Posts posted by Kevin Kenny
I hate using pseudonym, any way. “no idea” have you figured out the various needle sizes that would produce the correct size treenails.
in 1/4” scale i am looking for 1”, 1.5” and 1.75”, in imperial measurement that would be .021, .03 & .036 and in metric it would be .56, .78 & .94.
once i can confirm these numbers and find a good supplier i would post this data in the video description with the appropriate link. Also, have you figured out the best speed for the drill press. Its quite clear to me that if the speed get above 1000 RPM the needle get to jot. I started lubricating with silicon and it works great. I even sprayed the wood and all the burning stopped.
kevin -
Stuglo, i assume you are asking about the needles used to make the tree nails. The sharpened point was cut off and the blunt end sharpened evenly. This was used to drill the wood and i was able to fill the blank with 65 holes each having a treenail in it. This took about 2 minutes. Its still early days as these needles cut 2” treenails. I need to get smaller needles before i sign off on this method. In the mean time i am using treenails made on the jim Byrnes draw plate.
- GrandpaPhil, mtaylor, ct mike and 2 others
- 5
- mtaylor, GrandpaPhil and AJohnson
- 3
HMS Thorn by Kevin Kenny - 1:48 scale - Swan-class - David Antscherl practium
Thats exactly what we needed Mark. I have added it to the description of the video.
