Everything posted by jwvolz
You'll find that Syren wheel kit quite an upgrade. Great little kit.
- 950 replies
- syren
- model shipways
Looks very nice. I rigged mine per the Irene book for what that is worth, which looks like option 3... Main/Crossjack yard braces originating on fore shrouds, taken to block on yard pendant, then back through a leading block on fore shrouds, then belayed to bulwark pinrail.
- 102 replies
- cruiser
- caldercraft
Very nice work so far John.
- 104 replies
- model shipways
- new bedford whaleboat
Thanks Richard, it's an enjoyable build.
- 140 replies
- benjamin w latham
- model shipways
Thanks guys. I'm really enjoying this build. The little details as Bob mentioned make the difference, and 1/48 helps with that.
- 140 replies
- benjamin w latham
- model shipways
First update in a while. Once my company lifted travel restrictions, I've gotten very busy at work, which I'm actually quite happy about, but it has kept me away from the bench more. Finished the trunk cabin. It's a straightforward build, and the plans are good. The iron bars that make up the skylight framing were a bit tricky. I ended up using small gauge brass rod and they worked out great. It's just tricky getting them all the same length. I ended up sanding to final height with the sandpaper on a piece of glass. I used boxwood for the skylight, as basswood would have certainly split drilling all the holes for the bars. The porthole rings/frames are not supplied so I fabricated them from appropriate sized styrene tubing. I still need to make the smokehead cover.
- 140 replies
- benjamin w latham
- model shipways
Don't know how I missed your log, but saw the gallery photos and just caught up. What a great build! I really like what you did with all the weathering. I never really considered building this kit, but you now have me intrigued...
- 52 replies
- model shipways
Nice work! And you're moving very quickly too.
- 138 replies
- glad tidings
- model shipways
Cannon Balls 9mm
jwvolz replied to REG Head's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
OOO Buckshot is the almost the exact size you need (9.1mm) I don't know where you are located, but a 5 round box (8 pellets per shell) is about $7.00 a box in the US. -
Could be a flag halyard.
Painted the dory and added a few little details. I'll add oars and maybe a few more things later on.
- 140 replies
- benjamin w latham
- model shipways
