Sailing ship, threemast-barque Gorch Fock 2 in scale 1:95
Introduction to this build by Nils Langemann
When choosing my first tallship for modeling, the choise for either Gorch Fock 2 or for Pamir was not so easy, so finally I decided to build both, the Gorch Fock 2 to begin with, and the other to follow on in staggered time schedule.
The Gorch Fock 2 is the follower of the still existing german Gorch Fock 1 and bearing the original Name again (ex russian Tovarisch, now towed to the pier in Stralsund harbour, Baltic sea), which had several sisterships, one of them being the still serving USS Eagle of the US Coast Guard.
GF 2 was launched 1958 at Hamburg Blohm & Voss shipyard, build N° 804 and to be used as a cadet training ship for the German Navy, Bundesmarine. She since then, and after several updates in look and techniques does her duty bravely. She is well known on the seven seas and in many ports. She is also participating in many “Operation Sail” events and to be seen amoungst other tallships.
Compared with the ultimate version of today I preferred to model the 1960 ties version for its more interesting look, with the more nostalgic looking boats and the motorized commanders launch. The model should be carrying all 23 sails and be fully rigged, if I would manage to do so. The ships hull in actual and in model is representing more the look of a large yacht, because of the slim fine lines and the missing cargo holds.
The ultimate version differs in color, has a larger oval shaped funnel, more modern navigation equipment, a variable pitch propeller, larger portholes (safety reasons, allows a man passing through !!) and modern rescue- and lifesaving equipment. Also a side-thrust prop was fitted in the bow Sub waterline section, as well as many inside fitting out updates.
When looking out for a suitable plan to build the model from scratch, I found a lonesome set of frames in correct scale at an Ebay auction and decided to trim and update these for my project. I saved myself some plywood-cutting-out right at the beginning, that gained some time for doing other things. The other data and rating I found in some GF2 related books, and besides that at that time, I still had a wonderful rare scale 1:150 GF 2 Kit in Plastic by Revell, that had never been built nor started, but representing a very useful pattern for enlargement to scale 1:95 (rating wise)
I started gathering all information and pictures of details I could get, and started to lay the keel. It should take me appr. 1,5 years to finalize the model. Many experienced techniques could be addopted to the Pamir build whereby not so good results on GF2 modeling techniques could be avoided or improved.
Have fun in exploring this build log
Nils
unmistakeable, the white barque with the golden flying Albatros figurehead, which had to be replaced several times when going lost in rough trips
The since WW1 late german writer, Johann Wilhelm Kienau, pseudonyme "Gorch Fock" is the name giver to this vessel
Build log Part 1
I tried to get a better print into this Formate, but not possible at this framerate
SSS stands for Segel-Schul-Schiff on the nameplate
the single Frames contours would not allow 2-dimentional deck curvature, so the Basic Support was done this way
the decks are from 1,5 mm aero-plywood and preplanked (3 x 1mm stripes) before mounting (structure done by charcoaling plank edges with a masons pencil, before gluing to the deckplates
stern fill blocks in multilayer ply, the deck Panels are checked for size with a Little surplus all around
deck curvatures clearly to be seen here
decks brought into shape with rough outer trimm
poop bulkhead and deckhousings started
Build log part 2 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Mauro,
enjoy the build furtheron..
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 2
the decks are checked if all Planks are free of marks
and checked for fit in the foreseen places
poopdeck bulkhead and midship deckhouse get paint and portholes
stairs checked, doors, handrails mounted
the many eyelets are placed and secured from under the decks
Frames look OK so far
mantaining the deck curvature while the glue is curing
Build log part 3 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Ah, you're just starting, I'm not too late.  I enjoy the explanations of your builds.  Thanks.
Bob
Current build:  SS_ Mariefred
thank you Bob and Crackers,
I sighted quite an extensive documentation (photos) for this build, it was probably the first time my digitible camera realy came to use, so there is plenty to come...
Nils
Current builds
-Lightship Elbe 1
Completed
Just arrived to watch and learn
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Nenad, John, Bugra
Thanks for joining in to watch the build ...
Nils
Current builds
-Lightship Elbe 1
Completed
great start to the build Nils.   is that P.E. your using for the fittings?.......doors and such :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Build log part 3
poopdeck eyelets
preparing for the welldeck pinrails
These pinrails are designed to withstand Forces initiated by the later rig
wear sections of the pinrails bear brass inserts
eyelets for foremast shrouds and backstays
especially the eyelets for the shrouds and backstays have to be well countered from beneath the decK
Build log part 4 tofollow....
