New recruit requesting permission to come aboard!
Having made a few ships in bottles I wanted to see how small I could make a static ship model.
I have been overawed by the quality and craftsmanship of models I have seen in these pages and know that I could never come close to these.
I used to build small ships when I was a kid so I  thought I would have another go. this is one from 45 years ago that my mother still had!
I really loved the models I used to look at in the NMM and Science Museum in London and decided to make my Victory out of boxwood for the beautiful colour and fine grain. I acquired some boxwood veneer and made a start.
I made the bulkheads and keel from 0.7mm ply the boxwood was used for deck and planking
I was keen to keep the model in a timber finish and started to construct the stern and galleries onto the base hull form
The gunports are closed! and therefore set out as simple squares on the hull. I also started to think about the few visible cannons with brass tube barrels.
Lower masts are bamboo skewers reduced through a draw plate and bands fitted in cotton thread
For the smaller solid parts I used sawn sections from one of my wife's used clay modelling tools which are made of fine boxwood
Wow that is pretty sharp.
Michael
Thanks for your kind comments guys, I do feel that my build is just playing compared to the masterpieces being shown on this forum, but at least I can build mine on the kitchen table!
Sonicmcdude, the ship will eventually reside inside this glass cloche that the admiral has acquired
I have started on the standing rigging using a bead thread which is not too "hairy"
I am using fine brass tubes for the upper masts and yards which although cannot be tapered seem to have the right feel in terms of visual weight and complement the woods used. I am not quite sure about the representation of the shroud chains, I may revisit this later. I also need to think about whether I should try to indicate the deadeyes and lanyards.
My son is studying medicine and gave me a set of his disposable surgical instruments which are great for this work! Clamps are very useful to act as weights to ensure even tension on all the shrouds
A picture of the rigging underway after launching!
The riggers have had a busy weekend and the majority of the standing rigging is now in place, they are all in the pub now having a well earned pint.
Sven, you are definitely pushing the bar up there, what a fantastic job on the masts and rigging. "steady hands,careful you must be"
Michael
Thanks Michael! Yes I did manage to cut a stay by accident and it was ten times more difficult to install with the shrouds in place!
I think at this or any scale the choice of material for the rigging is key to getting the right feel for the ship. I have been using bead thread called "silamide" which is quite fine and not hairy, I have used this for the stays and shrouds.
For the finer rigging I am using fishing fly tying strand called "Nano Silk" this is very fine, non hairy and extremely strong. It is however made of many fine strands which are not bound together very well and tends to unravel while working. I impregnate it in white glue to bind it. Cutting it is very difficult and can only be done with a brand new blade.
One advantage with using the brass tube for masts and spars is that I can attach fine wire loops in the tube ends for rigging to pass through. A good source of very fine brass wire is the "net" around some bottles of wine (also a good excuse to stock up the cellar!)
I have now finally completed the standing rigging, the bowsprit rigging was more difficult than expected!
Spars next!
Sven,
This is just amazing work.  The closest thing I can find to a salute emoticon: -->  :pirate41:
Woa...soo nice. You are a true artist. lov it.
MJD
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Thanks for the comments. It is really encouraging!
I am Test fitting the first yard and I have had a go at foot ropes which take a bit of time. I think this is ok so will proceed withe the rest.
Matt
Geeze Matt where are all the clove hitches on the ratlines?  and I don't see too many dead eyes either ;):D
Michael
Oh Michael. What have you started!
I have found a way to make scale deadeye assemblies. Unfortunately too late for this build!
Using two very small beads and one strand of white thread. The shroud is then coloured black with permanent marker. One for next time!
Matt
WOW!!!!
Michael
Your Rigging work is great.
Good Luck
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Yards now raised and thinking about how much running rigging to attempt!
Matt
Edited by Sven
So you are not only a superb model builder, but also a dab hand at composing evocative photographs!
Michael
Thanks Michael. So kind of you to say so. The images are mostly digital trickery.
What I love so much about making ship models is that is about the least digital thing you can do today. After working on screens for the best part of 30 years that is proper therapy!
Matt
Matt
Not that I've worked 30 years in front of a monitor (closing in on ten though) but I do agree on that!
And for your build Sven (I have Sven as a 2nd name ;) ) when I saw the first pic of your early try I thought to myself, hmm, that looked rather crude, but when you explained it was a very old sin I smiled :D
And now, that little Vic is just excellent!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Thanks for following guys.
Hi Hakan! Sven is not really my name but comes from the fact that I run a 1929 Austin Seven (S'ven) car.... I must like small things!
Matt
Edited by Sven
