and spritsail yards.
post-385-0-71357600-1451118691_thumb.jpg  post-385-0-13406800-1451118719_thumb.jpg  post-385-0-45321200-1451118794_thumb.jpg
cheers
Pat
Looks great, Pat and that is a big milestone...   :cheers:
Thanks for looking in folks and the comments Mark and John - appreciate the interest and encouragement.
cheers
Pat
Pat,
The Endeavour is beautiful...... and then the rigging is another chapter itself!
I just realized I am missing a book in my library, a book shown in the second to last picture for the moment.
Anatomy of the Ship - Endeavour
Btw, how's the summer?
Respectfully
Thanks again to all those whom have looked in and "liked' - appreciate you dropping by.
Hi Per great to see you drop in; thanks for your very positive comments.  The AOTS has been very helpful with this build.  It's going to be a very hot summer this year; lucky for us a cooler Christmas as we have some major bushfires just down the road from us on the "Great Ocean Road" with some 120 properties/homes lost already; the cooler weather had allowed the firefighters a little respite to try and control it.  Warming up again later this week - we have already had a couple of days in the 4o+ Cel. range - good excuse for a couple of 'frosties' (beers) ;)
cheers
Pat
ratlines look great Pat........nice view of the ship  ;)     stay safe and have a great new year........trust you had equally a good Christmas  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye, ditto. I also hope you and your family had a great festive season and have much to look forward to in 2016.
cheers
Pat
Have a great New Year and better 2016 Pat!  :cheers:
GEORGE