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Popeye,
if I am correct PE is the short for Polyethylene, but no, its etched brass sheet for stairs, doors, hatches,etc., in general available in various scales for use on all types of models
Nils
Current builds
-Lightship Elbe 1
Completed
Nils,
Another great log to match that of your Pamir. Lovely work and attention to detail. :)
I've seen Gorch Fock a few times during the Tall Ships Races. Being run by the German Navy she is always of course very smart, with the yards squared to the inch when in port.
Kester
Current builds: Sherbourne (Caldercraft) scale – 1/64th;
Statsraad Lehmkuhl (half model) 1/8th" – 1'.
Victory Bow Section (Panart/Mantua) scale – 1/78th  (on hold).
Previous build: Bluenose ll (Billings) scale – 1/100th.
yes Kester,
thats right, I have never sailed on her yet, but had the Chance to look around onboard. In the ports there are always many public visitors and so everthing is utmost tidy, brass is well pollished up, all ropes are belayed in perfect condition, or coiled on deck
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils,
In this context PE stands for photo-etch, or photo-etched brass sheet - which is exactly what you are using.
Fantastic build - I enjoyed your Pamir build very much and look forward to the next steps on Gorch Fock.
Greg
Build log part 4
view pinrack section
the holes for the masts made and a spare anchor lashed to the foreward deckhouse
the triangle like parts are lockers at the poop bulkhead and are taperd because they fit underneath stairs from well- to poopdeck
mastgarden and other pinracks fitted
eyelets for ropeguide Tacklings and pinracks on forecastle deck for the each 4 jib-sails sheets
Build log part 5 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils,
Greg
Thanks Greg,
...learnt something new to it, shall have to remember PE=photo-etched
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
I like your method of building the deck first.  I’ve always had trouble trying to fasten pins and eye bolts so they don’t come loose.  Thanks.
Bob
Bob,
I leave the most upper sideplanks just below the deck away as Long as possible, just in case and order to have Access to the decks underside for counterfastening whatever Needs to be fastened from above. If I should have Forgotten to set and fasten an eyebolt, I do it per enclosed scetch...
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks, Nils.  I thought I saw some solder under there.
Bob
Build log part 5
the first portside plank, pine 2 x 10mm, is fixed against the Frames to find the best fit in its gentle natural curve following the hull lines
and then glued on permanently
the second plank follows willingly
on this build I am not using additional stringers
the same done on starboard side to avoid possible Twist in the hull
the Gorch Fock is a fine model to plank, no risky bends, no watering of planks
the 2mm thick planking will allow sufficient material remaining after sanding later on
having no Problems with the planking
short propshaft in sleeve tube M3 thread for prop (the brass prop to be Exchanged against a larger one later on, because I cold`nt find a 28-30mm diam. brass prop with M3 thread in the hub)
Counter device for stand bolts with reinforced keel sides there
Build log part 6 to follow...
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 6
this ship was not designed to be a cargo vessel
planking good under way
time for checking if no sub-deck Counters have been forgotten...
finaly the last fit to size plank Closes the opening
should be a fine base surface for sanding, due to the single layer planking, the Progress goes on quite swiftly
14 Planks per side, keel to welldeck
still quite easy going..
The Planks that also form the bulwarks are mounted
Build log part 7 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
David,
all Colors in in satin-dull tones
the hull is basicly White, with chocolate Brown section line at sides of forecastle and poop, the waterpass is green and the Sub waterline hull is antifouling-red (These are the Colors of the 1968 look)
Masts, Yards and booms in safran-yellow
Nils
Current builds
-Lightship Elbe 1
Completed
Wonderful to follow another build, You must not have to sleep like the rest of us ;~)
Michael
Build log part 7
building up the bulwarks
and top Planks at forecasle
Need to pull equal on portside as well
the upper Stern Portion shall be planked verticly
bow bulwark planked verticly and roughly trimmed
all planking done, now the sanding can begin
vertical planking provides nice following of the curves
smooth finish, no dents, no scratches...
remaining material on sternpost appr. 50% of the raw planking, other planking random about 75-80 %
Build Log part 8 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Do want me to call the boys in the white coats?  They will put in you in a nice padded cell.  After 50 years you will be cured. :)
David B
Oh David,
my wife has already told me something in that direction...,
it is coming springtime here, and the garden Needs some care
Nils
Micheal,
after this build-log it goes steady again...
my still in the pipe HMS Pegasus Build feels itself quite stepfatherly cared for, so I Need to see what can be done about it
Nils
Current builds
-Lightship Elbe 1
Completed
