Everything posted by clearway
Thanks Keith, wish i had a fiver for everytime i have knocked the whisker booms😬! On a good note The Book is finally printed so hopefully will get a call off the bookstore i ordered it with soon 😁. Keith
Thanks for the likes and looking in as always everyone, thanks to rain moving in Friday afternoon all the way through til this Sunday) morning , garden chores out the window but got some work done on Terror. The jib boom guys are now rigged along with the down haul on the fore topmast stay sail. Take care all. Keith
I chose the flattening the ends of wire and drilling holes through for the deadeye strops on my HMS Terror build and it was shall we say interesting! Keith
- 118 replies
- billing boats
- meta 484
Ahhh summers like we used to get before the 2000s! Either work outside in the high twenties centigrade or hide in the shipyard🤪. Managed to finally get the whisker booms painted and temp fitted (feels like agessss since i made these)! Also got the first of the jib boom guys spliced on the end. Moving aft slightly the sheets on the fore course are rigged though the tacks still need run through a block on the end of the boomkins and belayed, the midships anchors have also been stowed on the ice bumper along with trail fitting of spare spars in the waist stanchions. looking at some of the images that have come to life it does look like flying jib boom and stunsail booms were fitted! though not sure tri sail yards would be rigged, hindsight is a wonderful thing but just going to leave my lil Terror as is! Thanks for looking in and the likes/ comments as always everyone. Keith
Nice work on the bands/ goosenecks😀 Keith
- 118 replies
- billing boats
- meta 484
Hi Daniel, i will eventually get around to adding ladders to both sides , all ships i have seen have had ladders both sides and suspect terror and erebus would have been no different (if you look at the much repeated lithograph of the ships setting out you can make out the ladder on the port side of erebus {closest of two ships in pic}) Keith
Thanks for likes and comments and looking in. A little more progress on the ritz hatch and started adding veneer to stern hatchway. Also cut away the mddle cross pieces on the engine room skylight as per my plans from N.M.M. (it looks like originally there were windows on the sides of the light as well because they had seats running the length of the skylight for the intended well to do clientele she was built for originally which is probably why they did the windows like they did). Also added the hawses for the anchors. Take care all. Keith
billings Victory at 1/75 scale is a massive beast, This beauty must be hugeeeeeeeeeeeeeeee!!!!!!!! 😁 Keith
Another build down the ways- well done Keith p.s. don't forget to add finished to build log title😉
- 35 replies
- Artesania Latina
- Sultan
Don't forget you also have stern davits for boat storage too😉- i liked Keith s comment a while back about turtles on a log when referring to the amount of boats on Terror/ Erebus! Keith
you are welcome- The running rigging is fun! - Thats why i didn't add the backstays and boat till as late as possible and didn't fasten in the skid beams etc to leave access room to belay the running rigging. Keith
Hi Johnny- i am going with i hope version 2! I would imagine the hatch replacing the skylight would have been done in the yard (originally the ritz was paneled a la cutty sark deckhouse style which they removed/ covered over with tongue and groove planking seen on pics). Also originally the portholes/ windows were square on original build. Talk about take your pick! Keith
Thanks for likes/looking in. Not spent much time in shipyard this weekend, but managed to do a little bit more with hatch on the ritz roof and a coat of paint on the galley stovepipe. Also when looking at pics in the "south with Endurance" book and stern views of wreck noticed the companion way on the poop deck has three small windows each side. Have drilled and filed those along with adding curve to roof of hatch. Take care all Keith
safe to say you, keith s and myself have moved away from the occre instructions slightly!! Keith
Anchors! after much deliberation over the last couple of years finally decided to replace the kit anchors with ones from aeronaut (one already in place). Using 30mm and 20mm for the ones aft and 40mm for the ones at the bows and midships which equate to the 10 foot anchors on the plans. While the kit anchors are o.k. the stocks are really thick which bulks them out too much to fit behind the shrouds. Take care everyone and thanks for likes and looking in. Keith
thanks for the likes and looking in. Both halves of hull now joined and gland for prop shaft glued on. Also the tubing for the rudderpost is tacked in place and will be epoxied in place same time as prop shaft (best say now that no i wont be RCing her though). Also here are a couple of shots showing where i want to go with her, as an aside billings Norden should have a hull like this (think they just re scaled their Mary Ann hull). Take care all Keith
Thanks Hakezou, i am basing my thoughts on the below photo. The funnel is in the background and the boom on the foreside of the mainmast is behind the crewman also note the pinrails on the shrouds. Good luck with Terror but witha little foresight alterations are easier! Also see daniel D and keithS build logs. The gangways will be located on top edges of ritz/ quaterdeck with the boat skid supporting middle (see photo in link you provided). Take care Keith
look good Daniel- i wouldn't permanently install the davits til all the running rigging is complete though as they will obstruct access and catch every line that goes near them. Keith
Thanks for likes and comments everyone. The first of the anchors are in place (behind the mizzen shrouds) and the port side davits are in place (need lanyards trimmed). hope i dont block access to any pin rails i need to use! Keith
