G'day Dave
Great job/progress! Can't fault a thing. I've done my air and light ports on my as well......bloody tedious. I took a log of my times and would you believe it was 48 hours to make the surrounds and lid. I'm cheating with the hinges, they will be fixed and all are dummies.
Cheers mate
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Love the way your Endeavour is coming together Dave, very nice indeed.  The walnut doesn't seem to have tripped you up at all with split/flaky edges.
Edited by Beef Wellington
Cheers,
Jason
In the shipyard:
Bit more work at the Shipyard.
Chess Trees added.
I could not source a 3.0mm dia. 1mm thick sheave, so filed down a 4mm dia. to suit.
The first picture I previously posted showing the laminated CT.
Other 2 Port & Starboard on the hull.
Dave R
Edited by DaveRow
Dave R
Measure twice, cut once.
Current Build: HMB Sirius 1786 - Flagship of the First Fleet to Australia (Scratch Build in the Shipyard)
Finished Build: HMB Endeavour 1768
Hi Greg,
I lost track of the hours on the ports. And still to make 10 of the smaller vertical hinges for the last lot, well I need to get my head in the right spot to do them.
The mid sized ones should open. However since I didn't/haven't "pinned" the flaps to the timber, the glue joint comes apart if too much pressure applied. So they look like they open, they should, but I won't try them.
Hi Jason,
I had a couple of earlier problems with the Walnut splitting, esp. the tight bends.
Lots of wetting and steaming was done.
Just used what was supplied in the Kit.
Dave R
Dave R
Hi All,
I made the trip to Sydney early this week to see the Endeavour at the Maritime Museum at Darling harbour.
I had planned/booked to join the Endeavour as crew for the 10 day Sydney to Brisbane Voyage, but the trip was cancelled.
So having the flight booked. I flew down and spent quiet some time on board, taking pictures, talking to the volunteers and generally getting the feel of the boat.
It was a weird feeling, as after building the model to date, I felt at ease on board, that I was kind of home. Weird eh!
Had a great visit.
Dave R
Edited by DaveRow
Dave R
Had the shipyard working on the Swivel Gun Stocks.
The Starboard ones made and fitted.
I used black card(idea from another post) to simulate the metal straps. Each was Super glued to the stock, as each wrapped around. I will follow on after the black painting by impregnating the card with the Super Glue to harden it up(hopefully from deteriating). Well I hope that will work.
Dave R
Dave R
She is coming along very nicely Dave, nice work.  Thin CA before painting should do the trick - medium/thick especially may not penetrate especially after painting which may seal the card?
cheers
Pat
Swivel Gun Stocks.
Well the shipyard pushed ahead and has completed the Port & Starboard Swivel Gun Stocks. Although in the haste, forgot to drill the holes in the top to mount the little cannon. Bad boy ! :huh:
I'm happy they have come up ok.
Pat. thanks for that PVA glue tip. I used a 50/50(PVA/water) mix that disappeared quickly(absorbed), and dry quickly. I have not painted the cardboard.
Onto making the hinge sets for the aft cabin side shutters.
Then will glue the decal on.
Slow and steady...
Dave R
Edited by DaveRow
Dave R
Hello Dave,
Glad I stumbled on your very impressive build log and for being your first build I think your just showing off a bit :) It looks like the card stock worked out great for your swivel guns (I might have to barrow your technique). In the past I have used household aluminum foil folded many times and then cut to the desired thickness. I use this trick a lot when brass is called for simply because I hate fighting with brass. I think your idea using CA glue to seal the cardboard should work out just fine especially with a coat of paint on top. More than one way to skin a cat in the world of model ship building it seems. I look forward to following your awesome work.
Semper Fi,
Phil :)
"Be polite, be professional, but have a plan to kill everybody you meet"
General James Mattis USMC (ret.)
US Independence by AL in 1/35
Completed:
Bon Retour by AL (Second Build)
Greg,
Had thought to leave them off, however got to go on sometime. They are glued on with 2 Pac epoxy, like the rest of the whole ship. Very solid joints. Time will tell how they stand up.
