Dear friends,
after finishing of Revenge 1577 I decided to continue again with scratch build - not with another "war monster", but with two small ships, two of Columbus fleet, which returned back from the New World for the first time.
I used free plans from MODELARSTWO OKRETOWE web page ( http://www.modelarstwookretowe.pl/index.php?p=44 ) for Nina  ( there are downloadable plans for Santa Maria too ) and made projection for Pinta based on the same plan and pictures of model made from MO plan. I will also change sail plan  on Nina - all of sails will be latin.
I absolutely forget to start a new thread here ( shame on me :D ), now I´m in progress of hulls planking.  Bottom parts of hulls and decks are just finished. There are three layers of cartoon planking already - I want to make extremely strong and smooth hull ( there are only first and last layer taken on pfotos - the second one I glued across the first ). Upper parts of hull sides will be make from one piece of thick cartoon each one.
Here are some pictures from the progress.
Jan
Finished:       Ark Royal 1588
                      Mary Rose 1545
                      Arabian Dhow
                      Revenge 1577 ( first attempt )
                      La Couronne 1636
                      Trinidad 1519
                      Revenge 1577 ( the second one )
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
On the table: Sovereign of the Seas 1636 - continuing after 12 years
All of them are paper models
Thanks for your photos.
Very nice work there! Love the fact that you're building it in 1/96 scale. It just adds to the challenge of building when it's a miniature, like yours. I"m also intrigued by the method of hull construction and planking that you're using. Is it cardboard?
Look forward to seeing the finished products!
Thank you, my friends, for your replies.
dgbot: I´m using just cardstock, for surface finishing ( decks, planking imitation etc. ) I´m using strips of foils - just like Doris is doing ( I learned this method from her :) ) I´m using wood just for masts and yards.
Karleop, Omega 1234: The scale 1:96 is normal for me, I´ve build all of my ships in this scale and I don´t want to change it. It´s just fact that these two are quite small :) Most of my ships is quite big ( La Couronne is about 80 cm long )
Here are two photos for comparison: Pinta and Revenge, both hulls and La Couronne.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Very nice work Jan, I am still always amazed by the models made with card.
Michael
Thanks, my friends :)
Upper parts of hulls are done, and the last part of planking is applied. I allways use four layers of planking - as I said, I want to have the extremely strong and smooth hull.
Here are some photos of the result.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
I started with imitation of wooden planking by strips of foil ( This is Dorisis´  method of planking - I learned it from her years ago ;)  )
The patination of planking will follow.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Such a crisp method of planking on the card it looks great.
Michael
Thank you, friends, for your replies.
I use self - adhesive plastic foils with wooden structure of surface. ( I use the same method of planking like Doris )
I patinated planking by brown anilin water color and painted them by colourless matt Revell paint , I think the surface of models looks much more better now. Keels will follow.
Jan
Edited by firdajan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Wow  :o
These are really great.   I can't wait to see more...
Tim
"That's a fine looking pair of oars you got there, Sir"
" 'em aint 'ores --- that's me wife and me daughter! "
  :o
Current build:   Glad Tidings Pinky Schooner
Past builds:  1:1  Stick-Up Sharpie Build
                    Muscongus Bay Lobster Smack by Timo4352 - Midwest Products - SMALL - First time builder
                     Gunning Dory sail & oar boat 1:1
Future Build:   Scratch built Mower Dory  -  scale undetermined yet
another future build:   Martha - Chesapeake draketail
timo 4352: Thank you !
You can´t wait ? Here you go :dancetl6:
Ships just got keels. I will continue with wales.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Wales are finished. Now I can continue with rails and deck´s equipment.
Here are some photos.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
What kind of foil are you using and whee do you buy it.  Inquiring minds want to know.  Fantastic work.
David B
David: I use self-adhesive plastic foils with wooden structure of surface, I´m buying it in local hobby store.
Just small progress before easter - I made windlasses, ladders and covers ( not gratings - I´m quite sure there weren´t gratings ).
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
  • 2 months later...
It takes me almost two months to continue with report, but I made some progress. Hulls are finished and today I gluded all masts. Now I have to prepare some parts for standing rigging.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Ok, ok, ok...I keep coming back to the early photos on Page 1 of this log and I still can't get my head around the fact that these models are built from card! Truly magnificent work, Firdajan.
I'm learning so much from builds such as yours, especially how clean and precise the hull planking using foils have turned out. Really top stuff.
All the best.
Thank you, friends.
dgbot: I use self adhesive plastic foils with wooden structure of surface. You can buy it probably in stores like BAUMAX or OBI or sometink like this - I´m buying it at home in store which is selling doors.
I´m working slowly - but still ;)  Main parts of standing rigging is done. I have just to finish it - and start with propulsion :dancetl6:
Here are some pics.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
Well done, Jan, your work is always a great pleasure for my eyes.
Keep up this beautiful  work
Doris
Doris
Current build:
HMS Royal Katherine 1664 from card
Tank you, my friends :)
avsjerome2003: I know Doris well, and, believe me, I really learned a lot from her. Her work and models were also one of reasons I start wit shipmodeling after 20 years again ;)
Yards are finished  ( just three on each ship :D )- and now I can start with first part of running rigging - the second one with sails ( BTW, I changed sails to latin on Nina - in plans are the same sails for Pinta as for Nina ).
Here are some pics.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
beautiful work Jan, it is really hard to believe that these are card models.
Michael
Michael: all my ships are made from card ;) Here they are
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
First part of the running rigging is finished. Now I can continue with sails - and the second part of the running rigging.
( ...and with anchors, rudders and flags.......It seems that ships will be finished very soon :dancetl6: )
Here are some pictures I took today.
Jan
                      Mary Rose 1545
                      Arabian Dhow
                      La Couronne 1636
                      Trinidad 1519
                      Nina 1492
                      Pinta 1492
                      Santa Maria 1492
                      San Salvador 1543
                      Anna Maria 1694
                      Sao Gabriel 1497
