Everything posted by thibaultron
Electric sanding belt file
thibaultron replied to Don Case's topic in Modeling tools and Workshop Equipment
That's like the Lowes "Craftsman Tools". They are not made by the same company that the Sears Craftsman tools were made by. Lowes bought the name and logo from Sears, but Stanley makes the tools. Sears still sells them, also, but reserved the right to continue to have their original manufacturer produce them, for I believe 10 years. -
Well my kit arrived, and my workbench is mostly cleaned off, so I had best start my build log. I'll post some pictures tomorrow, if my first Covid shot doesn't hit me too hard.
- 38 replies
No I bought the saw for less than $100. Wish I could have had enough for the Barnes. I've added these on over the course of a couple years.
Part 009 Yesterday the new Miter Gauge I bought from the same person I purchased the backplate and rip fence from arrived. It is a well made all aluminum assembly with nice large angle markings on it. It fit well in the table slot, with only a little slop, much less than the factory one. It also has a larger miter assembly, with one side angled at 45 degrees. The gauge has a nice thick blade screwed onto the protractor, giving a good surface to hold your work piece to. The only down side I see to it is that the position marker on the slide is a dot, rather than a line, making it harder to set the correct angle. The locking screw is well made and provides a strong grip when tightened. I tried cutting some old ¾” X ¾” hard pine strips on it for a project. It did stall a couple times, when I tried to feed it through too quickly, but I was using a 100 tooth blade rather than a more suitable one. The finish on the cut ends was smooth. This size wood is at what I would consider the upper limit, in thickness, so I was happy with the performance.
Trix X acto history?
thibaultron replied to FlyingFish's topic in Modeling tools and Workshop Equipment
Several Stanley 101s, though not that exact design, for $30 to $50 on Ebay here in US. -
A couple things to note about resin printers. The resins are generally toxic, so keep the printer away from children and animals. The resin print is brittle, so be careful handling it. The resin has a shelf life after opening it, so a large resin printer may be expensive to feed, if you are doing small volumes of prints. (OK, three things, but I can't count well).
Is the vise for "Pressed Chicken"?
Part 008 I also bought three Zero Clearance plates for the saw, from Radical RC. The center ridge you see on the bottom of the uninstalled one acts as a stiffener and the rear clamp. When I installed the one shown, I had to press along the edges, after tightening the screw, to snap it flush over the whole surface. I have not run the blade up through any of them yet. I’ll wait until I’m ready to use one. I don’t want to keep putting them on and off, in case doing so shifts them a little, after the slot is cut. They are ~$10 US each, so not a bad deal! I also bought a better miter gauge, off Ebay, from the same seller as the backplate, and rip fence. I’ll review that when it comes in.
Part 007 I bought two new parts for the saw, a backplate and a new rip fence. I got both off of Ebay, from a gentleman who says he has been making them for years. He plans to continue offering them through Ebay. A. The Backplate The back of the saw is open, from the factory, and this plate fits in the empty space. It thus closes the back from any things that might otherwise, accidentally intrude back there. It provides a port to attach a shop vac, which with the back plate on will actually do some good. It also braces the sides of the base to stiffen it. The other important item it provides is an additional lock for the back of the saw blade housing! This picture shows the outside of the plate (once installed). The knob in the curved slot is the rear blade housing lock. The aluminum angle bracket is the brace. Of course, the tube is the vacuum hose attachment port. The castellated top fits into the groves of the underside of the saw table. This is the inside of the plate. The nut on the shaft of the knob, is just to hold it during shipping, and will be discarded. The wing nuts are used when attaching the brace. Here is a picture of the instruction sheet. When installing the backplate, you must either discard the little rear blade guard, or figure out an alternate mounting for it. The backplate fits in tight against the blade housing, so the guard would have to be moved to the inside of the housing. If you look closely at the first picture, you will see scribed lines marking the area you would have to remove to allow for new mounting screws. I chose to simply remove the guard, as the plate seals this area anyway. The upper screw hole in the housing is where the new knob will screw in. The plate is slid in inside the opening and sits down onto the bottom of the table, between the housing and the adjacent ridge. I found that the plate did not fit solidly to the bottom of the table, which has apparently bowed just slightly over the years. This allowed the plate to rock a bit, so I cut a little off of the longer parapet area in the center. Now the plate sits firmly against the table. One effect of this was that the plate sat a little further down causing the knob shaft to rub on the plate. I filed the slot a little wider to fix this. Here are shots of the plate in place. Next the rear brace is installed. Check the fit, as the attachment screw holes are not symmetrical with the center of the base, so the brace only fits with the horizontal lip toward the table. I replaced the wingnuts with 10-24 nylon locknuts. Tighten the nuts down until the nuts on the brace touch the plate. This holds the plate firmly in place. In addition I’m going to drill a hole through the two lips on the base to insure that the plate can’t shift during sawing. B. The Rip Fence The Rip Fence is a big improvement over the factory one. It clamps more securely and has an adjustable fence blade. The fence clamps front to rear, like a full size saw fence, not just with a clamp under the front lip, like the factory one. The back of the factory fence is free floating, being held square just by the stub on the clamp casting on the front of the fence. The new fence is also taller than the original, allowing for more controlled cuts. The new fence can be fine tuned to your saw table, using the two adjustment screws on the main body. The manufacturer also included a nice push stick with it! For my saw I had to fine tune the front lip. As there were a few burs and dings on it. I used a large flat mill file on the front and under the front lip to smooth things out. This is why there are gray areas in the last picture, that is the bare plastic showing through. The adjustment also comes in handy, as I found the front lip to not be perfectly straight on mine. So I can now adjust the blade, if needed, for each fence position. The error is not very large, so most times I will not have to worry about it.
Lateen yards – inside or outside of the shrouds?
thibaultron replied to catopower's topic in Masting, rigging and sails
I believe that to tack a lateen sail, the halyard is loosened, and the tip of the spar is pulled back behind the mast, then the halyard pulled in again with the yard now on the other side of the mast.- 14 replies
- lateen rig
- washington galley
1/350 Type VII-C U-Boat. Metal construction.
thibaultron replied to lmagna's topic in Plastic model kits
Hey, Matey. I think you left your boat in the water too long! -
Currently on Ebay, there is a seller who has just started listing accessories for the saw. He has several, including a better rip fence, miter gauge, and a back plate. I ordered the fence and the plate. I contacted him, and he plans to keep listing new items. He has been making them for several years. Presently he has the fence, plate and gauge at least available.
Will be restating soon. I just finished refurbishing my shop to the point I can start working in it, and found the wood I bought for the mast and boom, that had been packed away.
Would the plastic frame allow you to put the unfaired frames in and then sand the outside fair after everything is assembled? For me that might be a better way than risking damaging a frame by over sanding beforehand.
- 16 replies