Phil,
The CA glue(I used PVA, is that the same ?) was BANYAN(Pat) advice, and for now just left the card unpainted. It is a slightly different shade than the painted post. I follow a lot of the guys build logs to get ideas how things are done and see if can come up with other ways to construct parts. Good fun and rewarding.
Dave R
Dave R
Very impressive build so far!  Great work on those tiny working hinges too!  Just going back to the beginning now to get some info on the starting process of the build to help me with mine.
Current build: MS Sultana; Corel Endeavour
Previous builds: MS Phantom
Under the bench: MS Syren; MS Bluenose II
Dave,
CA glue is Cyanoacrylate, what most folks call 'super glue'.
PVA glue is Polyvinyl acetate - this family of glues includes most of your white (Elmer's) glues and white & yellow wood glues.
They are most definitely not the same!
No probs Dave, glad to hear it worked out well.
I have left the swivels, anchors etc for the very last fit - as Greg stated, too easy to snag get in the way of the rigging.  I am also leaving the jib boom for as long as I can for the same reasons.  One of the last things I will fit are the delicate items such as the deadlights, quarter window shutters etc.
cheers
Pat
Hi Pat/Greg others,
I agree, will have to leave the items that are loose/swing off to the end. Anchors, Boats, Cannons(maybe fit them up and glue in place ?)
I should start to move onto the deck items next/soon.
Get these tucked away in place then back to the outside/mast bottoms.
Dave R
Dave R
I'm of the belief of going inboard to outboard. Everything that can get in the way will get in the way once you start the running rigging, I did the cannons and boats as they had to be belayed/lashed down. Once the standing rigging in place it just gets harder to touch the deck. The anchors I did fairly much last, as they really snag everything but if you look at how I did the cables it was painful as I had to steer them around the rigging.
Greg
Hi Greg, Will concentrate on the deck items from now. All makes sense.
I did push on over the weekend to get the Quarter Badge Deadlights made and fixed in place on the hull. I started the badges in April this year.  I love making very small hinges :angry:, did I say that ? I am over them.
I rebated the hinges on the deadlight so they did not stand out so much. At such a small scale, I found it difficult to make them smaller. At least the deadlights open, when all the glue is fully dry will snap a pic, post, then close them for the remainder of the build.
The deck awaits the shipyard. ;)
Dave R
Edited by DaveRow
Dave R
Some progress on the Windlass.
I turned up the barrel on my home made lathe.
The Bit pins & cheeks(ends) come apart to house the barrel, the cheek bottom held in with a brass bracket, the top with a brass bolt. Took a while to finely tuned the fitting to get the barrel to turn.
I was surprised the figure heads came up fairly well I reckon.
Only 2 days work. !
Next to add the pin rail, whelps, brackets etc. make the bell tower thingy. Mine will be something based on the replica, 2 posts.
PS. I have yet to trim the ends of the barrel off, left them on for now.
Dave R
Edited by DaveRow
Dave R
Nice carving Dave. I never could get my mind around a starting point to carve something. Your pictures and resulting carving of the head now show me a good starting method.
Thanks
Braver man than me mate; I cut the metal heads off and glued them to the replacement carrick bits  (cheating??? ---- nuh :))
cheers
Pat
Thanks to all that have been looking in on the build.
I was on the replica on the 6th Oct, took plenty of pictures to assist in details.
Windlass Update,
I have spent hours on this baby so far.
The side Standards & Bit Pins are glued in place now. This allowed me to fit the pin rails to the Pawl Bits(the bell tower !)
The barrel is 95% complete, fitted and turns in place between the Bits(pin & cheek) complete with brass bolt and nut to lock in place - for final lockup. Neat eh!
Made up some pawls - bit rough but at this scale lucky to get them. Need to trim them back a bit.
Still more to go - the belfry cap to finish off.
Then onto more bibs and bobs.
Dave R
Dave R
