Thank you Greg.
Although it is not historically accurate, I decided to leave the hull without copper plating. On the other hand, the whole hull will be with treenails. So I started the "mass" production of the pins (about 8,000 pieces).
G'day Marsalv
You are working hard to make the "sawdust". It would drive me crazzzzy to make them! Did you say 8000? Wow that's a lot of treenails! After that is done, you have to drill the hull and then place them! See you in a few months at least.
havagoodtime my mate!
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Really interesting build log.Your idea for makeing treenails is great
Regards Christian
OK, silly question:
  The treenails look like they are still attached at the bottom. How are you removing them from the wooden block.
Richard.
Richard
Member: The Nautical Research Guild
Thanks to all. The idea for making treenails with needle is not mine, I learned this method from russian modelers :) .
To rtropp: see enclosed picture - front side of the block with treenail is covered with masking tape, block is cuted off with saw. After removing tape you can easily eject treenails from the block.
After endless hours I finished the hull treenailing. Result will be more visible after waxing.
G'day Marsalv
Your home made claps are a great idea.
it is going into my memory vault for sure.
keep up the great work my mate.
Goodonyamate
Greg
Edited by Greg the peg leg sailor
Marsalv
     This is the first time I've peeked into your Pandora build log, and I have to say I'm impressed with your start.  I will surely follow along.  The Porcupine class vessels really do have nice lines.  It's too bad there aren't any drawings showing more than minimal stern decorations of those ships as completed.
Tom
I notice you've left gaps in the planking for the rails. You may find bending them around the bow difficult. Usually the rails are applied over the planking: much easier to bend. Your model looks terrific so far.
