Everything posted by Jack12477
I live in the North (lots of salt on roads) and I also own two Chevy Impalas a 2004 with over 200,000 miles and a 2010 with over 120,000 miles, neither car is showing any signs of rusting. - some minor rust in the wheel wells of the 2004 but none in the 2010. Both are running well and still get 30-32 MPG highway at 70 MPH cruise control speed. They both did come with a factory warrantee of 100,000 miles rust free. aka no rust thru.
Testors makes both a clear and white background decal paper. I've gotten some in Hobby Lobby. Denis (Popeye the Sailor) has another source online. PM hi. The sheets are roughly half an8 x 10 or 8.5 x 11 sheet. Testors also makes a decal sealant spray specifically for ink jet printers to set the ink before applying them. I've used them successfully in a number of applications include on sails (cloth).
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
Kurt, the Lee Valley brushes are not metal wire but rather a stiff bristle in a spiral around a wire "stick" - I think they are nylon bristles, same as you get in the store for cleaning kitchen bottles. In fact they look just like the ones shown in Don's video.
- 133 replies
- alert class
- tugboat
Get out the manual ! Seriously, dissemble the brush, and carefully clean all the parts, Lee Valley sells a really nice set of airbrush cleaning bristle brushes which I use for my Badger 200. You may have to soak the parts in thinner - make sure you disassemble the plunger (where the air hose connects) and clean it too. As a routine when I finish painting I run clear thinner thru the brush even if I am going to continue later. Do the same between colors. At the end of your session, run more thinner thru it and clean with the bristle brushes, disassemble as needed.
- 133 replies
- alert class
- tugboat
Denis, do you mean this bad boy or the B52 kit ? I build this B36 kit probably thirty years or more ago, can't remember if it was a Revell or Monogram kit but it was advertised at the time as being the largest wingspan model airplane available. It's been hanging from the rafters in my cellar since I built it and some parts have fallen off due to glue failure and some of the decals are coming off too; been trying to salvage the decals with Microscale's Sol and Gloss to reattach and reseal them. Plus it is covered in dust which I have to periodically take it down and dust it off without doing any damage. Wingspan by the way is 38-39 inches. Don't remember what scale but I'm guessing 1:72 maybe. (That's my B17 to the right of it)
Thanks, Denis. Nice model of the F-15 you did. I like the shading. I did a F14 some decades back but it got so busted up in storage I had to toss it out. Sitting on the shelf in addition the the F117 A are 1:48 Scale Testors/Italeri : YF-12 A Interceptor, and AC-130 A Hercules Gunship both are huge models. The box for the AC 130 is 40 inches long and the YF12 is 20 inches lone. Once I figure out how and where to display them I will start building them, that is, once I scrape 2 decades worth of dust off the boxes.
Sorry I don't have a full step-by-step build log for this one but I had not thought about a build log when I started it, hence I have only completed/near completed photos to show I chose the daytime mission colors (all gray) over the nighttime mission colors (all black). Even then the decals are barely visible when photographed and only slight more visible to the naked eye. But it was a fun and rather easy build. Not a lot of fiddly bits to mess around with. I also have the F117 Stealth Fighter by Testors/Italeri in 1:48 scale to build - Soon !!! In Paint shop : Final assembly and decal:
I decided to take a break from ship models and whittle down my stash of kits. Chose the PK-503 Dauntless SBD 5 Matchbox kit in 1:32 scale. This model kit was produced by Matchbox from 1977 to 1981. Not sure when I acquired it but the price tag on the box lists KayBee Toy and Hobby stores, price $12.99 on sale (probably clearance) for $3.00. KayBee went out of business entirely in 2007, bought out by Toys-R-Us. Their local store closed some 10-15 years prior. The aircraft model has functioning perforated Split-dive flaps, moveable tail rudder and propeller, a 1,000 pound bomb payload, Wright Cyclone GR-1820-66 radial engine. Kit is 3 color plastic (blue grey, white, and clear), offers a choice of models VMSB-231 South Pacific 1944 USA, A-24B French AF 1944, and #25 D B Squadron, New Zealand AF South Pacific 1944. I chose to model VMSB-231 Marine Bombing Squadron Scout flown by Capt Bell, credited for 23 operational missions and wears the "Ace of Spades" insignia. I used a combination of Valejjo and LifeColor paints. The outer hull of the aircraft was airbrushed with LifeColor Navy Blue. Photos follow: Assembly starts
I think I'm going to reduce the stash by building the 2 Testors/Italeri kits of the F117A and F19 Stealth Fighters which have been sitting on my shelf for ages, then I'll go back to boats.
OC, Carl, CDW, thanks for the info. OC, I use LifeColor too , don't dilute like you do but I do dilute with tap water, I put a small amount of paint on a pallette, dip the brush in water then mix with paint till I get the consistency I want, then brush onto model.
Thanks Carl, yes I had a lot of free time to work on it every day. RE: the primer - the only non-rattle can primer I have is Tamiya gloss white, I have to find some flat gray primer. I've tried the gloss white and it doesn't work to well. The other problem I have is the paint filling in the gaps between the rails, even the rattle can primer does this and I spray from a distance and keep the can moving left to right as I spray but it still fills in the "holes" with paint. Thanks CDW.. I found the Gator Grip worked well if the two pieces being mated were in a horizontal or near horizontal plane but not so well in a vertical plane. Example; trying to attach the ladder to the mast the Gator Grip did not hold long enough to set, the ladder kept falling over. Same with the railings around the upper and lower decks. The Gator didn't have enough holding power to keep them vertical until the glue set, so I had to resort to medium CA for these brass parts. Otherwise it was pretty good. General comment on painting - I'm still trying to work out the right combination of paint to thinner for my airbrushes - so far all I get is a clogged brush so I resorted to hand brushing the past 3 models. Still working on the airbrush. All of the plastic Armor (Tamiya kits) I did before were done with Floquil paint which was easy to mix (for me at least), these acrylics are a bit more difficult (for me) but they do brush on nicely. I'm also experimenting with different brands.
