Posts posted by TBlack
Thanks, Keith, bro, and all you others who are taking your precious time to follow my modest attempts. I do think that I've figured out how to accommodate an aft cabin and quarterdeck without altering the brig's lines too much. There are still a couple of issues that I need to sort out. Not the least of these is here:
The joint with the stem is disturbing, and I can't get it any closer than what you see. The waterline will come just at the notch, so not to worry below that. Above I'll have to fill with pear paste. And then not look too closely!
- mtaylor, Keith Black, etubino and 3 others
- 6
A little more progress. I've gotten the rest of the siding on both port and starboard plus molding strip along the top:
As I mentioned in my previous comment, the gun ports on the kit are higher than the painting. Also, you'll note that I finally attached the keel. She sits in the cradle much better now.
Tom
Keith, yes, she’s coming along OK now. I keep thinking I’m at the point when I can start following the kit instructions, but then remember some other detail. If you go back and look at the book cover photo in post 128, you’ll see that the hull planking is different than the kit which is straight pear. Also, the spacing between the tops of the gun ports and the top rail is smaller in the kit than in the photo. So, I’ll have to make some adjustments.
- Cathead, CiscoH, Keith Black and 2 others
- 5
Stern gunports installed. I kept knocking off the top rail, so I removed it until I'm finished with the quarterdeck detail:
- CiscoH, Oldsalt1950, Keith Black and 7 others
- 10
Of course, my first idea was to donate the books to the NRG library only to discover that we had dissolved the library several years ago (I'm not really up on current events).
In terms of an heir; it's actually my mom's dad who has given me the ability to do this.
Also, I need to thank "anima" (Jeff Wall) who actually made all of this happen.
Tom
- Harvey Golden, Keith Black and mtaylor
- 3
Just to close out this discussion, I've agreed (and sent the check) to acquire this set. After a little searching, I'm donating them to the library at the U.S. Merchant Marine Academy in New York. Now the logistics are such that I'll wait out winter before going to pick them up.
Tom
- mtaylor, Roger Pellett, Keith Black and 5 others
- 5
- 3
42 minutes ago, toms10 said:
it is hard to say no to your daughter.
Amen to that (see HMS Sophie)!
Tom
So, the final resting place is your family room? You need to have a lot of "open houses" so a broader audience can appreciate your art/craftsmanship.
Tom
- mbp521, FriedClams, James G and 4 others
- 7
It looks like a question of repairing the rigging. The rest of the model looks intact?
Tom
- Ryland Craze, mtaylor and Keith Black
- 3
On 12/28/2022 at 9:59 PM, AON said:
Every time I leave my shop I surprise myself with what I have done. No one knows how impossible I feel every new task will be for me. There are a lot of "do overs" and I have become very comfortable tearing pieces off. But I continue to crawl forward, never give up, always face the new challenge. I know I will fail at some the first or second time, but I get better and learn with each attempt.
I am still a novice!
Good night all.
Isn't this how most of us feel? This quote should be enshrined somewhere. The Gospel according to St. Alan!
Comfortable looking library. If you’ve gotten plumbers to come out during the holiday, you’re doing good!
It occurs to me that the fit of the netting is so perfect that a large part of the battle was to get the dimensions right in the first place. Damn you're good, Keith!
Tom
- Keith Black, mbp521, KeithAug and 2 others
- 5
OK, Keith, we agree on the davits, but I’ve made two mistakes. If you look where I’ve placed that top rail over the stern, you’ll see that the davits have to go right where the rail meets the transom. Gotta make that rail shorter. The other mistake you can’t see from the picture of the painting of the ship’s stern, but the painting on the cover of the book shows two gun ports in the transom. Guess I’m not done yet!
Tom
- Keith Black and mtaylor
- 2
OK, so I found the molding material. Did my best on the tricky corners and added the top rail:
Now the tricky parts are the stern davits:
My understanding is that, normally, these run along the top rail for support. But these don't. They just stick out from the transom. I think I'm going to depart from the photo and put them on the top rail unless you guys think otherwise.
- ct mike, Keith Black, CiscoH and 3 others
- 6
7 hours ago, Keith Black said:
Bail you out, in your dreams!
So I might be spending my days incarcerated? But I’d have the 7 volumes to keep me busy!
- 2
14 minutes ago, Gregory said:
Just curious why it makes a difference.. Are you banned in one of those states? 😁
I don’t know; I may be. Yikes! Does the MSW have a legal department that might have to bail me out?
Tom
- mtaylor and Keith Black
- 2
13 hours ago, KeithAug said:
Tom. Beans Christian name is Eve. Her mother started referring to her as “my little bean” when she was about 2 months old and the rest of the family have called her Bean ever since.
Then this project is like mine (HMS Sophie) for my daughter Sophie!
Tom
- KeithAug, Keith Black, mbp521 and 1 other
- 4
Boy, that was fast work. I'm guessing you had some surplus fixtures to help. Bean and Maisie will be delighted. And Eve is.....?
Tom
- KeithAug, Keith Black, FriedClams and 2 others
- 5
Martin J Lynne by LWARD1291 - Sylvan Scale Models - HO/1:87 - Great Lakes Freighter
And all hand-laid track?
TB
