Holiday update :).
7 from 8 sails are now finally finished :dancetl6:   . Last one will be done after installing fore and main mast. I learned a lot and next model will certainly have sails on.
Today I finished attachment rings for fore and main sail. I used 1mm brass wire and made spring from which I  cut out rings . Ends were soldered together. Because I didn't like brass color I decide do blacken them with Blacken-it solution. First I put them on cleaning solution for grease removal, then Muriatic acid for surface etching and finally blackening bath. To achieve final look I buff them with soft cloth.
Edited by SimonV
Simon
Current build:
Royal Yacht, Duchess of Kingston by Vanguard Models
Mercury by Victory Models - scale 1:64 - (99% scratchbuild) - on hold
Finished: Bluenose by Amati - scale 1:100
My "recipe" is as follows:
1) I dont know translation but I use "triklorethilen" cleaning solution for grease removal. It is usualy used in electronic cleaning - 20 min in 100% Solution
2) Muriatic acid for surface etching - 20 min in 100% Solution
3) Thorough rinsing with water
4) Blackening, 80% Blacken-it Solution, 20% distilled water - 5-10min.
5) Thorough rinsing with water
6) Buff with soft cloth
After buffing I noticed some spots where solution didn't "grab" well. If that was on canons or carronades I will repeat the process.
I found this article very useful: http://www.modelboatyard.com/blackening.html
Simon
Current build:
 After completing all sails ( Fore sail was not the "lucky" one, I need to repeat process 5 times to get good result, but now I can sew them with closed eyes , ha  :dancetl6: ) it is now time to put them on model and start the rigging process. I began lashing Main and Fore sails to booms and gaffs with running stitch using 0,1mm line. For rigging the kit thread is useless because it is to thick and stiff, so I replace that with 0.1 , 0.25, 0.5 and 0.75mm thread from Jotika.
Simon
Current build:
Well done, Simon! Your Bluenose is a little masterpiece. Just beautiful work on the sails.
Regards,
Gabe
Current builds:  Harvey, Baltimore Clipper - Artesania Latina;  HMS Triton Cross Section, 18th Century Frigate - online scratch build; HMCS Agassiz, WW2 Flower-Class Corvette - HMV - card model
Completed:  Swift, Pilot Schooner - Artesania Latina --- Build log --- Gallery;  Skeeter, Ship-in-Bottle - Ships a Sailin' kit --- Build log;  Santa Maria, Caravel - Artesania Latina --- Build log
Companion SiteHMS Triton log and live feed
Finally, all sails are on the model. Now it looks more like a real Bluenose  :).
All the running rigging is also complete. Belaying pins are made from bamboo toothpicks to add a bit Of realism (kit instructions
suggest only tying lines directly on holes). Some belaying points from instructions were little odd, so I change them to look more
realistic.
I now have to add rope coils, lash the Deadeyes to the standing rigging ,tie the ratlines,... Still a bit Of building yet B)
Edited by SimonV
Simon
Current build:
I rigged all the Shrouds to the Deadeyes. To hold the Deadeyes in place while seizing the shrouds, two wire hooks were used as seen on picture.
Currently working on Ratlines. I tried working with 0,1mm rigging line but found it is too big for my taste, so I used thin black sewing thread impregnated with beeswax.
Simon
Current build:
 Ratlines finished  :).
Kit instructions suggest to use rope for attaching anchors. Instead of rope I used chain. For blackening I used Blacken-it solution and slightly oiled it before installation to hide patina look.
Still few bits to go, currently working on display case.
Simon
Current build:
beautiful schooner Simon,
also the sails are well done
Nils
Current builds
-Lightship Elbe 1
Completed
Simon your Bluenose is coming along great.  Nice and neat and a symmetrical hull.  When done properly the hull is a work of art which you have down pat.  Now comes the deck furniture and the rest of the rigging that brings life to it.  Keep up the good work.  I am rooting for you.
David B
It,s a problem holding of starting the next project when the end is in sight . Be strong !!
:rolleyes: hmmm, I have already opened the box and now I am planning ahead, because there will be quite  bashing. Will finish Bluenose first, I promise   B) .
Dbot, welcome to my log,  glad you like it. Thank you :)
Edited by SimonV
Simon
Current build:
Finally I could write, Bluenose is finished   :)  :dancetl6: .
Life boats were last piece in puzzle. I replace kits plywood with pearwood, and definitely looks better.
The reason for slow progress is on the last photo  :)  :)  :).
I will post photos of finished model in a few days.
Simon
Current build:
I see with your last photo you have started a new scratch build kit    :o
Congratulations!
it is difficult to comment on the former when looking at the latter
This next kit will take a lifetime but like most you'll get so much more from it then you give.  :D
Edited by AON
Alan O'Neill
AON, Elia and shihawk ,Thank you very much for your kind words and others for likes  :) .
Yes, time becomes even more precious now. Some of it will be definitely devoted for shipbuilding.
Cheers,
Simon
Current build:
This is probably my last update of my Bluenose log.
I took all the pics for the gallery and here I present some of them. The gallery will be open soon.
I would like to thank you all for replys, comment, likes or just stopping by at my log. THANKS   :).
Enjoy the pics.
Simon
Current build:
  • 2 years later...
Simon, I hope you're doing well.  I just saw your log and was curious on your hull paint method.  From the pictures in your log, the quality of your hull paint job is incredible.  I'm curious, did you spray or brush?  Do you have some kind of finish on top of the paint?  Thanks.
Dave
Dave
Hello Dave. Sorry for late reply (recently I rarely visit forum :().
Hull is brush painted with acrylic paints. Key is to paint in several thin layers with diluted paint and let each layer dry completely. For finish matt acrylic varnish was used (also brush painted). Paints and varnish are Admiralty Paints from Caldercraft.
Simon
Current build:
Really wonderful looking model!
hamilton
