Posts posted by popeye2sea
The only thing I can definitely say about vacu-formed sails is that you should glue a bolt rope in all around. If you try to make holes in them to add robands, hanks, blocks, rigging, etc. they will rip and pull out. The bolt rope will allow you to fasten all these items to it without tearing your sail.
If your feeling very ambitious you can fashion the bolt rope into the various cringles needed to attach sheets, tacks, bowlines, buntlines, etc.. You can even run a line across at the reef bands in order to attach reef points.
Regards,
- mtaylor and thibaultron
- 2
On 5/25/2017 at 6:11 PM, kayakerlarry said:
This seems like a reasonable question for this forum but please direct me elsewhere if appropriate. On my model of the Howard W. Middleton, a costal coal schooner built in 1883, I have a question on how the stay sail/jib sheets were secured when they ran outside the foremast shrouds. I have 5 separate sheets that will run outside the shrouds and belayed on the rails midship. I don't like the way the way they look in this photo and would appreciate any thoughts on options or input on how it was actually done on coastal trade schooners of last 1800's.
This lead for the sheets seems kind of odd to me. If you had sails set here the clews would be pulled off in the direction of the shrouds. Not very efficient.
Regards,
I have been doing some thinking on the subject of tack lines on the fore sail. It seems to me that the only tack line that would matter would be the one to windward holding the clew forward and down. The lead of this tack would be more up and down when on a wind and so should not foul any other lines. The lee tack would be slack. The way I would solve the the fair lead problem would be to look at the where the clew of the fore sail would come to when braced up hard, and run the tack in the manner that reduces fouling and chafe to a minimum in this position.
Regards,
I find that taping and masking are more of a nuisance than they are worth and I always end up having to go back and fix stuff anyway. I get a much better result with just controlling the flow of paint off the brush. I never mask anymore.
Regards,
- Hubac's Historian, EJ_L and druxey
- 3
I've got some pictures to show you of the Constitutions topsail, topgallant, and royal yards. Hopefully you can see the fittings for the yoke and parrel arrangement. Also shown are the yardarm cleats and fittings for the outer studdingsail boom irons, as well as the sheaves for the sheets. The horses and stirrups are attached to the yards. At the center of the yards you can see the additional wood padding out the center section with the halliard blocks. There are no quarter cleats on the front of the yards. On the top mast yard, in addition to the iron jackstays there seems to be another rope one. Not sure what the purpose for this rope stay is. Perhaps it is for use as a man rope or hand hold for working aloft. This is the only sail that currently gets set on the ship. Also seen in the center section of the topsail yard is the net-like bunt gasket. Hanging from underneath the yards are additional blocks with their rose lashings above.
I hope you find these useful.
Regards,
- mtaylor, paulsutcliffe, RichardG and 7 others
- 10
Superb work! I love the way it looks, but man! your going to have a heck of a job painting all of that. I know how long it took me to paint the considerably fewer decorations on the original piece.
My hats off to you, sir!
Regards,
There is a fitting that looks something like this on every yard:
This fitting both helps secure the yard to the mast an allows it to stand off the mast a bit.
The surface that bears against the mast is leathered.
I will look to see if I have any pictures of the yards to show the details of the yoke and cleats.
Regards,
The fore topsail bowlines will lead from the sail forward to a pair of leading blocks on the fore topmast stay at about the level of the fore yard and then through two blocks attached to the bowsprit somewhere near the the collar of the fore stay. They then went directly to the forecastle rail or sometimes they went through the gammon block. Most often they belayed to the rail at the fo'c's'le or the "range" (a pin rail across the head). If to the range they sometimes went through an additional pair of blocks a little way up the fore stay. At times they were taken back up to blocks under the fore top and down to the deck from there.
Regards,
My apologies, I misread your post and gave you the info for the fore and not the main. The main topsail bowlines will run to leading blocks under the after ends of the fore trestle trees and then down to the deck. They will belay to whatever fitting you have abaft the foremast, whether that is set of bitts with a cross beam or a fife rail with belaying pins. I do not think there would be a separate set of bowline bitts.
- Jim Rogers, mtaylor and Captain Poison
- 3
What a superb job you have done with her. She looks fantastic.
Harold Underhill has a book called Masting and Rigging the Clipper Ship and Ocean Carrier. He describes the standard and usual method of rigging for civilian ships. Also included is a fold out diagram of the belaying locations with a comprehensive and cross referenced index.
I think it is a great resource.
Regards,
- CDR_Ret, paulsutcliffe, mtaylor and 1 other
- 4
The photos posted above by Captain Poison show the bentinck shrouds aboard USS Constitution. The legs of the shroud consist of a length of line with an eye at both ends. The legs are wormed, parcelled, and served their entire length. The shroud legs are doubled and passed through a thimble spliced into the end of the bentinck shroud. The ends of the legs are seized to the lower shrouds at the futtock stave. If you look closely at the pic you will see that the innermost pair of legs go the middle shroud and are seized one above the other. The remaining pairs are seized to each successive shroud moving out from the center.
The bentinck shroud itself leads down to the opposite waterway where it has a heart turned in. It sets up with a laniard rove through the two hearts. The lower heart is shackled to an eyebolt in the waterway.
The number of legs for your bentinck shrouds usually equals the number of futtock shrouds and should splice to the same lower shrouds as the futtock shrouds.
