18th Century Longboat by Nirvana - FINISHED - Model Shipways - 1:48
I still don't know whether to go with natural or painted cockpit.
After some experimenting the hinge in the last picture is a 110gram papercard with the 28 gauge black wire from the kit.
I did a trial with brass but I didn't like it.
Respectfully
Link to comment
Share on other sites
The hinges are made and in place. They turned out the way I wanted them.
Working with the 110gram paper was quite an easy approach.
I have decided not to paint the seats.
Looking at the picture it looks like I could have put simulated "going through bolts" in place.
Respectfully
Link to comment
Locker with hinges in place but not glued.
Edited by Nirvana
Respectfully
Link to comment
 I broke a knee today....... :P
Well at least it wasn't my own knee, but one for the longboat.
This resulted I made one more before realizing Chuck already had made sure of two extra from the laser cut board.
However, take a look at this I am more than pleased how the boxwood knee turned out.
Now I am wondering if I should do all six of them in boxwood.
On the other hand if they are to be painted then it won't matter but if I leave them natural then I should do it?!
Respectfully
Link to comment
Again, I am trying to figure out whether to go painted or au natural.
As above the piece from the kit but painted and 50/50 varnish on the boxwood.
Leaning towards the painted in order to get some contrast, but the natural looks good too........  HELP! :)
Maybe doing two sets and then take it from there......hmmmm
Respectfully
Link to comment
I think you should lean towards your leanings, DrPer.
(Besides, I like the painted knee also ... it adds contrast.)
Edited by CaptainSteve
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Link to comment
Dr. Per, I like the painted knees for the contrast, too. Go paint it! :)
Ken
Started: MS Bounty Longboat,
Link to comment
The twart for the mast is being made as per instructions from Chuck,
CA glue has become my friend.
Respectfully
Link to comment
And the result
Respectfully
Link to comment
Progress with the mast thwart,
I did cut a small piece from the mast material to get the right diameter.
Thereafter the half circle in the thwart was made along with other side of the "iron ring" (brass).
Respectfully
Link to comment
The band strap that "secures" the mast ring to the thwart is not cut equal see the bottom side.
Will not be visible once in place.
Respectfully
Link to comment
It's rough, but the picture gives me indication of trimming and bevel the edges.
Respectfully
Link to comment
Looking pretty darn good to me, Per.
Link to comment
After some trimming and adjustment, I washed the brass to clear any surface from any grime and fat.
This to ensure a better surface for the blackening.
I am not using the Black-it product, but a product that I found at the local RR hobby shop.
This product is probably the same as Black-it but seems to do a great job. This one is called rail weathering solution product number #49-104 and comes from Micro Engineering Company, it is recommended to start be diluted at 1:2.  However, you can use the concentrate directly.
Don't leave the cap off  - the fumes can start blackening items in its surroundings! I learned this the hard but interesting way.
One pint cost me back in 2009 USD 27.00
I used a piece of blue foam which I covered with clear tape and the pinned the thwart in place, then CA glued the mast ring in place. This way the two items doesn't get stuck to any other surfaces.
Respectfully
Link to comment
Once the glue settled, it was time to put a block between the foam and the thwart, this allowed me to attach the support band.
Next up is the holes for the belaying pins.
Respectfully
Link to comment
Hey Nirvana why did you use poly wipe on, I'm just curious as I am still learning? Thx John
John,
I think I picked it up from another builder from the group build.
Can't remember who.
The wipe on is very easy to use and you will get a nice finish surface along with it.
This specially for the keel and frames. Besides it gives you a protective surface.
Looking forward to see your build log.
Edited by Nirvana
Respectfully
Link to comment
John,
Can't remember who.
Thx for the info. I'll Try to start soon, I'll probably be doing the long boat as I do my Bluenose. Thumbs up on your "Long boat" looking Good!
Link to comment
I think I am one of many who didn't like the brass pins provided with the kit I decided to take on the challenge of making my own.
After a pm to Chuck, he explained how he did his.
The Dremel with the extension shaft did the trick.
This is my first attempt with the boxwood.
And only a few minutes job. I used blade #11 along with some fine files.
Respectfully
Link to comment
This is what Chuck wrote back to me upon my question - How did you do the fine belaying pins in the pictures?
"The few times I made them using a Dremel. I used boxwood placed in the Dremel and just a small file to make them.
One at the time like it was a mini lathe. I have the flex shaft with a small handle so I can hold it steady. That's about it.
It takes a long time, and I usually spend a few hours at a time making them."
Respectfully
Link to comment
My first home made belaying pin, just a little time consuming but I do like the final product.
Now I have to make another three (four, one extra for safety).
Respectfully
Link to comment
Uniformity? Hmmm, not so much  :(
Respectfully
Link to comment
This is so much fun, I am truly enjoying this build.
I didn't have to make a fifth nail, none of them broke.
Now all of them are installed.
Respectfully
Link to comment
Looking great from here, Dr. Per.
Link to comment
Good job on the belaying pins.  I am going to use your method on my build.  Thanks for sharing.
Ryland
               - Nautical Research Guild
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
