Started to assemble the parts. Glued the bitt and futtock riders to their places using PVA white glue.
For large and more detail photos see also:
http://www.flickr.com/photos/ilhan_gokcay/sets
(Best go into the set and choose slideshow)
Illhan,
as allways, it's really a pleasure to look in your build log and follow your accurate work.
Regards Christian
Glued the cleats at the bulwarks, knight, pin rail and pump at the main deck.
I do pay much attention to the sequence of these operations in order that nothing will be obstructed later.
Very nice work as usual Ilhan, your woodwork is very precise and clean.  This will make a very nice addition to your collection of excellent models.
cheers
Pat
Installed the deadeyes. I’ve used epoxy glue while glueing to the channels. Fixed the deadeyes in correct angle with rubber bands while the glue sets.
Little progress. Glued the anchor rope and the deck of the forecastle with white glue (PVA).
http://www.flickr.co...han_gokcay/sets
I somehow seem to have missed you log Ilhan, so I'm just catching up.  All up to your usual high standard, I see!
John
Ilhan, just catching your build again. Exquisite workmanship clean precise use of wood and other materials enjoyable to watch the progress.
Michael
Absolutely amazing workkkkkkkkkk. Ilhan i really enjoy in this build log and specially in metal work :) You are truly master modeler but absolutely you are top top top in metal work :D
Thank you!!!
Current build: LA MARTEGAOU
Past build:
BRACERA
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do... Sail away from the safe harbor. Catch the tradewinds in your sails. Explore. Dream. Discover"
KIND REGARDS!
ELMIR
Hey Don, I don't recommend to use the plans form MSB to build a model. There are lots of mistakes which I do not remember all of them right now, but some of them are really serious.
Edited by Ilhan Gokcay
I’ve started to build the bulwarks on the fore- and aftercastle. To fix the stanchions at correct angles I’ve built two  casings to guide
the structure and fixed these casings temporarily using the holes for the masts. I’ve cut the stanchions from pear strip and drilled the
ends 0,7 mm (diameter of an ordinary pin). Using the guide casing I’ve marked the positions, drilled the deck, and glued the stanchions with CA.
Ilhan Gokcay
________________________________________
Going on with the bulwarks. I’ve glued the rail and the upper planking using white glue(PVA) and also got rid off the casings.
Hi Ilhan,
Always great to see the thought process and care you put into your ship building.  And, thank you for taking the time to repost your builds that were lost.
Reg
Great job, Ilhan.
It's also a great source of inspiration about building techniques and tools for bending.
Cheers
Alex
If any of you cry at my funeral, I'll never speak to you again! (Stan Laurel)