Regards,
In Steel's Art of Rigging he desribes the method of hoisting up and rigging the top mast. According to this method the top mast is hoisted up using a hawser rigged in the old manner (pre 1640 or so) as has been described in posts above. The hawser was used to hoist the top mast high enough to pass through the lower mast cap where at the topmast cross tress and head rigging were fitted over the top mast head. The top mast was then held in place by tackles from the lower mast head while the hawser is un-rove. The top rope pendant is then rove in the method described by Lees (1640 on).
So, everyone is correct here. The top rope, after 1640, as described by Lees was never intended to allow the top mast to be lowered to or hoisted from the deck. That job was accomplished by a separate line. Which also sort of explains the differences in whether the top rope was un-reeved or left rigged during different time periods.
Regards,
The studding sail guy is a rope used to help support and steady the studding sail boom. When the boom is swung out into position for spreading the foot of the lower studding sail the guy ropes run from near the outer end of the boom to points on the hull to steady it in position. You could simply fit an eyebolt into the hull to take the end of the guy. Or you could lead it onto the channel to belay there.
Regards
Here is what I used, based upon R.C. Anderson The Rigging of Ships in the Days of the Sprtisail Topmast 1600 - 1720:
The rigging sizes all are figured relative to the main stay which has a circumference equal to half the maximum diameter of the main mast, so
42.76 inches mast diameter x 1/100 scale gives 0.43 in. scale mast diameter
.043 / 2 gives a main stay circumference of 0.215 inches
0.215 / 3.14 gives a main stay diameter of 0.068 inches.
The closest line I had available is 0.08 inches (which may be a bit too large. 0.06 may be a better choice)
The following rules of thumb then apply (in order of size):
Fore stay = 4/5 of the main stay
Main shrouds and Main topmast stay = 1/2
Fore Shrouds, Fore topmast stay, Mizzen stay = 2/5
Main topmast and Mizzen shrouds = 1/4
Fore topmast shrouds, Mizzen Topmast stay and the two Topgallant stays 1/5
Shrouds for the last 3 = 1/6
These following rules apply to the rest of the rigging but they are relative to their respective lines (this should become clear in the table below):
Mast tackle pendants = shrouds (i.e Main mast tackle pendants = the Main mast shroud diameter)
Shroud deadeye laniards = 1/2 the shroud
Stay collars = 3/4 of the stay
Tackle runners = 2/3 of their pendant
Tackle falls = 1/2 of their runner or pendant
Backstays = Shrouds
Tyes = Shrouds
Halyards = 2/3 of the Tye
Lifts = 3/8 of the shroud
Lift pendants = 1/2 shroud
Braces = 3/4 of the Brace pendant
Brace Pendant = 1/2 shroud
Deadeyes = 1/2 the diameter of the mast
Tacks = shroud
Sheet = 3/4 shroud
Clews = 1/2 of the sheet
Bowlines = 1/2 shroud
Leech lines = 1/3 shroud
Bunt lines = 1/3 shroud
Block length should be about 12 times the diameter of the rope and their sheeves should be about 9x the diameter of the rope
Hope that helps some.
Regards,
- mtaylor, paulsutcliffe, rybakov and 3 others
- 6
13 minutes ago, DSiemens said:
There is little historical evidence for a lot of the flags that are attributed to pirates. Historians traced the appearance of the common flags to the 1950's.
http://www.piratesurgeon.com/pages/surgeon_pages/memento_mori6.html
That is an interesting article. It does state that the common images of the flags as shown are probably from a more modern source , however it later states that some of them depict images as described in period sources.
Regards,
- 2
You have to remember the purpose of a pirate ship. It was to make money by looting or taking other vessels. It was not sensible to extensively damage or sink the other vessel unless they absolutely did not need it. To that end most pirates actively cultivated a fierce persona and reputation to cow their prey into submission without having to fire a shot. Gunpowder and shot was also a large expense item. To that end many of them adopted their own flags so that they would be recognized and feared on first sighting.
The 'golden age' of piracy was in the early 1700's. Some notable pirates of the time flew versions of the "Jolly Roger" The first skull and crossbones motif appeared in 1700 when the French pirate Emanuel Wynne hoisted a black flag with a skull and crossbones over an hourglass to show his prey that time was running out. Thomas Tew flew a black flag with an arm holding a sword. Jack Rackam had a skull and crossed swords. Bartholomew Roberts' showed a pirate and a skeleton holding a spear supporting an cup between them, drinking a toast to death. Another flag of his showed himself standing on two skulls. One labeled ABH (A Barbadian's Head) and the other AMH (A Martinican's Head). Blackbeard, Edward Teach flew a black flag with a skeleton holding a a glass in one hand and a spear in the other which was aimed at a bleeding red heart. Edward Low flew a black flag with a red skeleton.
Regards,
- thibaultron and mtaylor
- 2
19 minutes ago, Jim Rogers said:
I do the backstays last and use them to tighten everything up.
That is how it was done on the actual ships.
Regards,
- mtaylor, thibaultron and el cid
- 3
A fascinating and relatively unknown piece of history.
Regards,
- John Allen, mtaylor, lmagna and 5 others
- 8
MPC steam locomotive "The General" 1:25 scale by Popeye the Sailor - finished
in Non-ship/categorised builds
I remember building this kit back in the day. I have no idea what happened to the model.
Regards,
