mort stoll
NRG Member-
Everything posted by mort stoll
Finally completed the stern and quarter galleries. Definitely for me the most difficult part of the build so far. It was difficult to shape those baluster patterns and the decorative brass strips. I still have to varnish the stern and quarter galleries. I also just finished the side entry port and steps. I added rope lines to the steps even though the kit doesn’t show them as I couldn’t imagine those older admirals being able to climb those steps without them, Stay safe and well, Mort
- 60 replies
- victory
- caldercraft
- 60 replies
- victory
- caldercraft
Hi Will, When I installed the stern gallery windows I glazed them as you did. As luck would have it during the course of construction I broke 2 of them. I'm now working on the stern the quarter galleries and just finished installing the window frames #'s 510, 511, 512. I glazed all of the window frames before I glued them on and they all look fine. If I didn't know the glazing was missing on 2 windows I wouldn't know. Also as an added plus the window frames act as sort of a guard as the as the glazing is behind the frames. Hope this helps. Keep up the great work. Any questions, don't hesitate, Mort
Completed the flag lockers - they look better in person - and started work on the stern.
- 60 replies
- victory
- caldercraft
- 60 replies
- victory
- caldercraft
Hi Allan, Gratings are from Syren - Chuck Passaro - not from the kit. Checkered floor pattern I learned to make through Bob Hunts Rattlesnake Practum. I will be happy to post pictures from my build as to how I did it if you like. I already have signed up through the Jersey Club for the Trafalgar Series. Hope it comes to pass. Mort
- 60 replies
- victory
- caldercraft
Completed the bow head rails, gratings , cat-heads and the figure heads. Took me awhile to get it organized but it worked out fairly well. Poop deck is planked - with maple - and just about complete. Am now working on the flag lockers. Stay safe and well, Mort
- 60 replies
- victory
- caldercraft
- 60 replies
- victory
- caldercraft
Hi Will, I carefully bent the copper plates using the small Exacto chisel blade as sort of a bending aid for support . I put the blade over the plate and bent it. I trimmed them with an Exacto chisel, a Dr. Slick microtop scissor - used in fly fishing - and a cuticle scissor. The plates are easy to shape as they are not that thick. Hope this helps, if not don't hesitate. Keep up the great work, Mort
How much of the stern cabins are going to be exposed on the completed model? Thanks, Mort
- 355 replies
- vanguard models
- Sphinx
I've never aged my copper plates. I prefer them to age naturally. They look more realistic I feel as they don't all age at the same pace. Previous to my Victory I used Weldwood Contact Cement whenever I coppered a hull. I always had the fans and a mask on and windows open in my ship room when I worked. Just before coppering on my Victory was to begin I heard that Weldwood had a low odor formula contact cement. I tried it and it was fine. Didn't need a mask. I prefer contact cement because it allows me a few seconds to adjust the position of the plate should I have to after it's placed on the hull. If further adjustment is necessary after the plate is dry, or a day or so later I simply heat the plate or plates with my plank bender and readjust the plates. No problem. Good luck. It's a great kit. Keep up the good work. Mort
